Question about Curtis CM27002S 27" TV
Cannot get the tv to work through my vcr/dvd player
I am not sure what model I have but it is Curtis 27" not a flat screen. It will not let me watch the Tv through the vcr even when I put it on Av1. My vcr is fine because it even records ok. Did work when I 1st got the thing like a month ago I want to be able to watch & change channels through my vcr/dvd player. It just stopped working?? Help please.
5 Suggested Answers
SOURCE: curtis mathis universal control code for 13 in tv cm13102
We also bought a universal remote to program a Curtis Mathis TV. We found the code by using the code search method. It works everything but the channel program feature. Does anyone know how to access that? BTW the remote is a GE 24921. Thanks
Posted on Apr 26, 2008
  • 56 Answers
SOURCE: Old Curtis CMC13003 will not display DVD picture
Radio Shack has a Y adapter to hook up the 2 audio wires together RED/WHITE are audio. 2 females to 1 male Y adapter
Posted on Feb 03, 2009
BElectric
  • 1140 Answers
SOURCE: I have a curtis television
Hello Dave,
A slightly better description of the problem would have helped, so I'm having to guess a little here. I suspect that you are trying to play a DVD without switching the TV to DVD mode first. You have to put the TV in DVD mode in order to play a disc.
To switch to DVD mode
1. Switch the TV on.
2. Press the TV/VIDEO button on the Curtis remote repeatedly until DVD is displayed in the corner of the screen **
3. Insert a DVD
4. Press PLAY
** If a list is displayed (TV, VIDEO, S-VIDEO) when you first press TV/VIDEO, use the UP/DOWN arrow keys (above and below ENTER) to highlight DVD, then press ENTER to select
When you have finished watching a DVD, you need to use the TV/VIDEO button again to return to TV mode. If you are using an antenna connection or a cable line direct to the TV, the correct selection for watching TV is TV.
If you have a cable box or satellite receiver connected by AV cables or another type of cable, you may need to select the VIDEO, S-VIDEO or COMPONENT or even HDMI mode to return to watching TV.
Hope this helps. If you need further assistance, please reply to me by clicking on "Add a Comment" below your question and include full details of the problem.
Regards,
BElectric
Posted on Apr 18, 2011
homearceo
  • 66 Answers
SOURCE: My daughter's Curtis LCDVD244A will
if its under warranty just return it to the store or to the authorized service center... if not there is some helpful tips to help you.. (1) for continued protection please unplug the unit from the wall socket.. for your own safety please wait for at lease a day to automatically discharged any electrical shocks stored on the unit (for beginners)... (2) remove the protected cover (3) inspect and observe the circuit esp on the power supply circuit. because almost all electronics brand are using the SMPS (switch mode power supply) now. so even the slight changes in resistance on resistor may cause the problem.. but the most common cause of the problem in the SMPS is the filter capacitor. so the easiest way to know that a defective capacitor is by looking by its shape.. esp on a round head shape. you can easily notice it by comparing it to the other shapes... mostly it value about 16 volt 1500 uf or 25 volts 2200 uf. but no matter the value is. just look for the shape and you can notice it what i mean... ty
Posted on Jun 21, 2011
While moving my parent's Curtis Mathes Cm19001 TV produced in 1999, I touched the channel button which took the TV off of channel 3. We've tried to use the channel buttons to return to channel 3,...
I have one of this tv model too.Just used a RCA component cables like Y,R,W hook one side to the tv Video IN INPUT holes and the VCR the other end of the cable to VCR Video OUT INPUT holes.Now just pushes a channel manual button up or down a couples for the tv go into VIDEO Mode.Play the dvd player it will work.Or try Remotes.com to buy a tv original remote.Return the universal remote.
Jun 18, 2011 | Curtis-Mathis CM19011 TV
IMagnavox TV stuck on VCR mode
Youre gonna need the original replacement remote , heres a link to get your replacement :
http://www.replacementremotes.com/
Dec 01, 2009 | Philips Magnavox 27MS343S 27" TV
Insignia flat screen (tv/dvd) combo. dvd player does not work
Get someone technical to open the unit and clean the laser lens with a swab of eyeglass cleaner and also clean the rails that the laser runs on
Please rate my help if this helps
Thanks
Aug 30, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
On my combo tv/vcr/dvd the vcr and dvd do not work is there a way to hook up an external dvd player
DVD's dont have coax output so you can use your RCA output (yellow,red and white) and hook to the input of your TV you just gotta select the input its on(i.e. Video1)
Jun 28, 2009 | Samsung DynaFlat CXM2785TP 27 in....
Parental lock
i have the same exact problem what i figured out is that i cant watch cable on it but when i hook a vcr to it i can watch movies. but when i hook my dvd player to it the block comes back on. so i hooked my playstation 2 to my vcr and hooked my vcr to the tv and i can watch dvd's that way. thats all i have sorry..
Oct 20, 2008 | JVC AV-27820 27" TV
Curtis Mathes TV Remote Control Codes for Programming the remote to the TV
I own a One-for-All universal remote, and my booklet says the setup code for a Curtis Mathes TV (without a built-in DVD or VCR) is one of the following numbers: 0030, 0047, 0054, 0060, 0093, 0145, 0154, 0166, 0451, 0702. I can not guarantee these numbers will work with your remote, but it is worth a try.
Jul 03, 2008 | Curtis-Mathis CM32010 TV
Unable to connect philips dvd recorder/vcr recorder to philips flat screen 19pfl4322 tv. HAVE AV 1 AND AV2 ON FLAT SCREEN TV BUT RECORDER WILL NOT GIVE MENU PICTURE. COAXIAL CABLE ATTACHED TO VCR AHD...
make sure that av 1 out on the dvd go into av1 in on the screen and av2out goes to av2in onto the screen.make sure the cable is not loose.press av on the tv remote till you find it. same with the vcr remote
Mar 31, 2008 | Televison & Video
Black square (parental Control??)
You'll have to go into the menu setting of the VCR and turn the controls off, also you can try completely unplugging the VCR and then plugging it back in again to see if it goes away.
Feb 10, 2008 | Curtis DVD-7600 DVD Player/VCR
Curtis CM27002S 27" TV Logo
46 people viewed this question
Top Curtis Televison & Video Experts
Steve Allison
Steve Allison
bihug
bihug
Level 1 Expert
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
