Question about Tappan TEF242 Electric Kitchen Range
Put on the self cleaning...and some wires in the back sparked and it shut down the circuit breakers? ITs a electric tappan
  • 21 Answers
Hello
Is the stove directly wired? The code says the wire coming from the breaker box should be connected to a four prong 50amp range receptacle. Then a 50amp four prong range cord from the receptacle to the range. There's a clip on the back of the stove that connects the neutral wire to the frame of the stove. It has to be removed and the green wire coming from the cord connected to a green screw on the stove to separate the neutral form the ground. Get a licensed electrician.
John
Posted on Jan 07, 2010
Trigger siwtch spark cause electric short circuits
short in the ignition switch or loose wire at the ignition switch. if trigger switch is the key ignition switch you referring to.
Sep 02, 2012 | Cars & Trucks
We set our wall oven for self-clean and received an error message after about 4 hours that told us to turn off the circuit breaker. We are unable to turn the circuit breaker back on again.
If you cannot turn the breaker back on then it is no good...some breakers do take some very firm effort to get them to come on...but the oven may have ruined the circuit breaker...
Circuit Breaker Keeps Tripping
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Dec 26, 2010 | Thermador SC302T Electric Double Oven
My Tappan oven is built in and 23 years old. I put it on self clean. It did, but the noise won't shut off. I turned the oven to off, but the noise still goes on. There is no way I can unplug it.
go to your homes power panel and find the circuit breaker or fuse controlling this circuit and shut off the breaker or pull the fuse,this will power down the unit
Nov 07, 2010 | Tappan TGF320 Gas Kitchen Range
I turned on the cleaning switch for my self cleaning wall oven and now it seems to be finished but mthe door lock is still on and the oven keeps making a buzzing noise what do I do?
If the lock does not open after the oven has cooled down, then try this: First, unplug the range or shut off the circuit breaker for ten minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. Next, set the self-clean cycle again and only allow it to work for twenty minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door
Mar 13, 2010 | Frigidaire 27 in. Electric Double...
Can not open the door of the self- cleaning electric Range after cleaning operation
Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
or
Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures
Mar 11, 2010 | Kenmore 99123 Electric Kitchen Range
Tappan 30 Series Range ignition system
no fuse/ with execption of trying to reset circuit breaker. perhaps the power tripped the breaker om the electrical panel, if the power supply is goos to the unit i would look to the spark module( it contorls all electronic ignition function
May 08, 2008 | Tappan TGF320 Gas Kitchen Range
Kitchenaid double oven shut down!
The problem is they overheat because hot air is drawn in by the blower and overheats the outer chamber of the oven where the thermo fuse link is. The one or two fuse links are blown simple replacement but have to remove oven (two person job) remove outer shell and find it (them) in the back of the oven. Also the fuse link wire going into the main processor is probably blown.
Sep 06, 2007 | KitchenAid Architect Series KEBC208KSS...
Tappan TEF242 Electric Kitchen Range Logo
102 people viewed this question
Top Tappan Kitchen Ranges Experts
Paul Carew
Sal De
Craig Butler
Craig Butler
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
