Question about Whirlpool GU2400XTP Built-in Dishwasher
How to install diswasher
I NEED TO INSTALL A DISHWASHER AND DO NOT HAVE ONE IN MY KITCHEN, I HAVE TAKEN OUT A CABNIT AND HAVE A 24IN BY 34.5 IN HOLE. WHAT I WOULD LIKE TO KNOW IS HOW THE PLUMBING HOOKS UP TO SINK WATER AND DRAIN LINES
    Sniper:
  • 68 Answers
To get the water to the dishwasher, it depends on your plumbing setup. If you have shutoffs under your sink(1/2" X 3/8" compression angle stop), you will need to buy a 1/2" x 3/8" compression double stop. This will be easy to change.
#1 Drill a 1 1/2" hole in the back bottom of the cabinet to run your water, drain line, and power cord through.
#2 First turn off the water at the Hot Water Tank, or the House supply, and turn on the sink to relieve the pressure.
#3 Next remove the Hot supply stop, and install the double stop.( The nut and ferrul do not have to be removed, as they will attach to the double stop. Reinstall the hot supply to the sink to one of the connections on the double stop.
#4 Install a 3/8" x 3/8" x 48" braided flex with the 1/2" MIP
x 3/8" compression ell at the dishwasher.
#5 Install the drain hose supplied with your dishwasher at the bottom of the dishwasher.
#6 Install a 6' pigtail power cord to the power box under your dishwasher.
#7 Feed the drain line, power cord and water supply through the hole in the back of the cabinet at the bottom. As you push the dishwasher back into the enclosure, you will need to feed the 3 lines into the cabinet under the sink.
#8 Attach the water line to the open connection on the double stop.
#9 The drain line will attach to your garbage disposal.(If you have one) Be sure to knock the small piece of plastic out of the drain connection, and retrieve it out of the disposal, before connecting the dishwasher drain line.
#11 Raise the middle of the drain line as high as possible under the cabinet under the sink, preferably attach it to a screw to the bottom of the counter top. This will keep the dishwasher from drawing a back siphonage and getting a bad odor.
#12 Plug in the dishwasher. Assuming you have electrical under your sink. Otherwise an electrical outlet may need to be installed.
#13 Balance the dishwasher using the front legs. After you adjust the depth of the dishwasher, and the level. Use the 2 mounting screws included with the dishwasher to fasten the 2 clips above the door to the bottom of the counter top.
#14 Remove the installation manual and styrofoam from the tray, and turn the dishwasher on. Inspect for leaks as you run a cycle.
#15 Attach the bottom kick panels
You are done.
If you have any questions, please let me know.
Posted on Jul 29, 2008
  • 640 Answers
Depending on your exsisting plumbing you will probably have to cut the hot water line and install a tee.you then run a metal braided hose to the water input valve at the dishwasher.the standard tee/hose to use is 3/8 inch or 1/2 inch,i would go with the 1/2 inch.as for the drain you can do 2 things---connect a tee at the down pipe of the sink drain,the tee should match the original plumbing but the outlet where youll connect the dishwasher drain hose should be 3/4 inch.if you dont want to go that route you can simply drill a 3/4 hole into your exsisting drain plumbing and screw in a 3/4 inch by1 1/2 nipple then connect the drain hose with a clamp.if you decide to drill make sure the drain pipe is strong enough or it will just fall apart.use a 3/4 inch high temp hose for the drain.i belive home depot/lowes sell dishwasher installation kits.if you have to cut the plumbing (which you probably will) and dont know how to sweat/solder you can buy compression tee's and they work just as well.the drain you wont need to sweat or solder.let me know.
Posted on Jan 20, 2008
    President:
  • 949 Answers
Its probably in by now, but to answer the question. You need a tail
pipe that has the dishwasher port on it,or if you have a garbage disposal, they have a port to connect it,most of them. It is better
if there a water line under the unit in basement where you can put a shut off and connect it to the washer, hot water line. Or you can
install copper t under sink and install shutoff w/3/8 output for washer.
There is also a sharkbite that you can add, you need a t, then get a compression 3/8 shutoff, this way there is no sweating involved, you only have to cut copper pipe, install shark T, then put compression shutoff onto a 8in piece of 1/2 copper,push it into
shark, and now your set.
