Question about Epson Stylus Pro 4800 InkJet Printer
Error 0001001D It's the weekend & no tech support till M_F :( New printer Green tabs pulled out & still error message. On line it says t-Bar might have come out of encoder strip or might be dirty. Where is the T-bar located & access to encoder strip so I can see if the problem is there? Help Please I'm dead in the water needing to out put films. Bayouloupgaru
  • loupgaru Jan 20, 2008
    New printer
    Green tab is pulled out & still error message. On line it says t-Bar
    is there?
    Also any suggestions on what the prob might be?
    Help Please ! I'm dead in the water needing to out put films.
    loupgaru
  • Anonymous Jan 27, 2009
    Ihave the same problem,cant get no answers from epson,once they have sold you a product your on your own.they dont want to no.I have emaild them and looked on there site for help,there is none.Error code 0001001D is a carriage servo parameter error it says on the screen,so whats one of them?is anybody any wiser?I have looked in the field repair guide and still am not sure so i recon am going to take the thing to bits with the field guide,It should be fun,cant think of anything else can you?and I may come across the problem buy accident or luck,we will see.wish me luck.Bill.
  • 33 Answers
Are you still having problems?
Posted on Apr 18, 2008
Toshiba 353
you have to tell the copier you've changed the toner, OR you didnt pull the tab on the cartridge a small white waxy paper tab with an arrow on it hope Ive helped Tosh Tech 23 yrs SC
Aug 26, 2014 | Toshiba e-Studio 350 Copier
Docuprint C3290FS error code 0e
At this point I haven't had a chance to remove the lament flooring. I'm planning on removing it this morning so I can pull the dishwasher out and take a better look at the drain line. I didn't think it made any sense that it would drain well is the line was low but wouldn't if I raised the line. I was thinking the pump might be putting out low pressure but I wasn't sure how to determine if that was the case.
for more help visit CBR Tech Solutions
Jan 30, 2012 | Xerox DocuPrint C3290 Printer
Printer keeps saying to clean the corona wire. I cleaned it several times but the message keeps popping up.
To clean the corona wire in the brother laser printer, it said to remove the drum/toner assembly from the printer. This is very easy to do, you simply pull down the front of the printer, and press a small green tab down and pull. Then the toner and drum assembly will quickly come out.
After that, it says you must clean the corona wire by moving a small green square back and forth several times. It seemed kind of strange to me, but I did it anyways. In the upper right corner of the drum/toner assembly, there is a small green/blue square that can be moved back and forth. I did this several times.
I then placed the unit inside, and the error message went away for a minute. However it still wouldn't print and the error message came right back up. I was a bit frustrated since I have only owned this printer for about 2-3 months.
But then I realized something: The toner button had been blinking for about a month. I had already purchased a high yield black toner cartridge for the brother laser printer (Tn-330/TN360). I purchased it online, and had it stored for when I eventually ran out of toner.
I thought perhaps the error message had something to do with the old toner. Maybe it was out?? So I once again opened the front of the laser printer, and removed the toner/drum assembly. I pressed a green tab, removed the old toner, and then added the brand new high yield black laser toner cartridge. The whole process was very simple (you gotta love today's technology).
I then quickly "cleaned the corona wire" a few times again just to be safe. I re-installed the toner, and the printer was up and running. So apparently it will throw this error when you are out of toner. Now the printer is running great again, and I really like this printer.
If you are still using an ink jet printer, then you are living in the stone age. I was reluctant to buy a new laser printer, but now I love it. The toner only costs $30-60 and lasts for months. I print hundreds of labels out each month-just to give you an idea of how long it lasts.or get more information Call +877 889 6859 for detail.
Jan 04, 2011 | Brother HL-4040CN Laser Printer
Error code 010-397 dell printer 5100. Have change fuser and restart printer keeps coming up as error message
) The fuser gets very Hot!! Let cool for 10 minutes after turning off the power and unplugging the copier!
