Question about Canon BJC 4300 InkJet Printer
Have new inks but still want print,
Everything else seems to be doing what it should it just want print anything .its a canon B J C 4300 color bubble jet printer . it a couple of years old but never been used so it is really new , our other one broke
and hooked this one up . like i said new inks. can you help me out please
    Genius:
  • 1,018 Answers
Make sure that you have removed the packing tape from the nozzles of the ink cartridges.
Forgive me for asking this, but roughly speaking about 80 to 95% of problems involving ink or toner are resolved by the following:
Are you using a factory new ink cartridge supplied by the manufacturer of the printer?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
Don
Posted on Dec 11, 2009
  • 428 Answers
Ink may be new, but their nuzzles may be blocked; depending on manner of storage. To be sure apply a folded tissue paper to the ink nuzzle and press firmly. If the tissue comes off well blotted with ink it means you still have a good amount of ink in it and the nuzzle is not blocked. If not blotted or scantily blotted, it means ink is really low or nuzzle is blocked. To be very sure of this, place nuzzle in a plate/saucer with a bit water so that the nuzzle is soaked. Leave for about 10 minutes. Then apply the tissue again. If still not well blotted it means ink is really low or empty. If new you should return it for a replacement. In the case of blocked nuzzles, the procedure may be repeated over to get results.
  • 8,404 Answers
Did you remove the seals from the cartridges???
Please double check this and then go into the printer program (in the control panel) and run the cleaning routine.
Thanks for your interest in FixYa.com
a
Canon 5750 Won't print the color, although it's set to do that, and cartridges all have ink in it. I deep cleaned and also ran a nozzle check ... but don't know how to interpret that. A = 0 B = -1 C =...
Hi Sue, first tell the exact printer model, because MF5750 is laser printer B&W, lbp5700 is also laser and doesnt have ink.
Wich ink printer do you have like pixma 5300? pixma 4300?
The 5750 doesnt exist in canon range of printers.
But, by your description you have print head problems or clodged inks or purge unit problems.
Aug 28, 2010 | Canon LaserBase MF5750 All-In-One Printer
Black not printing
Canon Bubble Jet i560 Ink Jet Printer not printing black
Aug 01, 2010 | Canon BubbleJet i560 InkJet Printer
Cannon BCJ-4300 has stopped printing/ new ink and will print but no ink on paper/ everything looks good but is there something I am missing/ it has been a dinosaur until now- do not have manual - printer...
Sometimes the printhead itself gets clogged. You can remove it with the green lever to the right of it. Take both cartridges out, take the printhead alone and soak it in lukewarm water for an hour. Rinse when done. You will likely see lots of black ink in the water that has been softened and removed from the printhead. Blow excess water off or leave it to dry. Put known good cartridges back in and you should be ready to go. Done this many many times.
Dec 06, 2009 | Canon BJC 4300 InkJet Printer
Canon pixma ip 4300 colour problems
If they are generic inks, sometimes the colors aren't quite right, also in your machine you can't use the photo inks, the photo magenta and photo cyan are not the right shade for your machine. You need plain magenta and plain cyan. Beyond that you may need a new printhead.
Oct 13, 2009 | Office Equipment & Supplies
Canon IP4200 printed great photos when new. My
Although refill inks can be quite good, it is likely the cause. Several companies do make good refill inks for canon but they are specific to model lines and you have to be sure you get the right ones for photo colour.
The inks you're using are likely "universal" inkjet inks and are fine for everyday printing but are rarely ever colour corrected properly for photo.
My recomendation to all of my customers is always to keep a new cartridge handy for photos but to use the refilled ones whenever they are printing anything else as it will give you the best balance between print cost and print quality.
Chris
May 18, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Printer won't print
It always helps to replace with the correct brand as cheaper versions do fail, also if you had replaced it with a BC-20 from Canon, the supplier may replace it for you. It would be a good idea to trust the printer at this stage, try a Canon BC-20
Sep 07, 2008 | Canon BJC 4300 InkJet Printer
Canon Pixma IP4300 - cartridge recognition preventing any printing happening.
I seem to be having a similar problem with my cannon pixma 4300 as certain others, i have just recently replaced all the inks with " original" cannon inks and all of a sudden it refuses to print anything, it says that one of the inks is not working, ( Yellow) I remove it, replace it again and the light comes on but when the slide retracts the light seems to go off. any ideas would be great, this seems to be a fault i have read a few times.
Aug 11, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Poor color printing quality
do you have the canon print management software installed? it's located in the maintenance tab on that software.
www.canon.com has that by model number
Jun 16, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Canon i560s printer - color problems
I changed the black ink in my printer, now it will not print everything in black!, I changed it back to the old ink, but still not printing black ink, what do I do?
Mar 23, 2008 | Canon BubbleJet i560 InkJet Printer
Print color quality
It sounds as if your adjustments are off. Does this occur when printing from any program, or only a specific one? If any program, the setting has to be in the printer driver itself. Is there a "reset to default" somewhere in the driver? Under the "Color management" tab (Start | Settings | Printer & Faxes | Canon MP390 | Properties) there might be an "Automatic" setting - choose this. Also, go through all the tabs on the printer driver and turn off anything that might affect print output - you'd be amazed how many such settings there are. Hopefully, all you have is a tweaked setting which is causing trouble...
May 29, 2007 | Canon MultiPASS MP390 All-In-One InkJet...
Canon BJC 4300 InkJet Printer Logo
93 people viewed this question
old marine
old marine
