Question about Sony Playstation 3 (PS3) Console
Plugging the console into my house caused a breaker to trip. Resolving that my house does not generate enough power to play the console, anh attempt to plug it in at a friend's house only proved it no longer powers up at all. No lights on the console light up at all, obviously with the power switch up or down. Firstly, is this repairable? Secondly, if so, is there a way to make it operate at my house without having to rewire the whole house?
    Problem Solver:
  • 16 Answers
Yes and yes. lots of places places fix it for about 70 euro. ps3s dont use that mush power. to definatly solve the problem run a cable from your fuse board and put the socket on its own 20 amp circuit breaker. this will definatly solve it.
Posted on Jan 10, 2010
Sparking in power box when we use the generator and trips the braker
When you say "power box" do you mean the main breaker box in your house? Is the generator hooked up to the breaker that you say trips when the generator is on? There is a short somewhere. First check the generator. Is it running OK. In other words if you plug something into the generator receptacle directly, does it work? If the generator itself works properly, then check the wiring from the generator to the circuit breaker. DO NOT use the generator until the problem solved = safety first.
Jun 12, 2014 | Cars & Trucks
I have a 5kw generator it was working fine I use it on the oil fields to power my little rv suddenly every time I turn on the air con it trips the breaker and now im using a air compressor and at first...
A number of things can cause this. A sit worked before !
Basically:
Engines get older and can't hold HP which causes the rpm to slow and voltage dip, this causes a current increase and trips.
Breakers also get weaker especially if they trip a few times
HVAC and compressors pull approx 6 times the current to start as they do to run, once they have run a while, they build up higher head pressures which cause harder starting and more current draw, hence the breaker tripping.
It's hard to pin point which is the actual issue, but these all contribute.
Aug 08, 2013 | Briggs & Stratton Power Products 5,550...
Duo therm a/c turns on blows cold after a few minutes it trips breaker on the power source
Take off the to the compressor it sounds like a burned terminal is causing the breaker to trip
Jul 26, 2012 | Dometic Rooftop RV Air Conditioner
Have a 5000 watt portable generator when running AC on a hot day it will pop breaker after about 30 minutes
Extension cord will cause it to trip. Make sure it's big enough and as short as can be. worn breaker will trip easier.
May 30, 2010 | Coleman Powermate Powermate 5000W...
Generator starts but does not put out amperage.
Make sure the breaker has not tripped. If the breaker has not tripped then it can be many things causing it not to produce power.
Jan 02, 2010 | Honda 3000 Watt Portable Generator
Trailer AC works plugged into house plug but trips breaker on generator and a light plant why??
Poor grounding on the generator or connecting wires. Weak breaker on the generator. Locked rotor amps to high for generator circuit. Weak capacitor causing too high amps for generator.
Jul 08, 2009 | Heating & Cooling
Cooler keeps on triggers breaker
If it is tripping the breaker, stop plugging it in. The breaker is tripping because something is wrong, and continually resetting the circuit WILL cause a fire. Either return the unit, or have an electrician look at it. You can also try plugging it into another circuit in your house to isolate the problem, but please don't repeatedly reset the breaker, there IS a problem somewhere.
May 27, 2009 | VinoTemp (VT60GNV) Wine Cooler
One of 2 circut resets keeps tripping on our Generac generator
If it's tripping a breaker that usually means there is to high of an amp draw on that curcuit.
Are you plugging more things into that particular curciut (or just different but higher amp draw items) than you did last year?
It's also possible that one of the items plugged into that curcuit is wearing out and drawing more amps than before.
If you have an amp meter, plug everything back up just the way it was when you were having problems. Check the main wire going to that curcuit. (right at the breaker)
If your amp draw is greater or nearly the same as the amprating of that particular circuit, then thats your problem.
To many things/to high amp draw on one circuit.
If it is not near the amp rating, and you are getting proper voltage to the breaker, then I would replace that breaker.
Dec 30, 2008 | Electrical Supplies
Frigidaire front loader dryer, Gallery series, blowing cold air only
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
I attempted to locate an answer to resolve the issue for you, but you have not provided me with enough information to access my service database. Please observe the TIP below, and post me back and I will be happy to assist you further.
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 23, 2008 | Frigidaire Dryers
Sony Playstation 3 (PS3) Console Logo
62 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
