Question about Canon PC170 Copier
I'm getting a 'paper jam' indicator light on my Canon PC 720 copier. I have taken the copier apart numerous times and can find no paper anywhere. Is there another reason why this indicator may light?
    President:
  • 3,085 Answers
Yes, if one of the switches in the paper path is trapped in the down position.
Posted on Dec 12, 2009
The copier says rec paper jam slide left platen? what do i do ?
On the slide there is a handle. This releases the top reader port of the copier, move it to the left. Raise right side cover and remove the drum cartridge unit. You should see the jammed paper there, at the right lower access door, or in the fuser where the paper should come out. Just reverse the procedure to reset the jam. If the copier still indicates the jam then it must be in the fuser. You will have to have a technician remove the fuser assembly from the copier and take apart the unit to remove the jam. Hope this helps.
Jun 12, 2011 | Canon PC-1060 Black and White Copier
I have a canon ir2200 that is saying paper jam on front left. I can find no paper jam anywhere and have checked to see that the dials on the paper trays are set correctly. Also I have turned copier on and...
I am Sunil choudhary resident in Junnardeo dist. Chhindwara, My machine canon ir 2200 b&w machine -Miner problem paper jam-some move paper & right side jam paper & jam indicator show
Jan 11, 2010 | Canon imageRUNNER 2200
Shows paper Jam on Canon 720 PC photo copier
Sounds funny but this model shows a jam when the exposure lite goes bad. Turn on the copier and watch the exposure lamp, should lite up and not flicker. Lamp is still available.
Nov 16, 2009 | Office Equipment & Supplies
Canon PC 941 copier. Paper jam indicated with no paper.
Can be that sensor of the passing of the paper or was broken off flag, or sensor has wedged in position james, more often such can be in block of the fastening, when paper stuck extract. Try its see, this possible behind do. Good luck
Sep 04, 2009 | Office Equipment & Supplies
False Paper Jam Signal Canon MF5730
Try changing the quality of your paper.
Roughen up the rollere guides a little to you get better grip. Clean rollers with alcohol and use a green scrub mit to lightly rub the surface of the guide reels.
Hope that helps yours work too
Please rate our help to keep service online
Aug 19, 2009 | Canon imageCLASS MF5730 All-In-One Laser...
Error, paper output slot
That means the sensor flag under the platen roller is broken, bent, or jammed in the up position. Hard to see and must be taken apart to repair.
Aug 07, 2009 | Canon PIXMA MP610 InkJet Printer
Jamming canon 795
Check the sensors(photointerrupter) & toggle hanging up
Nov 20, 2008 | Canon NP 6050 Copier
Error message
hi silv
just seen this post , if still getting trouble with the printer you can try here - PIXMA MP500 -
type in the ? for results.
riz.
Apr 26, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon PC170 Copier Logo
173 people viewed this question
old marine
old marine
