Question about Kenwood Car Audio & Video
My amp got very hot today. No smoke, but smelled like bleach, then like new plastic (like a new shower curtain). Seems to work, but it is still very warm to touch 15 mins after I shut the car off. Any ideas?
    Scholar:
  • 84 Answers
Well, an inadequate ground source (paint between the ring terminal and the ground metal) or just not a good place on the chasis that is grounded. Or you have the amp wired at a low ohm load. the lower ohm load that you have your amp wired at the hotter and more current it will draw from your vehicle. this basically means you may be overworking your amp... If it's improperly wired from the subs to the amp you will certainly fry your amp. Also another reason your amp can get hot is if the amp is underpowering your subs a lot... this also is incuded in overworking your amp... usually it will cause a lot of headlight dimming and that kind of stuff... Also if you have a lot of voltage drop in the vehicle like down in the 11 volt range when the subs hit it will cause your amplifier to heat up a lot...
Posted on Dec 13, 2009
I need advice on what to use on removing mildew stains from a linen shower curtain
Mold Control or solution of TSP to kill the mildew, then bleach, followed by soap and water.
Aug 22, 2018 | Home
Plastic smell
Overheat catalytic converter during your drive??????
Sep 10, 2017 | Fiat Cars & Trucks
New lg tv plastic burning smell
I would contact the store you purchased it from,,,explain the issue and go from there...
Sep 20, 2017 | LG 42LG50 42 in. LCD HDTV
I have an older front loading washer Frigidaire and it's now smelling like mold on all our clothes thought it was me leaving clothes in to long but it's not. model #FWT445GES2 serial #XC74463636 . I have...
No recall, Pour 2 cups of bleach into the washer, Wash on HOT water, long cycle. Then wipe seal with dry cloth. This will eliminate the mold smell... To stop it from coming back ALL front load washer doors MUST be left open to allow the rubber seal to dry, Just like you close your shower curtain so it doesn't get musty smelling... 2 hours is about the dry time... wiping the seal with a cloth usually helps too... All located in your owners manual/
Jul 31, 2009 | Washing Machines
Screechy shower curtain
what I would try is putting a strip of glue from a glue gun. It is barely noticeable. But us enough to stick.
Apr 12, 2009 | Watts 0392262 FS-CWM-S-HH 3/4" x 3/4" x...
they do make chrome plated, plastic curtain rings.
Apr 12, 2009 | Home
How do i install an arc shower curtain rod
you cant you need studs.get the spring loaded rod.
Apr 04, 2009 | Home
Smoke from 95 Camaro steering column
Where ever there's smoke, there's fire. This could be the multifunction switch arching and burning the lubrication in the assembly. Multifunction meaning, one switch that operates the turn signal wipers, cruise etc.
Mar 27, 2009 | 1995 Chevrolet Camaro
How to Install Shower Curtain
If you are going to use both a shower curtain and a shower liner, you have two options for installation. You can either use one rod and one set of rings, or you can use two rods and two sets of rings. If you used one rod, line up the liner and the curtain so they are facing one another and thread one ring through each of the corresponding grommets on the both the liner and the curtain. The curtain liner will move as one unit. If you use two rods, you need one set of rings for each, and the liner and the curtain will move independently.
Aug 27, 2008 | Moen Sienna Towel Bars Black Bathroom...
Car Audio & Video Logo
125 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
