Question about Viking 24 in. Professional Series VUD040 Stainless Steel (Premium) Built-in Dishwasher
VIKING DISHWAsher doesn't work U040SS
DOESN'T STOP UMPING AND WONT SUT OFF
  • Anonymous Mar 09, 2008
    I put in a new water shutoff valve (old one didn't supply enough water) and now the Viking dishwasher fills and pumps out continually but will not cycle or shut off.
  • 92 Answers
Your dishwasher is leaking into a tray underneath tripping a flood switch find the leak fix the problem
Posted on Jan 20, 2008
Lcode 1 flashes and drain pump doesn't stop
The flash code means there is water in the base panel underneath appliance first check the support on your lower arm isn't loose then leave to dry out
Jan 01, 2013 | Hotpoint-Ariston LFT 321HX Dishwasher
Whirlpool dishwasher wont wash
if the bottom tub is filling with water but not washing the issues is with the wash motor, some of this model use a start capacitor that can fail, if it has a capacitor on the side of the motor it may have failed but are difficult to diagnose but are cheap to replace so worth trying, if this doesn't help or if it doesn't have a capacitor then the fault is with the wash motor.
Mar 08, 2012 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwasher doesn't drain completely and then turns itself off. Dishes are not clean.
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Sep 12, 2011 | Viking DFUD042 Built-in Dishwasher
I have a husqvarna viking 5610 and it was an auction find. The reverse button doesn't work at all. It won't go in or anything. I've looked inside the back and it doesn't appear that...
Try setting the machine in direct sunlight with the back cover off and let it get nice and warm. It might even need a little assistance from a hair drier. Warm the area directly behind the reverse button. If you can get it to move a little, you will see which parts are moving. Use Tri-Flow on these parts and they may come loose without having to take it in for service. DO NOT USE WD-40 or 3-IN-1 oil. Go to a bicycle shop and get a small bottle of Tri-Flow liquid.If that won't work, any authorized Husqvarna Viking repair center should be able to take care of it for you. Don't force anything too hard. If you break anything, you may not be able to find parts as they are no longer available from the manufacturer.
Sep 09, 2011 | Husqvarna Viking 1
Dishwasher doesn't seem to be getting power. Breaker looks good
first check the power connection behind the toe-kick pane,then theres a fuse in the control panel to protect the electronics which can open and kill power to the unit
Aug 02, 2011 | Viking DFUD042P Built-in Dishwasher
I just bought a used Husqvarna Viking Designer I, and although the item was described as being "in perfect working order," the bobbin doesn't wind properly. The bobbin stop doesn't slide...
If you go to your local jo-ann's or hancock, they generally have a technition who comes in once a week our so to fix machines. A tune-up will generally run between $60-100, and thay should help your above mentioned problem, as well as keep everything else in tio-top shape. If there were, by slim chance, to be any additional costs associated with such a repair, the repair person will tell you ahead of time. Congrats on your new purchase!
Jun 22, 2011 | Husqvarna Designer I
Clean light will not stop blinking. nothing will work
There are two solutions. The first solution you can try is to turn off the power to the dishwasher and let it reset. If that solution doesn't work it is your control board.
May 13, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
The dishwasher doesn't seem to drain water.
heatman101
May 10, 2011 | Viking DFUD04 Built-in Dishwasher
I have a GE PDW8680 dishwasher. 5 1/2 years old.
sadly when doing DIY repairs you must be able to figure out how to remove and replace the parts. you could search youtube for a video
Oct 16, 2017 | GE 24 in. Profile PDW8680JSS Built-in...
Viking 24 in. Professional Series VUD040 Stainless Steel (Premium) Built-in Dishwasher Logo
440 people viewed this question
Top Viking Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Lloyd Carter
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
