I have a Samsung HL-R5067W and the HDMI input will not work. I get blue screen and a warning message that the signal is low or scrambled. If the HDMI cable is disconnected from the DVD player the TV says the HDMI is not connected so it sensing that. I have tried the DVD player and cable on another TV and it worked fine. AV and cable inputs appear to work OK.
those units have had problems with the siganl board and dm module both having solder connection problems and require to be sent out to a rebuilder that can handle that special work you might call samsung consumer and see if its uner and class actions or recalls
other wise it will be a local servicer to assist you further with its problems
Check if it has a scrambled image on all sources ie - DVD- VCR - cable/satellite box. Since the PIP is normal it sounds like the signal source is bad.
Post back with more info about your set up (what's hooked to your TV) if you need more info
After reviewing the service manual for this set, the problem is is in the DIGITAL BOARD. To get the right Digital Board you will need the Version number of the TV.
Check if this happens in analog inputs ( connect a DVD player or any other component uing RCA cables white,yellow,red ) then check if the bars are showing on digital unputs ( connect using HDMI cable )
if it is just an analog problem - replace analog board
if it is just a digital problem - replace digital board
if it is a problem with both -replace DMD board
The Samsung Television has 3 HDMI inputs, You would connect an HDMI cable from the Cable box to your television and go into a menu on the television to select the appropriate HDMI input.
New cable boxes should have the HDMI connection.
Most Flat screen televisions I've seen have an input button on the television itself. Pushing it should allow you to switch between inputs.
