Question about Sony Dual Shock 3 Controller for PlayStation 3
Won't vibrate Sixaxis Dualshock 3 controller Won't vibrate
  • 115 Answers
Yeah, that's one down side with the Sony Dual Shock 3 Controller. It does not provide vibration, sorry. I wish I could provide you with more information.
If I helped please rate me and create a testimonial on how well I did help.
Thanks,
Brandonmxb
Posted on Dec 11, 2009
  • Brandon
    Brandon Dec 11, 2009
    Thanks,
    Brandonmxb
  • m4gic May 12, 2011
    SIXAXIS does not provide vibration. DUALSHOCK 3 does. (Dualshock 3 also has SIXAXIS written on it, as it is also provides the motion sensors that the old SIXAXIS controllers did.)
    As for the actual problem: There's a setting in the PS3 to disable or enable wireless controller vibration.
    Go to Settings > Accessory Settings > Controller Vibration Function. Set it to ON.
    If it still doesn't vibrate, turn the controller over and press the reset button. Now resync the controller by plugging it into the PS3 with the USB cable, and pressing the PS button.
    If the controller STILL doesn't vibrate (and you're sure it's a Dualshock3 and not just a standard SIXAXIS) it may be malfunctioning. You'd likely have to buy a new controller.
    (Yes I realize this question is two years old. People still end up here from Google. I did.)
If i press the ps button on dualshock 3 controller all four lights on it are supposed to flash but it doesn't therefore the ps3 system cannot be turned on using it
Have you charged it? If you have plugged it in and no lights blink you may have a defective controller. If so check with Sony support/
Oct 05, 2012 | Sony Ps3 Sixaxis Wireless Dual Shock...
Turns on but no disc read or remote will not connexted
Can you give any information relating to the game you are trying to play? Do other games work? If your machine powers up and everything works accept the dvd drive the laser/drive maybe at fault. It maybe as simple as you need a new sixaxis dualshock 3 controller.
Mar 01, 2011 | Sony Playstation 3 (PS3) Console
Troubleshouting dualshock 3 sixaxis does not work brand new.I wired usb cable does not work too.I try two others controls not work too.I use wired control for another brand and it works.
Don't worry i will tell you a easy and efficient idea to fix this..... First download repair guide and go through it, it has many solutions......
Click here to download PS3 repair guide
Jan 03, 2011 | Sony Playstation 3 (PS3) Console
Dualshock sixaxis troubleshooting wired and wireless does not work PS3. I try to wired control from another brand not sony and works.How i know if the console is charging the controls?
while the controller is plugged into the system with USB cord try the reset button on the back of the controller (next to the center screw on top).
Jan 03, 2011 | Sony Dual Shock 3 Controller for...
Hi, the wireless controller, a sony dualshock 3 sixaxis, won't stop vibrating. Any solutions? thanks, Angela
If you've already removed the batteries and replaced them, then I think there is a small hole on the bottom you could stick a paper clip into an press a button to do a reset. You may have to re-sync the controller with the console after doing this. I don't have one of these, but I've heard of doing this before.
Sep 20, 2010 | Video Game Consoles & Games
My ps3 controller wont charge
Bosa, you're wrong. Had the same problem. The USB cable that comes with the PS3 won't charge the new Dualshock Sixaxis. I had to use a thicker, more robust cable in order to get the controller to start charging.
Apr 03, 2010 | Sony Dual Shock 3 Controller for...
PS3 Controller will only work when plugged into the USB
I picked up the folling troubleshooting tips from the PlayStation Knowledge Center. I know it may seem silly or insulting; This is not my intention. Problems like this are usually just little things you're over-looking. Give thest tips a shot, one by one, and see if your solution is in here. If it isn't, message me back here & we'll try something else to get your controller working, ok? By the way... Is it a sixaxis controller or dualshock?
  • Verify if the SIXAXIS or DUALSHOCK 3 wireless controller works with the USB cable.
  • Verify that the SIXAXIS or DUALSHOCK 3 wireless controller's battery is charged.
  • Attempt to pair the SIXAXIS or DUALSHOCK 3 wireless controller to another PLAYSTATION 3 system. This helps determine whether the problem is with the system or the controller.
  • Attempt to connect another SIXAXIS or DUALSHOCK 3 wireless controller to the PLAYSTATION 3.
  • Move closer to the PLAYSTATION 3 system. The maximum range for Bluetooth is 30 feet.
  • Make sure you have less than seven Bluetooth peripherals paired with the PLAYSTATION 3.
  • Unplug any other USB device plugged into the system when pairing the SIXAXIS or DUALSHOCK 3 wireless controller.
May 19, 2009 | Sony Playstation 3 (PS3) Console
Sixaxis controler won't vibrate
The SIXAXIS controller will not vibrate by design.
You must have a Dualshock 3 controller.
If your controller says dualshock 3 on it and it does not vibrate, you should see if you have any warranty support or if you can replace it.
May 04, 2009 | Video Game Consoles & Games
Sixaxis on ps2 ???
No, it's not possible to hook up sixaxis to PS2. Sixaxis is a part of DualShock 3 for PS3 which is an optional feature in the PS3 games. Playstation 2 controllers run off of DualShock 2. So sorry, but you're gonna need a PS3 for that.
Jan 29, 2009 | Sony PlayStation 2 (PS2) Console
Ps3 version 2.10
hello There..i think you might check your controllercoz there are 2 type of controller
1. Sixaxis Controller
2.Dualshock 3 Controller (vibration)
And Here The Latest Version For PS3 Firmware - (2.42)
Here You Go - file:///C:/Documents%20and%20Settings/WinXP/Desktop/PSP%20&%20NDS%20Files/2-PS3%20Folder/PS3%20Firmware/PS3%202.42/PS3/
Jul 31, 2008 | Video Game Consoles & Games
Sony Dual Shock 3 Controller for PlayStation 3 Logo
354 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
juanmireles1
David
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
