Question about AOC 9GLR 19" CRT Monitor
Extract of xorg.conf file for AOC 9GlrA needed
Do you have an extract of the Linux xorg.conf file relating to the AOC 9GlrA monitor?
ASUS computer not identifying AOC monitor correctly, cannot set native resolution.
Ok. I looked at the AOC site that you went to for the drivers. The drivers come in a ZIP package. Did you extract the files from the ZIP folder or did you point the computer to the ZIP file? The computer probably wont see the files inside the ZIP unless they are extracted first. There are three files inside the folder. The .inf file should trigger the driver load.
Dec 06, 2013 | Computers & Internet
I am using ubuntu 10.04 linux operating system ,but it,s screen resolution is not good .is there any possibility to download and install any vga drivers to get better resolution
Go to System, on the top bar, then Preferences and select Monitors.
On the Monitor Preference screen there will be different resolution settings that you can choose.
If there are any resolution settings higher than 800X600 like 1024X768 etc. select it and apply.
If there is no other settings available go to System then Administration and select Additional driver.
When the Additional drivers screen appears check if it recommends a a driver to be downloaded.
If it does, download the driver and then you will be able to get higher screen resolutions.
If there is no additional driver to download it gets a bit tricky.
You will need to edit your /etc/X11/xorg.conf file.
The file will look someting like this:
Section "Monitor"
Identifier "Philips 190S"
ModeLine "1280x1024" 108.0 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync
Option "PreferredMode" "1280x1024"
Option "DPMS"
HorizSync 30-82
VertRefresh 56-76
EndSection
Section "Screen"
Identifier "Default Screen"
Monitor "Philips 190S"
Device "Default Device"
DefaultDepth 24
SubSection "Display"
Depth 8
Modes "1280x1024" "1152x864" "1024x768" "832x624" "800x600" "720x400" "640x480"
EndSubSection
Depth 24
EndSubSection
EndSection
Section "Module"
Load "glx"
EndSection
Section "Device"
Identifier "Default Device"
Driver "nvidia"
Option "NoLogo" "True"
EndSection
It will be wise to make a backup of this file if you are going to edit it. (xorg.conf.old)
Inside the file you will see your screen and its resolution. (Preferred mode)
You need to change the resolution, save the file and restart your session.
If all went well your resolution will be set to what you specified, if your display freaks out replace the xorg.conf file with the xorg.conf.old file.
Hope one of these options solves your problem!
Regards
Nov 28, 2010 | Vga (CAT5-1000S/R) (EXTCAT51000)
Sync out of range message 29.8k/60, how to clear this ?
This monitor (supposedly) only supports the following ranges:
Horizontal Rate (KHz) 30-70 Vertical Rate (Hz) 56-85
29.8K < 30K (although darn close).
This is usually fixed in the settings for your graphics card. Are you running Windows or Linux?
If Windows: You can load up the drivers for the monitor (I never do) or choose to hardwire the monitor to a VGA LCD 1024x768 and then even force the vertical refresh to 75Hz (or something nice). Try that.
In Linux (under Xwindows), you'll need to look at the /etc/X11/xorg.conf (if using that) and change the section for the monitor to include the limits as shown above.
Do a "man xorg.conf" for the parms. They're also on Xorg's website.
Oct 01, 2009 | Samsung SyncMaster 150MP Monitor
Fedora -9 installation
it should be supported.
Either boot in single user and login in the terminal window, go to your xorg.conf file and edit the resolution to something smaller e.g 1024x768.
Aug 12, 2009 | fedora Linux Operating System
My touch pad wont work
Are you running linux?? do you know how to use linux?
Open a terminal and as root type: nano /etc/X11/xorg.conf or type: sudo nano /etc/X11/xorg.conf if your not root user.
You should be able to find the line that says shmconfig and change it to true.
save the file and restart the computer.
Jun 16, 2009 | Acer Aspire 4530-5889 Notebook PC
Linux Mint graphics problem!!!
If ASUS does not make Linux drivers for you mother board, then you may have to wait a while before someone in the Linux camp makes them.
Jun 08, 2009 | ASUS P5PE-VM Motherboard
Analog - Out of Range.....going to higher video res
Sometimes less is more when configuring X, even with the improvements in X.org
I'd remove everything from the section except Section "Monitor" and Identifier "Monitor0".
Let the boot process do the auto-detection of hardware: card and display monitor.
After logging in -- hope this works -- go the Menus:
System > Preferences > Display and try to get things working through that interface.
Mar 07, 2009 | LG L196WTY Monitor
Monitor screen is off center
Adjust it on your monitor they are not all quitte the same but there must be a button there.Use adjust horizontal if you can find it.
First find your Monitor manual.Then find where it mention something about HorizSync and VertRefresh.
Next open the terminal:
Code:
sudo gedit /etc/X11/xorg.conf
Go to the Section "Monitor"
and add the correct HorizSync and HorizSync
CAUTION: Make sure it's correct it can damage your monitor if you use incorrect numbers!
save and exit. Reboot.
Eg. Mine looks like this:
Code:
Section "Monitor"
Identifier "DELL P992"
HorizSync 30.0 - 107.0
VertRefresh 48.0 - 170.0
Option "DPMS"
EndSection
Another way is to backup your /etc/X11/xorg.conf
Jan 25, 2008 | Acer AL1715 (Black, Silver) 17" LCD...
AOC 9GLR 19" CRT Monitor Logo
129 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
