Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
4wd unit on 9400 grain combine blowing o ring so much psi or someting that it bent the steel plate the o ring is on
    President:
  • 1,627 Answers
Sounds like you might have a relief valve stuck,with no releif there can be too mutch pressure as you say.If you go to either rear drive motors[cam lobe motor] then follow the hoses from it to the middle of the combine until you get to the solenoid conltrol valve,the relief valves are in this valve.You need to run some pressure test to verify this,let me know how you make out.
Posted on Dec 17, 2009
Why is wrong, I have an 86 toyota truck, 22re with 0 compression in #3, 125 in 1,2 and 4. I also have a LOT of blow by at oil fill cap. WTF?
a combination of valves and rings
more likely rings or hole in the piston to get so much blow by as blow by is not from valve problems
the combination could be that a valve head broke off and punched a hole in the piston
Apr 20, 2017 | Toyota Cars & Trucks
Tip
How to Clean a Country Living grain mill
One of the most widely used grain mills is the country living grain mill, it is known for its stable build and lifetime warranty. Every so often when you use your grain mill frequently you will need to clean it out to keep it functioning as properly as possible. Luckily cleaning the Country living grain mills are very easy to clean.
First you want to disassemble the grinder, by removing the adjusting knob off of the front of the unit. Make sure that you don't lose the small square piece that keeps the front plate form spinning with the shaft. Behind the knob you will find some washers and the burr. You can take out the burr and use a small brush to clean out any flour than may have gotten caught inside.
Some times you will need to clean the grinding plates this can be done by using the wrench that came with the mill to remove the screws that hold the stationary plate in place. When the plates have been disconnected they can be taken out of the unit for a more thorough cleaning. If you wash them in water make sure that you dry them well immediately to prevent them from rusting. These grinding mills were not made to be washed in water, therefore just using a damp cloth should be thorough enough to clean the whole unit.
When you have finished washing and drying the pieces its time to assemble your mill. Before you put the plate back inside make sure that there is nothing inside the unit because the plate will not reattach if anything is in the way, all the mounting hole have to align before you move on to the next part of the mill. Then follow the disable instruction the reverse order, replace the burr, washers and knob. Wallah! you now have a clean grain mill ready for use.
on Jan 23, 2014 | Kitchen Appliances - Others
What does e01 mean on ninja 3 in one cooking system
EO1" occurs when the unit is still on but the pot has been removed from the cooking housing system. Place the pot back in the cooking unit.
This can also occur for the following reasons:
-if there is food jammed in the gap between the disc and the surrounding heating plate (the blade circle).
-if there is food stuck to the bottom of the pot.
-if there is food stuck on the heating plate (yes even a grain of rice can be a problem!)
-there is mechanical damage to the unit (disc is defective for instance).
-if the handles on the pot got bent down (so the pot is not fully seated on the heating plate and disc does not get pressed)
-debris or other damage preventing the pot from make full contact with the heating plate.
A good tip is to plug in the unit and turned to any mode. Please be sure the unit is completely dry. Use your finger to fully press on the disc and see if EO1 goes way. If pressing down does not clear EO1, then unit is defective.
If EO1 does clear by finger but does not clear when pot is installed - and bottom of pot, heating element and gap between the disk and heating plate are clear, then the unit is defective.
Dec 29, 2016 | Washing Machines
We are harvesting wheat and are having trouble getting a clean sample. We have the fan at 1300 concave closed right up and the thrasher on 800. Having trouble with straw in the sample and white heads.
have you checked the screens for missing lovores,you may have to remove the top set to find the ones letting straw get to the clean grain auger that will then send it to the grain bin.
hope this helps
randy
Nov 11, 2015 | John Deere 9400 9500 9600 Combine Operator...
Dewalt emglow 2gal compressor will not reach cut out pressure
This usually means you have a problem with the piston & cylinder assembly or with the valve plate. If the piston ring or cylinder is damaged, it will compress some air but as the tank pressure rises more and more air will leak past the piston. If the reed valves on the valve plate are bent, warped or broken the same will happen. It's easy to check them for damage by removing the head but Emglow parts are getting harder and harder to find.
Apr 26, 2012 | Air Tools & Compressors
Dewalt D55168 air compressor runs until 95 psi and never stops. Pressure never goes above 95 psi. It use to stop around 140 psi.
Check for leaks all over the machine. Possibly the O ring on the drain valve is damaged. If the machine is oil-less, the big rubber O ring on the piston could be worn away.
When the machine is turned off can you hear air leaking from anywhere?
Mar 31, 2011 | Dewalt D55168 1.8 HP Wheeled Portable...
On my 2006 Ram 2500 truck. Last week I hit a bump while traveling about 60 MPH. The front tire started shaking, I thought I had a blow out. When I slowed down to about 30 it all stopped. When I...
A few possibilities.... bent rim, broken steel belt in tire, or a wheel weight that keeps the tire/wheel combination in balance has fallen off. Not sure how big the bump was, so other options would be suspension related. I would check the tire and/or wheel first.
Sep 27, 2010 | 1999 Dodge Ram 2500 4WD
Motor "bogs down" at roughly 120 psi...almost stops
You suspect this unit as being a two stage because of the unusually high cut off pressure. It is a single stage and the motor really has a difficult task and is being pushed to the limits. to reach this pressure. We usually reset the pressure to lower setting ~~ say around 140. Your pump probably has a leaking intank check valve (brass fitting at tank) or leaking valve plate in pump. Simple tests : with pressure in tank unplug compressor from outlet and listens for air leak around pressure switch. As you unplug the running compressor from outlet you should hear air leaking from pressure switch for just a moment as air is let out of airline from pump to tank. If air leaks out till zero pressure then change the valve. If tank holds pressure then valve probably ok. Next test, with no air in tank and air filter removed, plug in compressor and feel intake port for strong suction. If the valve plate is bad, suction will decrease as pressure neers the 120 mark till the point of feeling that air is actually blowing out of intake. With good valve plate there will be strong suction untill unit reaches set pressure. If valve plate is bad also change the cylinder and piston ring. Good luck with your repair.
Jul 28, 2010 | Dewalt 2 Hp 4 GAL Air Compressor
Fingerprint stains on stainless steel fridge doors
going with the grain( s/s has grain just like wood product) try cleaning with a stainles steel cleanlingcloth and some wd40, this will remove any defect in th metal go with the grain not across you will leave rub marks if going avcross t he grain!!
Feb 12, 2009 | Whirlpool GB2SHKRLS Stainless Steel Bottom...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
106 people viewed this question
Top John Deere Garden Experts
Wayne Fellows
Wayne Fellows
Matt Olenzek
Matt Olenzek
Mike Squire
Are you a John Deere Garden Expert? Answer questions, earn points and help others
