I have an Intertherm EP1500 portable heater. It's 7 foot long exactly, 120 Volt, 1500 watt. Intertherm was bought out by Cadet and this model equates to the Cadet model EPA 1500. I need to find what I believe is a thermostat connected to the heating element, but some are referring to it as a limit. It's black, round plastic, a bit smaller than a dime and has two wires going into it. It's physically broken. I'm hoping to find a replacement as this things virtually indestructible minus this part. Let me know if you need more info or a picture uploaded somewhere, I'd be happy to do that. Really appreciate your time:)
  • 288 Answers
I would take this part out and take it to a local mechanical supply house in your area. The service people are very knowledable about heating and a/c parts and they can physically look at the part to see if they have it in stock or if they can order it. good luck
Posted on Dec 12, 2009
Fan works but no heat
look to see if the safety fuse is open you can do that by using a continuity test on the heating element.
Feb 12, 2015 | Cadet EnergyPlus 1600 watt 120/240 Volt...
How can you get the amp size for a product when they dont list it for example I have a heater it runs on a 120 v and goes to 1000 to 1500 watts so how do I get the amp size?
One watt is the rate at which work is done when one amp of current flows through one volt of electric potential difference. Thus, to find the amps, divide the watts by the volts. In your example, 1500 watts divided by 120 volts gives 12.5 amps.
Sep 07, 2013 | Office Equipment & Supplies
Intertherm baseboard heater model 1580. Need thermostat
Home Depot carries I believe 2 different T-stats , wall mount, and unit mount. Try there. Or you will need to get it touch with the manufacturer. Also have info, 120 or 240 volt.
Mar 06, 2011 | QMark Portable Hydronic Electric Baseboard...
I just need a wiring diagram---with a thermostat-- for a cadet FX-152 , 240 volt ,1500 watt wall heater
grainger has them- home depot. wire is easy wire one side straight to 1 wire on in coming power the other side use your thermostat to break curcit ie wire into stat out of stat to voltage
Jan 15, 2010 | Cadet Manufacturing CADET SL Series Small...
Wattage for Kirby Sentria G10D
The conversion of Amps to Watts is governed by the equation
Watts = Amps x Volts
For example 1 amp @ 110 volts = 110 watts
your case 7 amp @ 120 volts = 840 watts
unless you are running it at 230v but I don't think you can
I would look for one rated for Volt-Amps instead of watts
It's best to round up to be safe add 40 - 60 watts
Don
Apr 25, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Marley B2451 wall heater
These are only 1500 watt heaters.
They 'could' heat a 20 x 20 foot room (with good, tight construction), with a slow temperture rise.
Check the company web site at http://www.qmarkmeh.com/
Doug
Jan 22, 2009 | Marley Electric Hydronic Baseboard Heater,...
Plinthe chauffante baseboard heaters
take a close look at the tubular element with a magnifying glass. the volts value should be stamped into the element. most baseboard heaters are 240 volt at low, high and medium density. wattage could be from 750 to 1500 watts
Jan 09, 2008 | Fahrenheat Electric Convector Baseboard...
Heating & Cooling Logo
197 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