Posted on Mar 26, 2009
  • 3 Answers
You can take a branch(15mm) from the hot and cold connections to your kitchen taps. Then attatch a quarter turn valve on to each branch. As simple as that
Posted on Feb 17, 2009
What are the dimensions on a Kenmore 363.14192992 dishwasher?
Dishwashers that are installed into standard kitchen cabinets have a standard width and depth of 60 cm (Europe) or 24 inches (US), and most dishwashers must be installed into a hole a minimum of 86 cm (Europe) or 34 inches (US) tall. Portable dishwashers exist in 45 and 60 cm (Europe) 18 and 24 inch (US) widths, with casters and attached countertops. Dishwashers may come in standard or tall tub designs; standard tub dishwashers have a service kickplate beneath the dishwasher door that allows for simpler maintenance and installation, but tall tub dishwashers have approximately 20% more capacity and better sound dampening from having a continuous front door.
Feb 06, 2015 | Kenmore Dishwashers
Want to remove present dishwasher for replacement with a new one. How do you do it.
Most dishwashers are housed in a cabinet next to your kitchen sink.
Not knowing how exactly your machine is set up I will just advise you on common setup features and removal.
First open the doors to kitchen cabinet under the sink. If you see two hoses connected under the sink, they most likely are from your dishwasher. One is an inlet hose which would be connected to a water tap. The other would be a drain hose which would be connected via a clamp to the drain under your sink.
Turn off water tap to remove inlet hose. Unscrew or undo the clamp fixing your drain hose to drain pipe. Note when you remove the drain hose the hole to the drain pipe is exposed. You need to block this off as it will leak water when ever the sink is running. I normally get a plastic bag and twist it inside the hole and tape it off.
Next you need to locate the power cord and plug for the dishwasher. This is normally under the sink cabinet as well. However, check either side of the dishwasher. Sometimes they are behind the dishwasher.
Once you have disconnected the hoses, open dishwasher door. Look on the inside walls of the dishwasher. Some models are screwed into the wall of the cabinet so you need to unscrew machine. The screws go in either from the side walls or from the inside roof of dishwaser to your benchtop.
You need to also remove the kitchen kickboard if one has been installed infront of the dishwasher.
When machine is free open the diswasher door and grab either side of door and gently pull machine out. Have someone help you feed the hoses through as you pull out.
If the machine does not easily pull out check again for hidden anchor screws around the edges of the machine or even clamps which fix the hoses to the cabinet.
If you have issues pulling it out see if you can take some pictures and I will help you.
ash
Sep 11, 2011 | Dishwashers
The diswasher drain connection is blocked in the new badger 5 that I just bought and installed and the dishwasher cannot drain and it runs up out of the drain line and goes out on to the counter...what am...
You are missing that the plug needs to be removed on a new disposer. All new units have this port sealed as not every install will have a diswasher...Take the unit out, and look in the hole, woopsies. Push it out with a screwdriver and a hammer. this blockage would cause the water to come out of the vacuum break on the counter.
Fortunately not a big problem to repair.
Oct 05, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
GE CAFE dishwasher was installed and I can see the hindge at the bottom of the door. Can it be installed deeper in the cabnit
if it was installed correctly you should only be able to see the hinge uif you were looking at it on a downward diagonal
Nov 16, 2009 | GE Cafe C2S980SEMSS Stainless Steel Dual...
Replacing an old diswasher
all dws are standard hight
Dec 24, 2008 | GE Dishwashers
How to install built-in dishwasher w/out kinking water lines?
I eventually unhooked the hotwater line where it comes in below the sink in order to give the slack I needed to hook it up to the elbow on the front of the dishwasher...then slid it into the 24in. space, but found that my hotwater line was 4 inches short! A trip to home Home Dept to buy more line and connectors solved the trick and now it is all hooked up and works with no leaks.
Nov 30, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwasher installation problem
I have had this problem in the past as well. They state that you have all the parts you need to install the dishwasher, however that is assuming that it is under ideal conditions. You will need an adapter to attach to the fill line to make it match the size on the diswasher. They usually only cost about $3.00.
Nov 09, 2007 | Kenmore 15129 Built-in Dishwasher
Diswasher drainage in an island
Dbootin,
I suggest just putting a dedicated Drain in the island next to the Dishwasher. You can hide it in side the island. Under the house, tee into the Main Sewage drain.  You should not need to vent it as the sinks vent is near enough to keep you from worrying about that.
Oct 31, 2007 | GE 24 in. GSD4000J Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
1,102 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
