Question about Fuji FinePix F470 Digital Camera
Broken Zoom on Fuji Finepix F470
My zoom on my camera is stuck outward. When I power the camera on I can hear the gears inside trying to initialize the zoom and it sounds like a grinding noise since the zoom is already out. I now get a black 'blank' screen and on the first time I would get a picture with me zoom half way out and the display would have a zoom error on it. Any tips on how to fix this if there is even a way?? Thank you.
  • 1 more comment
  • Muncheez Feb 05, 2008
    I have the exact same problem. Now everytime I go to turn it on it says zoom error, and shuts itself off... can't do anything with it. With all these complaints of the same problem you'd think they'd have fixed it. My model is actually the Fuji Finepix F480, instead of the F470. Wish they would have fixed this problem on the new model...
  • adamandrew Feb 17, 2008
    i have same problem with my camera f470, does anyone know warranty on them? showing zoom error and wont move in or out
  • morey_09 Feb 18, 2008
    I sent mine back to Fuji after calling their tech service. I was verbally told this is a mfg error that they are aware of and it shouldn't cost anything. They just mailed me a bill for $116 in parts in labor and I have the option of accepting or declining the work. I need to call and request this be done at no cost. I'll report back on what eventually happens.
    My next camera will not be a FUJI if this is the way they are handling this.
  • 423 Answers
Try turning the power on and gently pulling the lens outward as it powers up. This may force the gears to re-align themselves. Use "fingertip" pressure only. Don't force it excessively. Also try turning on, and then applying slight pressure to the front of the lens while you power it off. You can also try rotating the lens barrel segments while it powers up or shuts off. Sometimes either can get the lens back on track.
Posted on Feb 18, 2008
Cant change from shoot mode to playback mode.also zoom lens is not adjustable
The Fuji FinePix F470 camera is an excellent device. Most of the controls are computerised in such a way that makes picture taking and viewing less stressful. Changing from shoot mode to playback mode is by the press of the play button which looks like an arrow the zoom lens is not manually adjustable it adjusts by the press of the W and T buttons.
Here is a link to help you download the brochure, User guide and quick start guide for the camera:
Hope this soultion has been helpful?
Dec 19, 2010 | Fuji FinePix F470 Digital Camera
Zoom gear problem
helow, can you please explain the problem if you meant zooming doesn't work, it can be due to zoom button broken or zoom mechanical problem if you hear any weird sounds when you try to zoom that maybe to broken gears or a dislocation of the gears, you need to take it to a repair center
Dec 15, 2010 | Fuji FinePix A500 Digital Camera
Problem with F470 Fine pix camera
sounds like the keypad ribbon has either popped out of it's socket or, and this would be the common fault, the ribbon has broken. In which case fuji will be your only way to fix and get it serviced at the same time. last quote I recieved was £80.
source a donor camera on ebay for the cheaper option
Jan 06, 2009 | Fuji FinePix F470 Digital Camera
Comes on, takes pics, menu and all else locked out or don't work
It sounds like you have a problem with the ribbon inside. You need to replace this ribbon connection. You're not locked out, the connection is faulty. Take it to your repairman and explain what is broken.
Jan 04, 2009 | Fuji FinePix F470 Digital Camera
Zoom error
You lens are tilted? If so, they are out of track. Maybe you bumped or dropped the camera. Try straighten them up with your fingers, very gently.
Sep 05, 2008 | Fuji FinePix F470 Digital Camera
Zoom error
Hey MBB722,
What is most likely going on is there is something stuck in the lens obstructing its movement (i.e. sand). I don't know what you have tried and what you have not tried you can try placing the camera on a flat surface with the lens pointing upwards, and then press and hold the shutter button and while doing this turn the camera on. If this doesn't work you can try removing the batteries and waiting a minute or two and then reinserting. If these suggestions don't work you should have it looked at by an authorized service technician such as bringing the camera to a Geek Squad® precinct at a Best Buy™ store and they can send it out for service. I hope this helps!
Go Ahead. Use Us.
Jun 01, 2008 | Fuji FinePix F470 Digital Camera
Finepix A400
If the "!ZOOM ERROR" message is displayed on the digital camera, switch the camera off and on again 2 or 3 times.
If this does not clear the error, take the camera to your nearest FUJIFILM Service Station for testing and repairs. Problem may caused by lens zooming gears stuck.
Apr 04, 2008 | Fujifilm WL-FX9B 0.79x Wide Conversion...
Fuji finepic F470 - Damage Ribbon cable for menu controls
Broken ribbon cable cause key pad not functioning, you may need contact and order a key unit from fujifilm spare parts and replace it to solve  the problem.
Mar 29, 2008 | Fuji FinePix F470 Digital Camera
I used to get that error all the time with a earlier Fuji FinePix with the slide-over lens cover. If the cover wasn't pushed back completely, the lens would extend only so far and then give an error. Make sure that there's nothing (dirt, hair) on any of the lens surfaces and make sure the lens is fully extending when you do turn the zoom on. Don't let anything touch or bump the zoom while it's moving, either.
Not sure if this will help, since you have a different model. This is what worked for me, though.
Nov 16, 2007 | Fuji FinePix F470 Digital Camera
Fuji FinePix F470 Digital Camera Logo
418 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
