Question about Seagate Barracuda ST3250824A (ST3250824A20PK) 250 GB Hard Drive
Trying to find drivers for this device - Seagate Barracuda ST3250824A (ST3250824A20PK) 250 GB Hard Drive
  • 466 Answers
You do not need drivers for EIDE/SATA hard disks. They will be recognized automatically by all current OSes, Windows, Linux, *BSD and MacOS X.
If the unit is not recognized, it may be damaged or the configuration pins (usually near the data connector) may be set wrong, so that the drive is not recognized properly.
Posted on Dec 12, 2009
Thanks for your reply, but my problem is what to enter in the registration key area, to activate the driver whiz. I try numbers and letters but did not do it correct, and i need the driver for my...
If you know the model of your Bluetooth device then you can try to search the driver on the web, everything's on the web nowadays:)
By the way did you installed any driver when you first used your bluetooth device coz most bluetooth device is just plugged and play no need to install any driver, If you did not installed any driver when you first used it then that means that either there's something wrong with your bluetooth device or your pc is the one having a problem detecting the device. Try to use you bluetooth device to another computer to isolate the problem.
Feb 05, 2011 | Computers & Internet
Pls help - my sound card driver is not working properly when i ply files on winmap show a error massege- baddirect sound driver. please instal proper drivers or select another device in configuration....
You can try going into your sound driver and selecting properties. Try rolling back driver. If that doesn't work, go to device manager, select sound card, uninstall device, reboot computer and let windows reinstall the device. At that point windows should load its latest driver.
May 26, 2010 | Office Equipment & Supplies
After using Driver Genius my system audio device cannot be found. Everything I can check reports normal function except there is no audio device found.
You might have updated to an incompatible driver. Not all new drivers work on all devices. Realtek drivers for example often are incompatible with specific devices, where you need a driver from the PC manufacturer. The Realtek driver will install without problems though. Just no sound anymore after that.
Try rolling back you audio driver.
Here are some things you can try: http://www.pcauthorities.com/pc-errors/no-audio-device-in-windows
Mar 29, 2010 | Avanquest Driver Genius for PC...
No audio device driver for vista 54
Try to check the windows audio services in windows service, and make automatic, then try to check if not working then go to device manager and uninstall audio drivers and restart the computer and give some to to automatically install the driver then audi will work in case not working then refresh the driver from device manager and try to download and reinstall the windows audio driver then windows audio will work fine.
Mar 19, 2010 | Compaq Presario V2630US Notebook
Device manager is showing PCI Deice missing
Hi you should try the motherboard website for drivers. Usually drivers that come with Windows XP are generic.
Try going in to Device manager, Uninstall the driver and reinstalling the driver that you downloaded from motherboard vendor site.
Jul 18, 2009 | Microsoft Windows XP Professional
No audio device found
Download Driver Cleaner Pro v.15 from the link. Also, download, and save on your desktop, a clean version of your Sound Card drivers. Run DCPv1.5 and remove all of your audio drivers, plus any possible problem drivers (i.e., if you installed generic drivers to try and get your card to work). After you uninstall, reboot, install your downloaded drivers and reboot again. This should fix your problem, if not please post an update to this thread and I'll continue troubleshooting with you.
Mar 03, 2009 | Dell Inspiron 1525 Notebook
Driver/Firmware Problen on a Lite on CDRW
Here ya go straight off the Microsoft Knowledge Base. Geek Squad too lazy to research:
Code 41
Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41) Recommended resolution
This problem occurs if you install a driver for a non-Plug and Play device, but Windows cannot find the device. Here are some things that you can try to resolve this problem.
If the Troubleshooting Wizard does not resolve the problem, do one of the following:
  • If the device was removed, uninstall the driver, connect the device, and then click Scan for hardware changes to reinstall the driver.
  • If the hardware was not removed, the driver files might be obsolete. In this case, update the driver from Device Manager. In the device Properties dialog box, click the Driver tab, and then click Update Driver to start the Hardware Update Wizard. Follow the instructions to update the driver.
  • If the device is a non-Plug and Play device, you may have to install a newer version of the driver. To install non-Plug and Play devices, use the Add Hardware wizard. Click Start, and then click Run. In the Open box, type hdwwiz.cpl.
4 diamonds pls
Mar 01, 2009 | Gateway 510 X PC Desktop
Download USB 2.0 device drivers for windows 98s sport intel board
i cannot use my pen drive with my win98 please help me!!!!!!!!!!!
Nov 28, 2007 | Microsoft Windows 98 for PC
Seagate Barracuda ST3250824A (ST3250824A20PK) 250 GB Hard Drive Logo
98 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
