Question about Bissell Vacuum - Momentum Cyclonic 1 ea Bagless Upright Vacuum
Bissel Momentum Vacuum
My vacuum runs really loud, to loud to use around the house. Suction is fine. What can i do?
  • Vac Belts
    Vac Belts May 11, 2010
    You can try changing the belt and cleaning off the roller brush. Here is a link to the belt you need and a manual you can view: Bissell Momentum Belt and Manual
  • 85 Answers
There is dirt in the motor you can take it apart and clean it
Posted on Dec 15, 2009
The suction on my bissle 93Z6 isn't working. I can turn the vacuum cleaner on but only if the brush is engaged? Any helpful suggestions to troubleshooting the problem?
I am not sure I understand your question. If the problem is that the vacuum won't run without the carpet head, that is beyond my expertise. If the vacuum is on and there is no suction, there are only three possibilities: 1. There is a plug somewhere between the pick up point and the fan. 2. There is a hole somewhere between the pick up point and the fan (an air leak reduces the vacuum) or 3. The motor is running but the fan is not turning or has been damaged badly.
My son's Bissel lost suction when used to clean carpet, but was fine when doing hard floors. The plug was in the line between the brush and the point where the hose could be removed and connected to a wand to do hard floors. It is difficult to see a plug in this section of the line (it is hidden inside the head). I was able to use a stiff wire (with the vacuum off) to dislodge the plug. (I inserted the wire, poked and prodded the plug., turned the vacuum on and checked to see if it would suck out the plug and repeated until the plug finally cleared.)
My daughter's Bissel lost suction when something (I have no idea what!) abraded the line (short section of ribbed hose) close to the brush so that there was a major air leak. Being cheap, I disassembled it enough that I could wrap that section with electrician's vinyl tape to seal the leak.
I haven't had a vacuum where the fan became disconnected from the motor, but I have had fan destroyed. I had a leaf blower that could also be used as a vacuum. In vacuum mode everything that was sucked up passed through the fan. Unfortunately, it was a strong vacuum and would pick up small rocks. When a fan has lost most of its blades sucking rocks, it stops sucking anything! Most vacuum cleaners are designed so that debris can't get sucked into the fan, so this is the last thing to check. It requires significant disassembly to be able to see the fan and can be dangerous to turn on to observe its operation once exposed.
Jan 29, 2015 | Vacuums
Making loud high pitched noise and no suction. Belt seems fine
Sounds like something is clogged/blocking the intake hose. Pull off your bin & see if you can feel/see anything blocking that hose that everything goes thru.
Jul 08, 2011 | Bissell Vacuum - Momentum Cyclonic 1 ea...
No suction for Kenmore upright vacuum
You have not stated which model vacuum you have. Bipass vacuum have a bipass compartment which is under drive unit. Make sure there are no cracks around housing as this is where you vacuume is created. In order to have vacuum you must have airflow, in assences suction. No air flow, no suction. If the airflow is deverted somehow suction will stop. Your filter, your bag are all sources of air flow. Clog either and you lose suction. Start with loss of air, being cracks in housing,bag or filter
Feb 23, 2010 | Kenmore Vacuums
My vacuum makes a really loud noise when I turn it on. It was working and now it smells like something is burning. I check the belt- it looks ok.
The belt may look okay but it still can be stretched or worn and can be slipping on the motor shaft and thats why you have the burning smell. I would try changing the belt. Here is a link to the manual and a link to the belt you need:
Bissell Momentum User Guide (PDF)
Bissell Momentum Replacement Belts
Oct 31, 2009 | Bissell Vacuum - Momentum Cyclonic 1 ea...
My vacuum makes a loud noise like a soccer horn going off, and neighbors are yelling at me for it! how do i make it quiet? its a bissel.
If you haven't changed the belt recently I would try that. Worn belts can cause funny noises sometimes. You can get Bissell replacement belts here:
www.bissellbelts.com
Oct 28, 2009 | Vacuums
Powertrak bissel vacuum 6390/3910
it might have something stuck, check all the entrance suction sections, also give it little shake
Jun 14, 2009 | Bissell 3594 CleanView PowerTrak Bagless...
Bissel model 3594 has weak suction
clean the filter abovethe dust cup... and any other filters
Feb 16, 2009 | Bissell 3594 CleanView PowerTrak Bagless...
Bissell Vacuum - Momentum Cyclonic 1 ea Bagless Upright Vacuum Logo
1,041 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
