Question about Nortel T7316E 2-Line Corded Phone
How do you get a t7316e phone to ring
How do you change the setting to get a t7316e phone to ring?
    President:
  • Nortel Master
  • 860 Answers
ProgrammingHow do you get a t7316e phone to ring - 2_bing.gif is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt,
press the show key (top right arrow).
The display should now ask for an extension number. Enter extension number you wish to program ringing on.
Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear only
press the Chng key till it says appear & ring
press next key (lower right arrow)
The display should say line 002: appear only
repeat the procedure the same as line 001 for the remaining ringing lines
press the release key when finished
Posted on Dec 12, 2009
  • 1 more comment
  • jenkingequip Jul 22, 2011
    I am good until the bottom of the directions. Instead of my display saying line 001: appear & Ring my phone ready line 001: BlocA, and there is no "Change" option. How can I get my phone to ring and answer the line when the handset is picked up??
  • RefCoach Sep 20, 2013
    I had to you the System Coordinator Plus PW, 727587, instead of the 266344 PW to get to the line access and line assignment area.
    USE, not you. :)
3 Suggested Answers
SOURCE: How to change time on my T7316E Nortel phone
Step 1
Press the FEATURE key followed by **8463
Password Retry Step 2
Press 266344 on the dial pad buttons to enter the DEFAULT password. Your password MAY BE DIFFERENT! The display will show the following options:
Hour: 01 Next Change Step 3
Select CHANGE - the display will show the following options:
Hour: __ Cancl Step 4
Use the dial pad buttons to enter the hour. You must use two digits for all hours (i.e. "08" for 8 o'clock). You will be prompted to enter AM or PM. Select CHANGE and OK to choose PM. AM OK Change Step 5
After you have entered the hours, select NEXT. The display will show minutes as 00. Use the dial pad buttons to enter the minutes. If you are just changing the time, press the RELEASE (RLS) button to end your session. The time will be changed and the date will remain the same.
If you want to change the date, select NEXT.
Minutes: 00 Next Change Step 6
The display will show 99 as the year. Using two digits, enter the year using the dial pad buttons (i.e. "05" for 2005).
Select NEXT, and repeat to change the month and the day.
Year: 99 Next Change Step 7
Once you have entered the day, press the RELEASE (RLS) key to end your session. This will save the changed time and date.
Posted on Mar 12, 2009
  • 11 Answers
SOURCE: I have a T7316e phone set. How do I turn on/off
This would have to be done in system programming. Usually by to vendor that installed the system
Posted on Jun 27, 2009
How to I turn the universal volume on a Norton Networks T7316E Phone?
Have you tried to call the phone and adjust the volume on the set while the call is coming in? I think the only way you can adjust the ringer volume is if the phone is ringing.
Jun 25, 2015 | Nortel Networks T7316E Telephone Platinum...
When I put my t7316E on "night" it only rings half ring then sends call to answer machine, Any way to change to a few rings so I can answer it if needed
That is generally how Night mode works - alerting you to a call then directing the caller to voicmail night message. You want to change the Forward No Answer setting in that mode; if your system doesn't support that, set FNA in regular (non-Night) for the attendant phone.
Oct 09, 2014 | Nortel T7316E 2-Line Corded Phone
T7316E - Phones just installed. None of them ring.
You need to ensure that the main bell is programmed to ring, also that the extensions are also programmed to ring as well. Also check that the ringer is switched on, on the base of the telephones. Also ensure your handsets to not go over the ren value permitted. Make sure the service is on the correct day service and not night service. Check that the handsets ring internally and ensure they are registered with the system. Ensure that the connections and wiring are also correct,
Mar 15, 2013 | NorStar T7316E Telephone
How do you turn the ringer back on a T7316E Nortel phone? We have several phones that do not ring, we need the feature code to hear the ringing
MANY TIME A PERSON DIALS WITHOUT REALIZING THAT THE ACCEPTANCE CODE NEEDS TO BE INSERTED FIRST THE Nortel T7316E?...If you want to temporarily turn them off use do not disturb (feature 85, feature #85 to turn Do Not Distrub off) Turning off the ringing permanently will require you to program the set. Programming is done on M7310, ...regards John
Mar 14, 2011 | NorStar T7316E Corded Phone
How do I change the ringtone (incoming call) on the phone set?
You can change the incomming ringing for your set by pressing feature *6 , press the next key to select the ring type and ok to store the new ring tone.
Feb 22, 2010 | NorStar T7316E Corded Phone
Jun 26, 2009 | NorStar T7316E Corded Phone
Using the T7316E in an onair studio want to have external mute
You can use Do Not Disturb feature
Feature 85 - On
Feature #85 - Off
Cheers
Jun 17, 2009 | NorStar T7316E Corded Phone
My phone won't quit ringing
Keep looking under Terminals and Sets for your extensions. Lines either Appear or Appear and Ring.
Carl
May 12, 2009 | Nortel T7316E 2-Line Corded Phone
NorStar T7316E Corded Phone - voicemail / ring time
Go to programming of Norstar which will be F**266344 password will be 266344.
Dispaly shows u terminal and extensions.
press show
then next display will show u capabilities.
Press show then next display will show u FWD no answer.press show then next.and change the ringing as per ur requirement.
Feb 23, 2009 | NorStar T7316E Corded Phone
Programing my nortel t7316e charcoal to access whole phone lines
If you are fmailiar with the programming of the system, you must set the lines (3-8) to appear and ring on the extensions.
Assuming you have a later release MICS or CICS:
Press Feature ** 266344, then the installer password.
Press Show at Terminals and Sets, enter ext #.
Press Show until you are asked for the line number, then scan through the line appearances, and change to "Appear Only" on the lines you don't want to ring at that set.
Repeat for each extension you want to change.
DO NOT DO THIS UNLESS YOU ARE FAMILIAR WITH PROGRAMMING.....
Nov 11, 2008 | NorStar T7316E Corded Phone
Nortel T7316E 2-Line Corded Phone Logo
1,534 people viewed this question
Top Nortel Lands Phones Experts
David Burbee
David Burbee
Oloyede Monsuru
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
