Question about GE Spacemaker JVM1640SJ Microwave Oven
I have a GE SpacemakerXL Microwave Oven model#JVM1339BW. It is about 12 yrs.old. Everything on the microwave works lights,panel,timer,clock,etc. but when you try and heat something the lights are on and the timer counts down. The turn table doesn't turn, it doesn't heat and is quite,no sound. Can you tell what may be wrong and if it is worth calling a repair person to fix it, verses buying a new one? Thanks.
  • GE Master
  • 8,404 Answers
Check the door safety interlock switches.
Thanks for using FixYa.com
Posted on Dec 11, 2009
Solution-GE spacemakerXL microwave oven model:JVM16505H01 mfg.date:feb.2005
Sounds like you have a bad smart board, you can try unplugging the unit for five minutes and then back in, if you are lucky this may correct the problem...good luck
Feb 18, 2014 | GE Microwave Ovens
I have a GE SpacemakerXL model JVM1350BW. It does does heat uo. The interior light, surface light,fan,clock,timer all work normallly. When I hit start, the time starts going down but the ovn does not turn...
Sound like a magnetron go to bad; here are the steps we took to replace it
Warning: You are not an electrician or repairman, following steps are from my experience. You should be careful while handling capacitor and other parts.
Unplug Microwave at least few hours before
Remove Microwave from above oven range by somebody holding Microwave from ground unscrew the screws from cabinet
Remove top cover of Microwave
Make sure to keep screws correctly in a place you remember what goes where
Make sure capacitor is discharged, GE manual inside Microwave says capacitor will discharge within 30 seconds once it is off. As a precaution check the voltage in capacitor to make sure there is no electricity
Remove other panels around magnetron part
You need to remove lot of connecting wires, should be careful to note down what goes where
If possible take digital photos to refer back when you put everything back together
You may need to remove transformer to easily remove and replace Magnetron. If you can't remove Magnetron easily then remove bottom panel of the Microwave and remove transformer
Now it should be easy to remove magnetron
Replace new magnetron and screw it. We had to put one outside part from old magnetron to new one because new one was missing that. Check to make sure both old and new one are exactly the same
Make sure put all wires properly back
Now put transformer back and screw it
Put capacitor panel in place and screw it
This might be a good time to test the Microwave to make sure it works fine now
Now cover the top panels and start to screw everything
Once everything assembled put the Microwave back above range put screws from top
Microwave Front and inside
Magnetron and transformer
Magnetron cover
Hope this helps (remember to rating this free answer).
Oct 10, 2011 | GE JVM1350BW/WW/AW/SY Microwave Oven
My microwave is not heating up food. Everything else still works, but it is louder than usual. Lights, timer, fan, etc all work, the food is just not getting hot. It is about 4 years old.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Dec 11, 2010 | GE XL1800 1100 Watts Microwave Oven
Everything works (clock, timer, inside light etc.) but not the fan, turntable and will not heat. It stopped while heating lasagne.
Basic
heatman101
Sep 25, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE SpacemakerXL Microwave oven clicking noise
Spacemaker t/t motors are very easy to change. Removed the screws from bottom of microwave. the bottom panel will found towards wall. Mtr is in very center of unit. Should have 2 wires going to it
Nov 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE SpacemakerXL, model #JVM1330BW 002, does everything but run
it could be a defective thermal fuse,h.v. cap,h.v. diode or the magnetron tube are defective
Oct 02, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE microwave oven
Does the turntable rotate? If everything but this works (except no heat), you probably have a bad door switch. Here's a discussion of what's involved in replacing it: http://www.fixya.com/support/t267796-kenmore_microwave_hood_combination_over
If the turntable does rotate, I'd suspect a more significant failure, such as the transformer, capacitor, or magnetron. If it's any of these, it's time to replace the unit.
Dec 10, 2007 | GE JVM1650 1000 Watts Microwave Oven
GE PRofile Spacemaker XL Microwave Oven Model# JVM1460 950 watts
Sounds like the problem is in the high voltage. Most common would be magnatron, capacitor and diode. For safety reasons this should be checked by a professional. Look in your owners manual because some high voltage parts have a longer warranty than 1 yr.
Oct 09, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
562 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
