Question about Electrolux Microwave Ovens
Microwave won't power up I unplugged it waited ten seconds or so..sill nothing I also plugged a blender in the outlet to be sure it was just the microwave and the outlet is good
  • Electrolux Master
  • 9,098 Answers
Chances are you have a blown fuse or thermal cutout / thermostat.
Please note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
To allow us to help you effectively (at no charge), please post a
NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, and your symptoms.
Posted on Dec 13, 2009
My fridgedaire brand microwave turns on but it dont heat up
Good Morning Bill, thank you for your inquiry! Please make sure the appliance is NOT plugged into GFI outlet. Let's try resetting the microwave by either flipping the household circuit breaker off or by unplugging. It is important to wait roughly ten minutes and then turn the unit on. If resetting the power does not correct the issue, you appliance could be experiencing the following: faulty power supply, control panel, or magnetron. I am fairly confident that an authorized service agent will be able to restore your appliance to its normal operating condition. You can often locate a qualified service technician on the manufacturer website. Thank you for allowing me to assist you in a small way.
Aug 22, 2013 | Frigidaire FMV156DC Microwave Oven
No power to microwave
Hello
Check the Power Cord
Verify that the power cord is properly connected the outlet; the plug might have been removed to make way for another appliance. Do not connect the microwave to an outlet via an extension cord or plug adapter; the oven must be directly connected to an outlet.
Switch the Outlet on
Turn the outlet on, if possible, using the switch on the wall behind the counter or on the plug itself. Some microwaves have a separate power switch that must be in the correct position before you can begin cooking.
Reset the Oven
Unplug the oven, wait a few seconds and reconnect the power. A power surge could have temporarily rendered the oven inoperable. The oven should start up as normal when you connect the plug to the outlet.
Check the Fuses and Breakers
See that the fuse or breaker protecting the oven's circuit is still active. Replace the fuse if it has blown, or reset the breaker to restore power to the oven. Stop using the microwave if it repeatedly blows fuses or trips breakers.
Oct 04, 2011 | Microwave Ovens
Hotpoint rvm1625sj01 no power
Hello
Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
Oct 04, 2011 | Hotpoint RVM1625 Microwave Oven
My microwave/convection oven will not heat up, but the lights and clock work
Hello
Look to see if the microwave power cord is securely plugged into a live power outlet. The power cord cannot be loose for proper function. Move other appliances to a separate outlet if possible.
Replace or reset the circuit breaker or fuse if blown or tripped.
Unplug the microwave and wait several seconds before plugging it back in to reset.
Make sure there are no current functions in use. Press "Clear/Off" to cancel any other settings or programs already in progress.
Select a new cooking program and then select "Cook Time." Make a time selection and press the "Start/Pause" pad to begin cooking.
Microwave does not work nothing on the control pad work the pad just says se
Hello
Check the power supply. Make sure the microwave is firmly plugged into a working electrical outlet and that your wall outlet is active if your home uses outlets controlled by a wall switch. Check your home's fuses or circuit breakers to ensure they have not been tripped. Without power the microwave will not respond to any input.
Make sure the parental lock is inactive. Some ovens, like the one shown in the image above, feature a keypad lock to prevent children playing with the controls. Most keypad locks can be cancelled by holding down a button or combination of buttons for a few seconds.
Make sure the door is firmly closed. Some microwave ovens will not allow any control panel input if the door is open.
Remove the microwave from the power, wait 10 seconds, then plug it back in. This will reset the microwave oven if there is a temporary problem with the software.
Press the "Stop/Cancel" button several times to cancel the current operation and return the microwave to standby mode. Re-enter your cooking instructions using the keypad as usual.
Oct 04, 2011 | Maytag Microwave Ovens
I just turned on the microwave (samsung) and it started for a second then turned itself off and now it is doing nothing.....
HELLO.
This is the step by step solution.
Check if there is live power on the outlet.
Make sure the microwave plug is fixed properly on the outlet.
If the problem is not solved,then change the fuse placed behind the microwave that is used to control power suppl to the microwave.
Thanks.
Sep 19, 2011 | Samsung Microwave Ovens
Touch screen displays is lit up , but will not respond by touching any of the promts. I have unpluged the unit hopeing to reset no change. unit was working fine the day before.
HELLO.
The solution is to troubleshoot the microwave as explained below.
1 Check the power supply. Make sure the microwave is firmly plugged into a working electrical outlet and that your wall outlet is active if your home uses outlets controlled by a wall switch. Check your home's fuses or circuit breakers to ensure they have not been tripped. Without power the microwave will not respond to any input.
2 Make sure the parental lock is inactive. Some ovens, like the one shown in the image above, feature a keypad lock to prevent children playing with the controls. Most keypad locks can be cancelled by holding down a button or combination of buttons for a few seconds.
3 Make sure the door is firmly closed. Some microwave ovens will not allow any control panel input if the door is open.
4 Remove the microwave from the power, wait 10 seconds, then plug it back in. This will reset the microwave oven if there is a temporary problem with the software.
5 Press the "Stop/Cancel" button several times to cancel the current operation and return the microwave to standby mode. Re-enter your cooking instructions using the keypad as usual.
please let me know the outcome..
thanks.
Sep 10, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Machine not turning on
1. Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
2. Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
3. Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
4. Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
Hope i could help you.
Have a nice day : )
Sep 04, 2011 | Microwave Ovens
Just quit. No power, no display....nothing
there are several possible causes, check voltage at outlet
check the 20 amp bus fuse on the main board ohm out the cavity thermostat, replace the bad part
Sep 10, 2009 | Samsung MS1040BB Microwave Oven
Microwave won't turn on. Seems like it is not getting power. I checked breaker. I am looking for a fuse. You know where one is? It is a GE Spacemaker(2 yrs old) model # JVM1440WH04
  • Make sure that the microwave is plugged into a grounded outlet. It must be a 3-prong outlet.
  • Make sure the clock is set.
  • Check to see if a programming sequence was entered. Sometimes improper programming or a program sequence such as delay start can cause the touch panel to be non-responsive. Unplug microwave or turn off house circuit breaker for 30 seconds. Plug back in, or reset circuit breaker, and try reprogramming unit.
  • Check the house circuit breaker or fuse box. If the microwave is DEAD and there is no display and nothing works- the problem could be a blown fuse or tripped breaker.
Jul 29, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
44 people viewed this question
Top Electrolux Microwave Ovens Experts
William Miller
William Miller
Paul Bade
Are you an Electrolux Microwave Oven Expert? Answer questions, earn points and help others
