Question about Belkin (F6C550-AVR) (DBF6C550AVR) UPS System
How do I know when I need to replace the battery
Can I replace the battery in my belkin F6C550 AVR with a larger one? The battery compartment seems big enough to hold two stock batteries.
    President:
  • 2,187 Answers
The only thing you will look out for is the specs of the battery. That is the voltage that it gives out. The size usually determines the hours it can provide power on a full charge.
Posted on Dec 11, 2009
Most ups batteries are 12v, what you need to look for is the "amp hour, or AH rating" usually they are 4-10ah batteries most common rating being 7ah which can upgrade to a 7.5ah or 8ah, but I'd stay closer to the 7 (as in 7.5) if your ups requires MULTIPLE batteries... because there are reports of ups's becoming fire hazards and you wouldn't want that to be because you went "large" by putting mutiple 9ah battery in a 7ah form factor when it wasn't designed to be.
Posted on May 17, 2010
My belkin F6c-500 works on the non back up side however, doesn't work when power is lost. I have replaced the batterey.
Moss Fet Transistors Failure.
When an UPS works too Much time power line disconnect always the UPS only works for a while. too much time working with the Batteries inside makes the power converting transistors overheating and failure.
Check Internal Fuses, inside the UPs there is an automotive Fuses(30 Amps) plug tipe like in cars.
if the fuses are OK .........................then check it by a Technician.
Check it by a Qualified Technician and check the Mossfets.
Sep 27, 2014 | B&B Belkin 84Whr F6C550-AVR - Rev.A UPS...
How do i tell that my UPS batteries need to be replaced
UPS makes self simpler tests regularly, if problems arise alerts UPS.
You can break the input voltage to the UPS and have it run on battery for 20 minutes, if your load accept the risk of power interruptions ...
May 23, 2014 | Belkin (F6C550-AVR) (DBF6C550AVR) UPS...
How do i change battery in Belkin 550av
I have had the same problem with mine.. and just found the product manual for BELKIN'S F6C550-AVR - UPS.. this is the link.. I hope it is helpful
http://www.belkin.com/support/dl/614-07166-00_UPSmanual.pdf
Jan 30, 2012 | Belkin (F6C550-AVR) (DBF6C550AVR) UPS...
My Belkin 550VA don't start up The model is F6C550-AVR
this may happen because of gone battery without battery it will not comes on mains also so directly change battery before that you also check the fuse if blown replace it with same ratings problem will be solved
Feb 24, 2010 | Belkin (F6C550-AVR) (DBF6C550AVR) UPS...
How do I take a Belkin F6B750-AVR apart?
they are non serviceable. You will have to pry it apart. Most of them do break the tabs off to get open.
Nov 12, 2009 | Belkin Office Series 750 F6B750-AVR...
I bught a belkin ups system but i lost the manuel and i dont know how it work . And when i conect the belkin product it me a sound like a beep .
Trust me when I tell you this. That UPS you are looking at, should be replaced. It is too small for computers today, maybe good for your fax machine or answering machine. Computers are getting more powerful, so I recommed, if you loose your manuel, I suspect you are also ready to upgrade to a AVR line interactive 1000VA.
Sep 05, 2009 | Belkin (f6h375-usb) UPS System
Belkin f6c750-avr repair / Testing
You could be correct on the transformer. I'm kinda leaning towards a bad cell in the battery. Sounds like it will need replacing.
Sep 03, 2009 | Belkin (F6C750-AVR) (BELF6C750AVR) UPS...
UPS periodically disconnects
You have a smart chip problem. Your unit is too small that would be cost effective to repair.
check out my web page:
www.storminprotection.com.
I will help you save a few dollars but I think you might need a little bigger UPS then a 550. Try going bigger.
Mar 14, 2009 | Belkin (F6C550-AVR) (DBF6C550AVR) UPS...
My model FC6120-unv is dead
If you've got nothing my guess is its something more than the battery as it should still be able to draw power if its plugged in. If its within the warranty period (3 yrs, I believe). Go to the belkin webpage and to their ups support and start the process to return it and get it fixed/replaced. A couple months ago I had a F6C500-UNV that suddenly died on me just like yours - no nothing. It cost me $13.00 or so bucks to ship the broken unit to Belkin; a week or two later I got a brand spankin' new F6C550 or whatever they currently sell in that same voltage area back from them. The cost to RMA the broken unit was much cheaper than even buying a new battery for the old and now discontinued unit.
Dec 26, 2007 | Belkin ( F6C500-UNV) (Bundle)...
Belkin (F6C550-AVR) (DBF6C550AVR) UPS System Logo
366 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
