Question about HP Pavilion a1610n PC Desktop
HP desktop locked up, when turned on and off it just beeps
My wife initially tried control/alt delete and it didnt' respond so she turned it off. when she turned it back on it just beeps, but nothing shows up on the screen.
  • 466 Answers
Apparently something went wrong bigtime in the hardware. Does it beep once or more than once? In the second case, check the beep sequence against HP BIOS Beep Codes:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=en&docname=bph07107
If the screen remains completely blank, it's either the video board or the motherboard (if your motherboard has integrated video, you may be able to solve the error by plugging in an additional video card. But it's better if you get it looked on by a tech, because the problem might well be elsewhere).
Posted on Dec 11, 2009
    Sergeant:
  • 275 Answers
Did you try hitting F8 as it is booting up to get to safe screen? Sometimes that at least gets you into it so you can scan for problems.
Possible to fix Power Spec B633 that becomes totally unresponsive if unattended for 15+ minutes?
Most common cause of what you describe is either the power supply or overheating. To troubleshoot this unplug everything that is connected to the computer and all the items that are on the motherboard inside except the power supply and power it on. You should hear the beep signal. IF you don't then it could be the power supply. That is the cheapest thing to replace without a power supply tester. If you do hear the beep, shut it down and put the ram in and try again, then if you hear a beep, plug in the hard drive and try again, then the video card and keep going till you find the bad part. If it is the CPU that is overheating you may not be able to tell right away.
Dec 21, 2015 | Computers & Internet
My sam4s er-180t cash register wont respond it just beeps and comes up with E00
try to do an 'initial clear'
turn power switch on right side of reg to OFF pos
turn control lock to P position
press and hold SBTL key and turn power switch to ON pos
should print 'Initial clear ok'
might need to repeat a couple of times
Jun 22, 2014 | Sam4s ER-180T Cash Register
I have a dell optiplex gx270 with an internal LG GH22LP20 super multi dvd writer installed. The system does not recognize the device at all. Can you help?
Make sure the drive is jumpered to cable select (CS) and using the original Dell Data cable. Re-seat both power and data cable connections.
boot to the BIOS (F2 at boot)
turn on caps lock, scroll lock and numlock on the keyboard
Press ALT + E (should beep once) Press ALT + F (should Beep Once) Press ALT + B system will reboot and re-detect IDE drives
Jul 31, 2011 | Dell OptiPlex GX270 PC Desktop
Unlocking my keyboard
try to press scroll lock. If it did not work try to press Control + Alt + Delete at the same time. If it did not work, turn off the pc, remove the cables and battery, press & hold power button for 10 secs, reinsert the cables and battery back, turn on the laptop. Press again scroll lock, num lock or Ctrl + Alt + Delete. Hope it is ok...
Jul 22, 2010 | Acer Aspire 5315 Notebook
Error msg on startup, no secondary drive found
it means no hard disk detcet on your pc, open the cpu cabinet and check weather the hard disk wire is properly connected or not.
Mar 19, 2010 | Dell Dimension 2400 PC Desktop
Keyboard suddenly stopped working - can't turn off or Control Alt Delete
  1. Disconnect power supply
  2. Remove battery
  3. Wait 30 second
  4. Reïnsert battery
May 05, 2009 | Computers & Internet
Dell Dimension 4600 will not reconize cd or dvd drive
  1. ensure the drives are jumpered Cable select.
  2. Boot to the BIOS, turn on Caps Lock, Scroll Lock, Numlock. Then press ALT+E (You should hear one beep) then ALT+F (You should hear one beep) if you have no floppy disk drive, turn off the Floppy Drive and the diskette controller the ALT+B to save and reboot.
Mar 01, 2009 | Dell Dimension 4600 PC Desktop
Hp 6225 Pavillion Will not fully turn on.
If you can go to their website, and search your machine, I am sure you will see that this is a known issue with several models. They are offering a free one time fix even if out of warranty. I know this because I just got the box to ship my wifes laptop back for the same thing.
Jan 01, 2009 | HP Pavilion dv9000z Notebook
HP Pavilion a1610n PC Desktop Logo
117 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
