Question about TurboChef TORNADO Electric Oven
I have a turbochef tornado and the panel wont light up at all, or oven start. when i turn the power on, all i can hear is a very faint mmmmm or whirr for a second then nothing, and nothing comes up on the front panel, its just blank
    Scholar:
  • 75 Answers
You may need to change the I/O board usually around 420 to replace. once you take the top and right cover off look at the I/O board the connector at the bottom is for the keypad sometimes this comes loose and can cause the keypad to not work correctly.
enter test mode
when the oven is off press back and enter at the same time then type in pin 9428 then press enter
select self test and follow on screen directions
hopefully this will give you some insight as to what is wrong
if you have any problems entering test mode and you have checked the connector and the bottom of the I/O board just replace the I/O board
Posted on Jan 28, 2010
Turbochef Tornado EC cooling fan ALWAYS runs at full speed
What jim said is right. plus clean the front vent. take off bottom front panel and clean all the little round holes. also if its dirty inside everything runs hotter(which makes the EC get warm faster) and dirt gets on the little wire(it's about 4" long coming from the main 40 pin connector0 that monitors the EC temp(clean it). sometimes the fan starts to get weak and doesn't cool properly. also, unplug oven, take side panel off and clean it as well. there are vents on it that get clogged. while it's unplugged clean the inside. I use a paint brush and shop van. just be careful not to hit wires or knock wires off. this will all help a bit but that fan will still run a lot anyway.
Apr 21, 2014 | TurboChef TORNADO Electric Oven
Turbochef tornado toaster wont get to menu, just warming up
The most common issue with this is a bad IR element. When the oven is cold remove the metal rack. you will see the IR element on the bottom. turn the oven on. wait 1 min. open the door and see if the bottom element is warm at all. If the bottom element is still cold then you have a bad element.
Feb 13, 2013 | TurboChef TORNADO Electric Oven
Turbochef tornado electric oven overheating and smoking one transformer is working fine but the new one is overheating
If transformer is looking burnt then replace it . It will show you F3 code once the transformer is. Totally burn. Tell me if you need help . I am tech for turbochef
Oct 14, 2011 | TurboChef TORNADO Electric Oven
I have tornado electric oven.My blower motor is keep making noise(seems that it is getting more power to run).I checked motor resistance and its okay.Any suggetions
Until the oven receives cook commands, it will continue to cycle until you give it a command.
Turn it from idle mode to off mode. Should be in your user manual page 11...
http://www.turbochef.com/filemanager/23/Tornado_Owners_Manual_NA_EU_NGC1006_G.pdf
FixYa Support
Aug 23, 2011 | TurboChef TORNADO Electric Oven
My turbochef oven display wont turn on. i just replace the solid state relay
HI,
you said it won't turn on.Is that mean its not warming up or its totally off.
please reply me with questions.
I will be happy to assist you.
thanks
Mar 15, 2011 | TurboChef TORNADO Electric Oven
How Can i change Motor in TurboChef Tornado
Its an easy fix although expencive for the parts. Just remove the rear blower cover then the six 1/4" nuts and it will come out.
Jul 12, 2010 | TurboChef TORNADO Electric Oven
F3 MAG Error
open the right side panel and change 3rd fuse from the left
Oct 18, 2008 | TurboChef TORNADO Electric Oven
TurboChef Tornado Door Open?!
check the door switch... also you can try a hard reset ( unplug power) ( if hardwired in you will need to trip the breaker) hope it helps
Jul 13, 2008 | TurboChef TORNADO Electric Oven
TurboChef TORNADO Electric Oven Logo
189 people viewed this question
Top TurboChef Ovens Experts
Dennis Boxerman
Craig Butler
Craig Butler
Are you a TurboChef Oven Expert? Answer questions, earn points and help others
