Question about Dishwashers
Dishwasher won't go to next cycle kinda hums.
I have a Kenmore undercounter dishwasher ( 665.16332301 )
The disheasher started have a minor squeek a while back but we really haven't noticed it for a while.
Currently the dishwasher seems to load with water and then kind of sound like it stuck getting to the next cycle. ( kinda a low hum )
Any ideas?
Thanks,
T
  • timkeating Dec 11, 2009
    Hi Mark,
    Thanks for your response.
    It seems like it fills with water, and then when it is ready to go into the next cycle( wash cycle? ) it just kinda hums and never really gets going. I was kinda hoping it's jammed with something. It does make a sound sort of like a fan would if you were holding the blade preventing it from moving.
    Thanks...
    T
  • Mark Egan May 11, 2010
    Sounds like either the controller has failed, or the heating element has failed. Hard to say based on your description. Does this occur at the start of the washing cycle, or at some point in the washing cycle?
    President:
  • 1,214 Answers
If you never hear it washing, then it sounds like the motor is not turning. There may be something that has gotten down inside the pump impeller at the bottom of the unit.
You will need to remove the baskets, remove the lower spray bar, then remove the lower plastic shield that covers the impeller. At some point you should be able to rotate the motor by turning the impeller.
Posted on Dec 12, 2009
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
Why is heated dry blinking?
FIXED Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry ...
www.applianceblog.com/.../40588-Kenmore-dishwasher-lights-flashing-...
Aug 26, 2013 - 10 posts - ‎3 authors
Thread: Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry" ... A few months ago, we had a brief power outage and the next morning, noticed the "Hi Temp" and "Heat Dry" lights were flashing. ... Well since then, the dishwasher intermittently stops mid-cycle and these same lights ... Thread: GE Eterna QuietPower 2 Normal and Heated Dry ...
Feb 24, 2012
Kenmore Elist 665 dishwasher Smart Wash red light ...
Dec 23, 2011
Heated dry blinking +17 times - ApplianceBlog
Nov 14, 2010
Heated Dry light blinking
Nov 7, 2010
More results from www.applianceblog.com
Why won't my dishwasher start and why does the "Heated Dry"
www.shopyourway.com > Manage My Life > Questions
Nov 16, 2009 - When I hold down the Heated Dry button to turn the control lock on it ...my dishwasher start and why does the "Heated Dry" light keep blinking ...
Dec 01, 2015 | Dishwashers
What is the length of time for the Normal Wash cycle on the Undercounter Elite model? Mine seems to run about 2 hours. That seems way too long to me.
Nah... that is about normal for a dishwasher today....if all else fails just soak everything to death... no real cleaning anymore...
heatman101
May 09, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Dishwasher not moving past sensing cycle
humming noise sounds like a solenoid is not snapping in, this is not something that the average or even above average homeowner can fix. Solenoids go bad, they are a moving part that are activated by electricity, can be dangerous to mess with as water and electricity don't mix. Get a repairman or get a new one.
Apr 28, 2017 | Kenmore 15952 Dishwasher
Kenmore dishwasher 15762
On the inside of the dishwasher (on the bottom), there should be a little "float" device, which tells the dishwasher when it has put enough water into the tub. Sometimes, this float gets stuck in the "up" position, so the dishwasher never puts any water in, but continues to run anyway as if it did. Try pushing down on the float to unstick it, then start the cycle over and see if it puts any water in.
Feb 06, 2007 | Kenmore 15762 Dishwasher
Dishwashers Logo
122 people viewed this question
Top Dishwashers Experts