2) Pull the two blue locking tabs forward and remove the fuser unit. Reinsert and push back on the tabs to lock back into place. Sometimes just reinserting the fuser will allow the catch on the locking tab to function correctly and push the trigger on the sensing unit. Turn the copier back on and pray the error code doesn't reappear..
3) Mine reappeared. Evidently the catch on the fuser unit was still not pushing the trigger forward, causing the copier to surmise that no fuser unit was installed.
CBR Tech Solutions or http://www.cbrtechsolutions.com
Oct 14, 2009 | Dell 5100cn Laser Printer
Brother 4070 CDW Drum Unit Error
The green tabs that you have to slide are under the color cartridges, so remove the three color cartridges and you will see three green tabs, to slide the tab across the wire you have to first open the translucent plastic wire cover, then slide the green tab across the wires and return it to it's original position, close the wire covers, replace the color cartridges, and reassemble the printer. All the Best
Jun 11, 2009 | Brother HL-4070CDW Printer
No function on my printer is working
E-511 error message is related to the Photoconductor Unit. In order to resolve your issue, there 3 things that I'd like to suggest.
1. Take out the Photoconductor Unit and turn it upside down check if the white tabs restract. If it doesn't you need to replace the PCU otherwise just put it back in
2. If reseating the PCU doesn't resolve your issue, try a different PCU
3. Lastly, warranty options if your product is within the 1-year warranty from the date it was purchase contact Epson Tech support they'll be more than happy to send an onsite tech support to fix it otherwise visit their website support.epson.com and look for a repair center in your area
Jun 18, 2008 | Epson ACULASER CX11NF All-In-One Printer
Trying to scan and I get message saying to change display setting to 800x600. How do I do this?
Right click on your desktop, go to properties. On display property click on settings then change the screen resolution to 800x600. hope that help get back to me if that error persist.
Apr 19, 2008 | Office Equipment & Supplies
How to change the drum on 2300 DL
Turn off printer.
Open side door, remove waste toner box.
Lift blue bar (in direction of arrow) to release drum assembly.
Grip tab as shown in small image, press and pull drum assembly out of its slot.
Take NEW drum and slide back into its slot, pressing it into place over the metal guide pin.
Pull yellow tab to remove protective film from drum (discard this).
Lower blue bar to engage drum.
Replace waste toner box, close side door, turn printer back on and let it cycle to start.
That should be all there is to it.
Feb 11, 2008 | Konica Minolta magicolor 2300DL Laser...
Carrier jam Lexmark 4300
I had this same problem, I found a long skinny thin plastic strip had fallen off & caused the problem for me. The plastic strip has slits at each side to attach to the inside back of printer, on the left side is a down ward facing arrow, the plastic strip feeds through the back middle of the cartridge carrier and then the slits are to be inserted to the metal tab like pieces on the back sides inside the printer on the right side (facing printer) it will look like a small rectangular hole with a longer metal tab like piece sticking out & on the left is a smaller squared like hole with a flat smaller metal like tab which will line up if the plastic strip is feed through the back of the cartridge carrier properly. This should allow the cartridge carrier to glide properly & work as it should, with no more banging! Sorry my tech. terminology isn't good, I am not Knowelegable with this sort of thing, just sharing my experience :) HTH!
Jan 14, 2008 | Lexmark P4350 All-In-One InkJet Printer
Error message
OK guys quite a simple one....
with the printer on press & hold both the small red button ( far right ) and the green, colour copy button. Whilst still holding press the power button wait till the unit powers off. Press the power button again, shortly after the unit powers on, the lights flash, let go of the two buttons your holding. The screen shoul dnow say "Init EEPROM" if it doesn't repeat procedure till it does. Now press the green colour copy button once, screen should now say "Push power sw" Press and hold the power button, the unit will power off and on again, now release the power button and your printer should be working again. Now you should change your waste pads......
Dec 05, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Epson Stylus Pro 4800 InkJet Printer Logo
1,281 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
