Question about HP Office Equipment & Supplies
I have a Hewlett Packard HP Color LaserJet 2600n, and recently it has started leaving toner-colored streaks across all my prints. (see scanned example at http://www.wilburncustomshop.com/Laser-problem.jpg What is wrong?
  • Scott Wilburn Dec 12, 2009
    Wow, quick, and you actually READ my post! Thanks for a great solution!
    Genius:
  • 1,112 Answers
Hello:
The Fuser needs replacing. In the back of the unit is the fuser housing unit, remove it and lift the protect flap and you will see the heating roller assembly, If you manually turn the gear look at the area of the roller that is leaving the smear if any indentations on the roller replace it, this will only get worse over time. Also take out toner cartridge and clean the well. This roller is used to heat the paper before the toner is applied to it.
Posted on Dec 12, 2009
    Genius:
  • 1,018 Answers
Forgive me for asking this, but roughly speaking about 80 to 95% of problems involving ink or toner are resolved by the following:
Are you using a factory new ink cartridge supplied by the manufacturer of the printer?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
Don
Posted on Dec 11, 2009
HP Color LaserJet C2320fxi MFP toner tray won't open
i think your not handle correctly...you must contact service engineer???
Apr 18, 2013 | Hewlett Packard Printing & Imaging Hewlett...
My HP Color LaserJet 2600n is printing with small black dots on the left side of the paper. The toner and ink was recently replaced. Is there a plausible reason for this? Thank you!
Could be toner build-up on the fuser sleeve. Pull out the fuser and check the rollers for spots.
Try running cleaning pages before replacing fuser.
Jul 28, 2011 | HP Color LaserJet 2600n Printer
The printout from my HP 2600n has serious toner streaking. The repair centre said that I have to replace all cartridges. Is that the right thing to do?
streaking is usually caused by crud build up on the drying drum. it you have done two sided printing, sometimes the toner ink can get on the drum, you have to take the drum out and clean it.
Mar 08, 2011 | HP Color LaserJet 2600n Printer
Right hand printer cartridge light is flashing - have taken it out and reinserted it, no luck, so put a new one in, still no luck. Only way I can get it to work is to take the right hand cartridge out and...
A Non-HP Toner Cartridge installed error message occurs in the following situations:
  • Non-HP cartridge is installed
  • HP cartridge is not installed correctly
  • False error
  • Sensor issue (hardware)
SOLUTION: The Non-HP Toner Cartridge installed error message could be cleared completing the following steps: All HP toner cartridges carry the Hewlett-Packard logo, and meet HP's high quality standards. 1. Verify that you are using a legitimate HP toner cartridge by going to the HP LaserJet and Color LaserJet Printers - Counterfeit Print Cartridges webpage. Click here to go to the HP LaserJet and Color LaserJet Printers - Counterfeit Print Cartridges webpage (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpl01270) . 2. Remove the toner cartridges, clean the metallic contacts by a dry linen cloth, and then reseat the toner cartridge, and check if the error occurs. To reseat the toner cartridge, see the instructions at the HP Color LaserJet 2600n Printer - Changing Print Cartridges webpage. Click here to view the HP Color LaserJet 2600n Printer - Changing Print Cartridges webpage (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00314345) . 3. If the issue persists, perform a firmware upgrade from the Download drivers and software page at www.hp.com. 4. Restore the factory defaults in order to restore the default settings: a. Use the left arrow or the right arrow button to select Service , and then press SELECT . b. Use the left arrow or the right arrow button to select Restore defaults , and then press SELECT . If the issue still persists, even after completing the troubleshooting steps provided, then use one of the following support options so that HP can work with you to resolve the issue, because it may be related to printer hardware where it needs a live interaction
Oct 26, 2010 | HP Deskjet 460c InkJet Printer
I have a red streak on the page coming from my hp color laser Juest 2600n
are you sure the colour is not magenta,if so replace the magenta toner
May 15, 2010 | HP Color LaserJet 2600n Printer
I have a HP laser 2600n and it is streaking magenta horizontally.
Sounds like the red cartridge was removed or tilted and leaked toner on the drum. Just do a self clean and it will clear up. It in the maintenance menu.
Mar 07, 2010 | HP Color LaserJet 2600n Printer
Grey background over entire page.
If toner is getting onto the transfer belt, it can only get there by either being put there intentionally, or leaking.
Failure of Transfer Belt is normally degraded print quality - usually poor density, or a failure of the support behind the belt (usually puncturing the belt), and scoring a drum.
Sep 15, 2008 | HP Color LaserJet 2600n Printer
Every page covered in magenta and black won't print across the page
This is caused by toner contamination in the laser scanner unit, it is quite a complex job removing and cleaning the laser scanner. I would suggest you contact HP regarding the repair.
Sep 04, 2008 | HP Color LaserJet 2600n Printer
Laserjet 2600n
firstly give the calabration command from the setting and if the problem will not solve the clean scanner assy and also problem will come the replace scanner assy
Jul 18, 2008 | HP Color LaserJet 2600n Printer
HP LaserJet 2600n
It sounds like it, but before you replace it you might want to troubleshoot this through the HP Toolbox (the software would have come with the printer) if you haven't got it, download it from www.hp.com (it's straight forward and easy to use)
Jun 12, 2008 | HP Color LaserJet 2600n Printer
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
