Question about Lexmark All-in-One Printer with PictBridge
Lexxmark x8350 PDF file is to big
My problem is with the Lexmark X8350 when I scan a PDF file that five is too large can not e-mail it reset to default on the printer this printer worked okay on Windows XP downloading new drivers for Vista and loaded about five times the find is always too big in the print does not be in the middle of the page I think it's definitely a software problem can you help me thanking you
    Genius:
  • 1,018 Answers
I would start by looking at the actual data size of the file.
Next step, I would determine is the flow control between the printer and the PC is working correctly.
If the file is very large or intensive (lots of graphic images), I would break the file into several segments.
For example, pages one to five I would highlight and then do a "Save As" and name the new file as filename1.pdf.
Once the file is saved that way, I would move to page six and do a "Save As" filename6.PDF and so on until I have broken the file into more useful segments.
If you have the file and can send it to me at don.farr@hotmail.com, I'll be happy to see if I can structure the file for you.
Don
Posted on Dec 12, 2009
On my X8350 scanner/printer, I can't figure out how to scan to a file and I can't find my manual.
The manual for your printer can tell you all you need to know. It can be found here:
http://www.lexmark.com/publications/pdfs/8300/eng/ug.pdf
Regards
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/don_e04c7d10037aa2ce
Apr 07, 2011 | Lexmark X8350 InkJet Printer
Lexmark 5600 how can a I scan or make it a word document or pdf file
You will need the Lexmark OCR scan software to scan a document from the printer to your computer and save the file as PDF, word document, etc. The Lexmark OCR scan software is only available in the installation disk. If you don't have the disk or you lost it, contact Lexmark technical support to request for it. Thank you for choosing Lexmark.
Sep 14, 2010 | Lexmark X8350 Print, Scan, Copy and Fax...
How do I reset the ink level on my lexmark x8350?
http://support.lexmark.com/index?locale=en&segment=SUPPORT&startover=y&userlocale=EN_US&question=x8350+ink+level&productCode=LEXMARK_X8350&page=answers&detectedProductFacet=CMS-CATEGORY_REF.LEXMARK.PRODUCTS.ALLINONE.LEXMARK_X8350&searchid=1280474419390#1
The above is the description page for you Lexmark printer.
Solution
Some menus on the X8310 and X8350 are repeated in the Copy Mode, Scan Mode, Fax Mode and Photo Card menus.
If you press the Menu button while in any of the above menus, two ancillary menus will be listed, Maintenance and Device Defaults.
To select either of these menus, press the check mark pattlnk_442006_155-selects.gif at the center of the navigation keys on the printer.
Maintenance Menu options View Ink Levels Clean Cartridges Align Cartridges Print Test Page Reset Defaults
Device Defaults Menu options Set Date and Time Language Country Copy Paper Photo Paper Photo Size Button Beep Power Save Timeout Caller ID Pattern
The ink levels should reset when the ink jet cartridge is installed.
Jul 30, 2010 | Lexmark X8350 All-In-One InkJet Printer
NEED A CD DRIVER FOR A LEXMARK X8350 ALL IN ONE PRINTER FAX SCAN
For what operating system do you need the driver?
I suggest that you go to www.lexmark.com Drivers and downloads. Once you are there, you can select your printer and search for all the latest drivers.
Don
Nov 23, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
When I scan a document to PDF with my Lexmark x7170 the PDF files
Sounds like you runs the scan with higher resolution than you did before. lower the resolution in computers scanner software and it will be OK.
Jul 03, 2009 | Lexmark X8350 All-In-One InkJet Printer
Pdf files are to large to email when scanning
copy the pdf text to a word document and relax!!
Jun 20, 2009 | Lexmark X8350 All-In-One InkJet Printer
Scanning to pdf creates files that are extremely large...
Lower your resolution on the file scanning.
Good luck
God Bless
-Carlos:
Default printer factory settings Lexmark X8350
Please follow the steps given below:
1. Press "Fax Mode" button.
2. Press "Menu" button.
3. Use the "Down Arrow" till the display reads "Maintenance."
4. Press "Select."
5. Use the "Down Arrow" buttons till the display reads "Reset Defaults."
6. Press key pad "1."
7. Press "Select."
Please let us know the results.
This will restore to factory default
Apr 27, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
Scanning as PDF
I see from Lexmark's site that your printer can scan to PDF Using the Productivity Suite buttons. The manual is here
But if that doesn't work for you...
I use PDF Creator.
It is a windows program that installs a printer driver that allows you to select it as a printer from any program and will create a PDF file.
For example, you can scan as an image, then open that image in an image viewer then print it to PDF.
Dec 08, 2008 | Lexmark X8350 All-In-One InkJet Printer
Lexmark All-in-One Printer with PictBridge Logo
145 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
