Question about Kenmore 22642 Top Load Washer
The top door is not working.the washer can wash but no spin and the water don't go
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
Posted on Dec 12, 2009
Hot water stops filling too soon.
Fill setting has to be adjusted and the belt is slipping on the spin cycle and not generating enough centrifugal force to get the water out.
Aug 25, 2017 | Kenmore 22422 Top Load Washer
Washer fills with water but then will not cycle through after filling tub
I looked up yur model. It is a fine washer. Your lid switch on this model don't allow for wsh or spin if the the lid is ope. Older models would let the washer wash but not spin. This switch here won't allow for wash or spin. How it works
My page on these
Note: this washer is a newer model and I have yet to come across one. I believe your problem to be the lid switch. It has 3 wires. 2 hot ones and another one attached to the frame. Jump them 2 live wires and see if she runs. If it works get a new switch and party on!
I am TheMobilian.
Let me know what ya find out, I am here to help.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 21, 2011 | Whirlpool LSR5132PQ Top Load Washer
My estate washing machine will not spin out, all of the other cycles work correctly.
Hello
Try to clean the magnetic door switch,some windex and a paper towell.Just do the part on the door or lid and where the lid meets the top of the magnet.Make sure this is not loose and is seated in the machine.
You may need to unplug machine and remove the door switch,take both wires and tie them togther so they make contact.Then try a wash cycle or try the spin cycle.
The door switches in the estate washers fall apart and get corroded and can stop the spin cycle.
If the machine works with the switch taken out then you will need to get a new one from whirlpool.
Mar 25, 2011 | Estate Washing Machines
Frigidaire MWX233RES4, Washer drains but does not spin
If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Jan 14, 2011 | Frigidaire FWS933F Top Load Washer
MY WASHER IS NOT DOING THE SPIN CICLE, DRAINS ALL THE WATER OK, PUMP IS FINE, JUST DOES NOT SPIN
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 06, 2010 | LG WFT1071TP Top Load Washer
Maytag washer, model: LAT8415AAE top loader. Washer fills with water but will not start agitating,spin or drain.
Check lid switch. Most will not run with lid open and the switch may not be pressed down when door is closed
May 17, 2009 | Washing Machines
Will not spin Maytag PAV2300AWW top loader
check your door switch. Many times a faulty door switch can prevent the spin cycle. When you locate the door switch, take a jumper wire across the connection and advance the timer to spin. If it spins with the jumper wire, you will need a new door switch.
Jul 04, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Kenmore washer - water is emptying from tub but clothes are not spinning dry
replace door switch.If the computer thinks the door is open, it will not fast spin as a safety precaution.
Feb 27, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 22642 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
