Question about Samsung LN-T4661F 46 in. LCD HDTV
Screen will periodically go half black. Then it goes back to normal. Or the black slowly creeps up from bottom of screen.
  • Anonymous Mar 30, 2014
    screen periodically goes black for a few seconds
  • 4 Answers
When you have video display problems such as shadows and lines that go away after warming up, or come and go during viewing, it is usually the LVDS cable and T CONN board going bad. The screen can have one of the following or combinations of blurs, different layers of brightness and lines. It could be the back light but most of the problems with the LNT4661F have been this.
I had the shadow and line problem and replaced both the cable and board for $120 and that fixed my problem. Since I had the TV apart, I went ahead and replaced the capacitors on the power supply board so I wouldn’t run into the clicking problem that also affects this model TV. You can find the parts numbers for the LNT4661F cable and board below. You can find links to YouTube ( Part 1 & 2) to show how to replace the capacitors. Good luck.
Samsung A/S-T CON BOARD BN81-01312A
Samsung Lead Connector LVDS BN39-00883A
YouTube (Part 1) http://www.youtube.com/watch?v=Mm51C_RDIZE
YouTube (Part 2) http://www.youtube.com/watch?v=BNHHrgX_6cs
Posted on Dec 18, 2009
  • CFlannigan Jan 23, 2011
    I had a similar problem that I was able to fix by just removing and reattaching the LVDS Cable and T-Conn board. I suspect it was a bad connection for me. Good Luck.
  • Samsung Master
  • 8,457 Answers
Ur backlight video board is dying,just not completely dead yet.Must replaced to solved this prob.
Posted on Dec 11, 2009
Half the tv screen goes black randomly,then returns to normal
The Tuner signal board have problems.The board CPU,Chip,have intermitten short.When the chip is completely dead.The tv will get only LED light indicator power only,will not get tv signal pictures.
Apr 12, 2010 | LG 42LC2D 42 in. LCD HDTV
While watching tv half the screen goes black
Download software from the Phillips web site. Use a usb flashdrive to transfer the download to the TV. This worked well for us and our picture is better than ever.
Apr 09, 2010 | Philips 42PF7320A 42 in. Plasma HDTV
Picture goes black on bottom half of the screen
You have a bad connection to the panel or bad caps on the boards. Not something for the DIY'er. High voltages in plasma sets.
Mar 31, 2010 | Sanyo DP42746 42 in. Plasma Television
Bottom half of screen goes black
This is because full pixels of your TV is not getting invoked at the beginning .If you are able to view the picture as normal after 1 or 2 minutes, its fine.Else you need to call to service center and get this problem fixed.
Aug 08, 2009 | LG 42LC2D 42 in. LCD HDTV
BOTTOM HALF OF SCREEN GOES BLACK R A MINUTE OR SO THEN RETURNS T NORMAL
remove the back of the tv.disconnect and reconnect the ribbon cables into your buffer pcb.if this does not correct the problem replace the buffer pcb in that location where the screen is going black.you also could have
a defective panel if the buffer pcb does not correct your problem.
Jul 17, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
Bottom half of screen is black
its ur diaplay problem.. go for a change of new display...
Jun 30, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Bottom half of the screen goes black
Make sure you have the text turned to off in the closed caption settings
Apr 23, 2009 | Televison & Video
Samsung LN-T4661F 46 in. LCD HDTV Logo
1,027 people viewed this question
Jerry Greenberg
Jerry Greenberg
