Question about Apple iPhone Smartphone
My iphone does not always ring with the set ring tone. The ring tone is set to "xylophone" but sometimes it only "bings" when a call is coming in. This particular sound is not even a ring tone option. Any explanation for this and how I can get it to stop. Ring tone is locked and still doing this.
4 Suggested Answers
SOURCE: iphone volume
I'm having the same problem. There is a 3rd party app that does this but I think the real answer is to take it in to apple and milk that warranty. It's an awesome phone but you should not have to worry about things like this.
Posted on Dec 06, 2007
SOURCE: iphone does not ring on sleep mode.
I fixed this issues on a friends iPhone.
Upgrade to version 1.1.4 - and you cannot restore your backup.
Posted on Apr 06, 2008
  • 16 Answers
SOURCE: my iphone won't ring with incoming calls. I have
The only thing i would check is the switch on the side. Make sure its not sticking, or accidentally switched it... If its messed up, im sure Apple would replace yours! :)
Posted on Jan 31, 2010
How do I change iPhone ringtone?
Phone has been launched to serve all those who wants to access smart device.There are number of iPhone models available today for users,you can select according to your needs.It is efficient and smart in performing tasks but certain issues might not be easy to rescue on your own.
By using the iPhone's home screen, select the option of "Settings"
Select the option of"Sounds & Haptics."
From the "Sounds and Vibration Patterns" section,select the option of "Ring-tone"
When you use "Ringtone" menu,a list of ring-tone will appear and you can see which is currently being used
After you get the "Ring-tone" screen,you can see a list of all the ring-tone on your iPhone
By using this screen, you can select one of the ring-tone that comes with the iPhone
However,when you want to buy new ring-tone,select "Tone Store" button by using "Store" section
If you want to get proper instructions on buying ring-tones, you may got the procedure by using your iPhone.
There will be "Alert Tones", located down the screen which is used for alarms and other notifications.
After you click a ring-tone, it will play, which let you decide if it's according to your needs
If you've found the ring-tone that you want to use as your default, ensure that you put a check mark next to it and then leave that screen
Now, there is need to see that whether problem has been resolved or not
To know more visit - How to Change iPhone Ringtone without PC
Mar 06, 2018 | Computers & Internet
How can I retrieve my caller tunes from iCloud after a restore on a(n) iPhone 6 plus?
I have read of others having same problem of missing tones after restore or upgrade. Fwiw - I always save backups of everything on my iphone to my PC using iTunes and only use iCloud as my secondary backup. Using iTunes allows selection of each category including "tones". Even though the tones were restored, I found that each contact was reset back to default. I had to go back to each contact, select "edit" and then select "ringtone" which brought up the listing of available tones and all my custom tones were at the top of the list.
if you purchased ringtones or downloaded free ring tones from the iTunes Store and they are missing, you should be able to go to the iTunes Store on your iPhone, select "more" then select "purchases" and re-download them, they may only be listed under the music category. Although I also have heard some people are missing ring tones from their purchases. In this case, you will need to email or call apple customer service.
if all this fails, your can use iTunes or any other music editor to make your own ring tones. Basically you save a copy of the song in m4a format, edit the start and stop times to be 30 sec max play time and save the clip as an .m4r file. You can google the procedure, it's fairly easy. In iTunes, save the clip with a new title then go to the actual file location on the hard drive and simply change the file extension to m4r, then add the file to iTunes and it will show up under "tones", repeat as desired then you can sync the tones.
without iTunes, you need to use an app to make ring tones on your iPhone - Apple has not yet provided this functionality.
Mar 05, 2016 | Apple - iPhone 6 Plus 16GB
The ring tone in my iphone 4 does not sound when the phone is in use, i.e. playing a game, or when it is on charge
Please check your audio settings under 'menu'. Select sound or ringtone and then select 'volume'. The option to 'always ring' should be listed somewhere there. :) hope this helps! Please rate me 4 thumbs up so I get paid if I have helped you :)
Mar 17, 2011 | Apple iPhone Smartphone
How do you adjust the volume on the Samsung T255 StraightTalk phone?
Sound Settings
You can customize various sound settings.
Incoming call
Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
Ringtone.
This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
Volume
This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
  • Use the Right or Left key to increase or decrease the volume.
Alert type
This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
The following options are available:
- Melody: the phone rings using the ring melody selected in the Ringtone menu.
- Vibration: the phone vibrates but does not ring.
- Melody and vibration: the phone rings and vibrates simultaneously.
- Vibration then melody: the phone vibrates three times and then starts ringing.
- Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
Message tone
This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
  • Use the Up or Down Navigation keys to make your selections.
Keypad tone
This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
phone sounds when you press a key.
Jan 25, 2011 | Samsung T239 Cell Phone
How do i set a ring tone from a web site on my iphone?
Go here and download this App.
www.iringer.net
you can use ANY song and create your ring tones here then sync the new ring tones using itunes FOR FREE!!!
Sep 29, 2009 | Apple iPhone 3G Black Smartphone
Keypad tone broblems
Go onto your menu and go to settings, go onto sound or audio and then volume and then go to key tone then select which one you want (or none).
Feb 19, 2009 | Samsung SGH-L760v Cellular Phone
Have nokia 3120 , incoming call does not rings
check if the format of ringtone set is compatible with your phone..
try to restore the refactory settings once.
thankyou.
Nov 19, 2008 | Nokia 3120 Cellular Phone
Keypad tones
just put your keypad tone on silent
Sep 19, 2008 | Samsung J700 Cellular Phone
Ring tone
For Mac users, this is surprisingly simple using Garage Band (part of the iLife product line).
Simply take your source audio material (no more than 30 seconds in length), and plunk it into a new project in Garage Band.
Then, go to "Share" > "Send Ringtone to iTunes"
When this is complete, simply connect your iPhone, go into iTunes and from the "Ringtones" tab under your device enable the new ringtone.
Do a sync.
Finally, go into iPhone settings and choose your new ringtone from the sounds menu.
Jun 06, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
170 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
David
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
