Question about Samsung Cell Phones
Trying to set up one touch dial or speed dial on Samsung U640
I downloaded the interactive user guide found on my wireless phone provider website
Posted on Dec 13, 2009
SOURCE:
How to remve hinge on samsung-u640 cell phone
Have you read assembly/disassembly manual?
Oct 11, 2014 | Samsung Cell Phones
How do you put speed dialing in a samsung GT-C3520
To Set speed dial numbers do the following:
1. In Menu mode, select Phonebook.
2. Select a contact to assign.
3. Select More -> Add to speed dial.
4. Select a number (if necessary).
5. Select a speed dial number you want to set.
The contact is saved to the speed dial number.
Note:
• You can call this contact by touching and
holding the assigned speed dial number in
the dialling screen.
• The first 3 speed dial numbers will be
assigned to the top 3 list on the widget toolbar.
May 16, 2014 | Samsung GT-C3520 Unlocked Quad-Band GSM...
Dropped samsung U640 in water now stuck nin USB download mode
water in in take to dealer or open and clean it yourself. water got in jack port
Sep 06, 2012 | Samsung 9 Out Of 10 Convoy Sch U640 Rugged...
How to set speed dials
Adding a speed dial - Samsung Convoy (SCH-u640)
  1. From the main screen, press OK to choose MENU.
  2. Select Contacts then press OK.
  3. Select Speed Dials then press OK.
  4. Select the desired speed dial number then press OK to choose SET.
  5. Select the desired contact then press OK.
  6. If prompted, select the desired phone number then press OK.
  7. Select Yes then press OK.
-------a rating of "4" and a testimonial would highly be appreciated"------- you may also click on "YES" if this solution has resolve your problem...
thank you for choosing fixya...
Roger...
Sep 06, 2011 | Samsung Convoy Cell Phone
I have registered my Brother MFC 9840CDW on the brother website but it still says "not registered" when I try to email a scanned document. I registered it online. Do I have to do anything on the...
If the LCD shows Not Registered when you enter a One-Touch or a Speed-Dial number, it means that an email or number is not stored there.
If you selected E-Mail and save the E-mail address, you can only use the E-mail address when you are in Scan mode. If you selected IFAX and save the E-mail address, you can only use the E-mail address when you are in Fax mode.
Your machine has 20 One-Touch keys where you can store 40 fax or telephone numbers or E-mail addresses for automatic dialing. To access numbers 21 to 40, hold down Shift as you press the One-Touch key
You can dial in any of the following ways.
Manual dialing
Use the dial pad to enter all the digits of the telephone or fax number.
One-touch dialing
Press the One-Touch key that stores the number you want to call. (See Storing one-touch dial numbers on page 60.)
To dial One-Touch numbers 21 to 40, hold down Shift as you press the One-Touch key.
Speed-dialing
Hold down Shift as you press Search/Speed Dial, and then enter the three-digit Speed-Dial number. (See Storing speed-dial numbers on page 61.) Three-digit number
May 17, 2011 | Brother MFC-9840CDW Laser Printer
I need to set up a number on speed dial and delete one.. i have a brother intellifax 4750e
Storing Speed Dial Numbers
1 Press Menu, 2, 3, 2.
2 Enter a three-digit Speed Dial number, and then press Set.
3 Enter a number (up to 20 digits), and then press Set.
4 Enter a name (or leave it blank), and then press Set.
5 Press Stop/Exit.
Changing One Touch and Speed Dial Numbers
If you try to store a One Touch or Speed Dial number in a location where a
number is already stored, the LCD shows the current name stored at that
location, then prompts you to either
1 Press 1 to change the number, or press 2 to exit without changing it.
2 Enter a new number and then press Set.
If you want to erase the number, press Clear when the cursor is to the left of the
digits.
If you want to change a digit, use left arrow or right arrow to position the cursor under the digit
you want to change, then type over it.
3 Follow the directions beginning at Step 4 for Storing One Touch Numbers or
Storing Speed Dial Numbers.
Feb 28, 2011 | Office Equipment & Supplies
How do I set and save a fax number as a speed dial
You can download the User Manual from here (temporary link): http://dl.dropbox.com/u/1322442/CANON%20CFX-L4000.pdf
Here is a transcript:
Storing Numbers for One-Touch Speed Dialing
Your Canon fax can store up to 120 phone numbers: up to 20 of your most frequently used numbers can be stored for One-Touch Speed dialing, and an additional 100 numbers can be stored for Coded Speed Dialing.
1. Press SET and DATA REGISTRATION
The display will show:
DATA REGISTRATION
1. SPEED DIAL SETUP
2. Press SET twice.
1-TOUCH SPD DIAL
01
3. Use the search buttons (up and down symbols) to select a One-Touch Speed Dialing button between 01 and 20.
1-TOUCH SPD DIAL
[1...7]
??¢ You can also do this by pressing FUNCTION, then pressing the One-Touch Speed Dialing button, then pressing FUNCTION again.
??¢ If a number is already stored at the button you select, that number appears.
??¢ If the button you select is registered for Group Dialing, GROUP DIAL appears.
4. Press SET twice. Use the numeric buttons to enter the fax number you want to store.
TELEPHONE NUMBER
TEL =
??¢ Press SPACE to enter spaces between numbers. (Spaces are optional and are ignored during dialing.)
??¢ If you want to clear a number or a mistaken entry, press CLEAR.
??¢ To enter a pause in the number, press PAUSE one or more times
Sep 22, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
Samsung s8300 how do i speed dial using keyboard
Hi, I found a way to get Speed Dial on the Eternity or Ultra Touch . As follows: [most of this from Phonebook/More/Settings/1 ]
1. Copy all address book entries from Sim to Phone Memory.
2. Delete all Sim Address book entries.
3. Switch Address book source to Sim.
3. Re-enter up to 99 speed dial entries in Sim, in the exact order you want them to be assigned to speed dial.
4. Switch Address book source back to Phone Memory.
From now on all numbers on the Sim will be in Speed Dial and you will view the address book from phone memory. Of course any number can be in both places.
Now to speed dial just enter 1#, 2# etc for any number in the Sim Address book. You will get to view and confirm the entry and then dial. In a way this is even better then the speed dial functions on older Samsungs, as the preview before dialing ensures you have the right speed dial entry.
I think it works fine. dk
Jan 30, 2010 | Samsung S8300 Ultra Touch platinium-red...
Speed dial
Jun 20, 2009 | Samsung S8300 Ultra Touch platinium-red...
Clear speed dial/one touch settings
There is no way to clear the settings you would have to re-program the correct setting. Did you program one touch speed dial on the line buttons? I do not see how programming a speed dial could effect accessing the CO lines unless you re-programmed the CO line buttons by mistake. If so, you would need to re-program those soft keys to line buttons. The manual you have may not cover this? The phone you have can work on a few different Panasonic phone systems. If you need a more detailed manual you will first need to know which Panasonic phone system you have. The phone part number WILL NOT help you determine which phone system you have. There is a main control unit somewhere (basement, utility closet, etc..)
Aug 13, 2007 | Panasonic KX-T7431 Corded Phone
Cell Phones Logo
210 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
