Question about Sony FD Trinitron WEGA KV-32HS510 32" TV
Tv problem my medallion series led blinking
  • 1860ph May 11, 2010
    How many times
  • Sony Master
  • 19,396 Answers
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem on dvd with no receiver box connected.
If the TV goes off completely, then is usually a faulty power board.
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on Mar 28, 2009
6ya staff
SOURCE:
I need to be able to connect DVD player to output 3 on Mitsubishi Medallion hdtv 1080 we can't seem to get it to work
It needs to be input if you want to display some on the TV from the DVD player. HDMI is the easiest as it's both audio and video.
Jun 01, 2015 | Mitsubishi LT55164 Unisen Medallion 55...
Have a Mitsubishi medallion 65 in got a code 2-3 how do i fix this or is it worth it?
These Medallions have some of the worst problems caused by wiring faults. They over heat and go into sleep mode. Try getting a can of compressed air and cleaning out the dust.
Chadman
Nov 18, 2014 | Mitsubishi LT46164 Unisen Medallion 46...
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
Nov 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
The green timer lite is blinking and the tv will not turn on. It's a Mitsubishi Medallion we bought about 5 years ago. It has a 64 " screen from corner to corner. This didn't match any option I was given...
Good Day,
You have a couple of problems.
(LED does not stop blinking after plug in) Disconnecting the USB connector from the Card Reader did not help. Remove connector FC from the FMT PCB and plug the unit in, if the LED stops blinking after 70 seconds with FC removed suspect a problem on the FMT PCB (part # 930B924002), if the LED keeps blinking with connector FC removed suspect a problem on the DM PCB (part # 934C116002).
(LED does not stop blinking after plug in) On the DM PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). See Service Tip VS-78A
(LED does not stop blinking after plug in) On the FMT PCB (part # 930B924002) check C8F19, C8F21, C8F22, and C8F27 (16V 1000 UFD 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). .
I would not attempt to do this on your own! Call an Autorized Service Center, it wikll cost at least $ 750.
Good Luck, big IRISH.
Dec 08, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Moving a Mitsubishi HD1080 Medallion series 55
Actually no just need to HANDLE WITH CARE and make sure you protect the screen,you can cut a piece of cardboard same size of you screen to protected from any object,you TV has mirrors inside just be careful,other then that you will be OK.
Regards
Nov 17, 2009 | Televison & Video
Last night the electric went off now my tv will not come back on all its doing it flashing a green light. my tv is a mitubishi big screen medallion model ws 55615
how many times is the led flashing or is it a continuous blink that doesnt stop? Pleaserespond to this same post and I will try to assist you with the problem.
Sep 07, 2008 | Televison & Video
Mitsubishi Medallion HD 1080 model ws-48413
my mitsubishi medallion tv wont power on.
all I get is a blinking light. How can this be fixed
May 08, 2008 | Mitsubishi WS-65413 65" Rear Projection...
Sony FD Trinitron WEGA KV-32HS510 32" TV Logo
121 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
