Question about Sony Televison & Video
Ke-42m1 sony flat panel tv ,upper and lower y-buffer boards
I just replaced the lower buffer and i am trying to figure what the two heavy gauge wire that soldered to the upper y- buffer does. the tv works fine without these wires attached. the new replacement board has only two tiny pins that needs a tiny plug or connector to go somewhere assuming its the upper buffer ,where the heavy gauge wire is ? i am assuming this connection balances the load between the two boards ? i know there not feed or ground or data connections. thanks gary.
  • leafy_rats Dec 12, 2009
    YES,THANK YOU. GARY
    Genius:
  • 1,112 Answers
Hello Gary:
You have received an updated buffer assembly, This Buffer board is a sony updated for the model Ke-42m2 series of Plasmas. Sony no longer make plasma televisions anymore. But this board will work in your model just as well. the Two gauge wires were used for load inpedance, sort of a resistance between the two, the new Y-Substain for model ke-42m2 does not have these wires but instead uses a new plug for these wires.
You set will work just fine without these wires, I would just Wrap them up and secure them to them with tape to the PDP Panel.
Posted on Dec 12, 2009
Why my Sony TV KE 42M1 takes a long time for the image to show. and when it does it takes a long time to produce a good quality picture?
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Aug 31, 2014 | Televison & Video
Have bad lower y buffer should I replace main board also
Lower and upper buffers should be replaced together. No need to replace the main board.
Sep 20, 2012 | Hitachi 55HDS69 55 in. Plasma Television
Sony wega KE-42M1 .power lead ok . no power at tv. (no standby or power light showing at on switch). house power went off , when it came on tv wouldn't work
This confirms that the main power supply which is the SMPS is faulty.
The fuse could have failed and must be checked, if the fuse fails the SMPS is confirmed to be faulty due to the power outage.
please check the links below for tips and support:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
http://en.wikipedia.org/wiki/Switched-mode_power_supply
Sep 21, 2011 | Sony WEGA KE-42M1 42 in. HD-Ready Plasma...
Thin white horizontal lines!!! I've had my WEGA KE-42M1 for 5 years with no problems until about three months ago. After about an hour being on, there are thin white horizontal lines that move randomly...
Sounds like your TV is giving out, plain and simple.
If this doesn't sound right, then only one thing comes to mind. Have you moved the TV recently? Are you using a different coax cable, (if using cable that is). If so, just change the cable back to the previous one and you should be fine.
Aug 21, 2010 | Sony WEGA KE-42M1 42 in. HD-Ready Plasma...
LG Tv 50PQ30 the lower half of the screen intermittely stops working
looking into the back of the tv with the cover removed, there is 2 boards on the far left the run down the back of the screen. These are the Ysus buffer boards.They both plug into a larger board (Ysus). Make sure that the bottom buffer board is pushed into the Ysus properly and that the wired lead connecting the upper buffer board to the lower buffer board is pushed in firmly.If this doesnt solve the problem then you will most probably have a faulty lower buffer board.
Feb 20, 2010 | SNK Magnavox 42MF231D 42 in. Plasma TV
Sony WEGA KE-42M1 sound but no picture.
i have the same problem! did you ever solve the issuE??
Oct 16, 2009 | Sony WEGA KE-42M1 42 in. HD-Ready Plasma...
Sony WEGA KE-37XS910
This TV has a very expensive panel... we are talking $3000 core charge alone! It comes complete with all the lower buffer boards (which from the sound of it, you are having a problem with). Individual boards for this defect are not available on repair parts list I know of. A panel is what you need, PN: 9-885-063-33
Aug 17, 2008 | Sony WEGA KE-37XS910 37 in. HD-Ready...
No picture-Sony
did you ever get your tv repaired?
Apr 29, 2008 | Sony WEGA KE-42M1 42 in. HD-Ready Plasma...
Televison & Video Logo
46 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
