Question about Bosch Dishwashers
My countdount down light stays stuck at 1 and the sanitary cycle doese not engage
  • rafael9236 Jan 03, 2010
    i am game!
  • Mark Egan May 11, 2010
    This is a common problem for Bosch's. Chances are pretty good there will be a burned place in the controller board. If so, you can either 1) Buy a new controller board and expect to have the problem again, or 2) replace the relay associated with the burned spot with the correct relay for 1/10 the price and likely never have the problem again. Reply if you are willing to take the board out and do a little soldering.
Definitely the board problem. Does the new board fix the problem or will the same problem recur with the new board?
Posted on Jan 03, 2010
  • 126 Answers
Hi.This is a common problem with the Bosch.The heater relay on the control board is burnt out and need to be replaced.This is the electronic control behind the push buttons.cost about $130 for the part.Hope this helps.Please rate my response :)
Posted on Dec 13, 2009
Door locked with flashing red light on model W10578789
This might work try unplugging it for about 45 -60 seconds and see if it clears the problem. The red light is some type of warning and I would be safe in saying it is a safety device gone bad. Sorry I couldn't be of more help.
Col. Dana Gillespie
Aug 14, 2014 | Whirlpool Duet Steam WFW9550WL 27"...
Can't select wash cycles
Is the control board displaying any fault codes?
Try disconnecting the power cord to the washer from the wall outlet for 5 maybe 10 minutes...give the control board enough time to power down and hopefully the control board could self-correct itself by resetting. No different than re-booting a computer.
If you still run into the same problem, and if so equipped, try holding down the "end of cycle" signal button for 10 seconds and see if that resets it.
Dec 07, 2013 | Kenmore Washing Machines
Yamaha 350 big bear. what type of clutch does this have
Try turning down the tickover speed. These machines have a centrifugal clutch which engages at anything over tickover.There is no lever.
Sep 25, 2012 | Yamaha Motorcycles
I have a 2002 sunfire... and i have trouble turning it on. Once it startes it is stuck there because it will not turn at all. Once it is in this position the wipes wont work, the windows wont roll down,...
sounds like you need a new ignition, reason nothing works cause once it doese turn over n starts the car the tumbler is stick in the starting position jus not far enough to keep the starter engaged but far enough the it still trying to go trough the start process which cuts the power to everything else till the ignition returns to the on postion
did you try jus turning the ignition far enough to when the starter engages jus let go of it so the car doesnt start and see if everything else still doesnt work if it dont i belive its the igniton
also with out starting it or engaging the starter as in just turning the key on to get power does anything work?
Jul 12, 2012 | 2002 Pontiac Sunfire
How do I get rid of the black stuff in the door seal?
Use a bleach and water solution 50/50 and apply liberally. Place 1 cup of bleach in the washer tub, and fill all of the dispenser cups with bleach. Run the hottest wash-rinse cycle that you have; for us, it is the sanitary cycle. Follow that cycle with a normal cycle to flush out any residual bleach. Leave the door cracked open when the washer is not in use. The moisture that stays in the washer is one of the most common reasons for mold to begin growing in the washer. Allowing it to air dry helps keep it from happening.
Best regards, --W/D--
Jan 23, 2011 | Kenmore HE2 Plus Front Load Washer
Everything works but my speedometer stays at zero
What about odometer? doese is it change or it's stuck also?
Apr 06, 2010 | 2004 Suzuki GSX-R 750
Brake pad wear warning light on after new pads fitted without pad wear sensors
why doese the pad wear sensor light stay on after fitting new pads and sensor
Jun 06, 2009 | 1998 Volkswagen Golf
Washer will not reset
Depress "end of cycle" button for 3 seconds & wait for 2 minutes to try the door gently.
Mar 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Control locked
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Jul 19, 2008 | KitchenAid KHWS02R Front Load Washer
Dishwashers Logo
154 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
