Question about Broan-NuTone Allure III QS330SS Kitchen Hood
Noisy fan or motor?
When fan is on high speed it very noisy any ideas what is causing it
allure ws1 series range hood
neil
  • 6,784 Answers
HI. The most common issue here will be with a loose motor shaft. This is the part that the fan blades are mounted on. When this occurs, the looseness will cause the motor, and shaft to wobble, thus, causing this noise you here at high speeds. The wobble is less violent during the slower speeds, so it is not loud, in this case.
The second issue will be a warped fan blade. This will cause the fan to rub against the shroud, thus, creating the noise, as well.
If the shaft is loose, or bent, the entire motor will need to be replaced. Now, if the fan blade is warped, you can, simply, unscrew the blade from the shaft, and replace it(on most model)
Posted on Dec 11, 2009
    President:
  • 3,085 Answers
These motors are real junk, i've had 3 in 2 years.
Go to www.broan.com and scream at tech support.
    President:
  • 1,214 Answers
These units tend to be noisy. Make certain the duct work (if ducted) is installed as recommended. No severe changes in diameter, hard turns right at the top discharge, etc.
If air is restricted at the fan inlet or outlet, then the fan will turn slightly faster, usually creating more noise.
The way the hood is mounted to the cabinets could also be a source of noise. Putting rubber washers between the hood the the cabinet will reduce the transmitted vibration, when done right.
Range hood installation
you can reseal the hole with aluminium tape
you can use screws with metal flat washer that has a rubber backing
May 28, 2009 | Broan-NuTone Allure III QS330SS Kitchen...
7" damper
The damper you are looking for is Broan part number 97. It is available online.
Jan 17, 2009 | Broan-NuTone Allure III QS330SS Kitchen...
Very noisy operation
Yes....this will throw than fan unit out of balance almost the same way the tires on your car get out of balance. The wobble effect at high speed makes tons of noise.
Oct 05, 2008 | Kitchen Ranges
Vibration at high speed
check these causes fan blade brackets,fan blade for cracks, any grease on blades.
Dec 27, 2007 | Broan-NuTone Allure® I WS136BC Kitchen...
Broan-NuTone Allure III QS330SS Kitchen Hood Logo
1,517 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Steve Allison
Steve Allison
Marvin
Marvin
Steve
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
