Question about Grilling
I have a Kenmore model#10648062890 bought in canada, frost is building up through out fridge and freezer
  • 4,070 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} There are two possible causes or types of frosting. One is where the surface of the items in the freezer have frost on them. It may be in one spot or evenly distributed. This is caused by excess room air getting into the freezer because of leaky door gasket which should seal snugly on a dollar bill inserted between the gasket. Frequent or prolonged door opening will also allow room air in. The higher moisture content in the air freezes on the surfaces of the food etc.
Posted on Dec 11, 2009
Testimonial: "great site guys "
  • Charles T Nevin
    Charles T Nevin Dec 11, 2009
    DEFROST PROBLEM
    The evaporator coil behind the cover on the back
    wall inside the freezer will ice up under normal conditions. Every 8 to 10
    hours for around 20 minutes the
    defrost timer (or in most newer models the electronic
    adaptive defrost control) will turn the
    defrost heater on to
    melt the built up ice. There is a
    defrost thermostat which prevents the heater from
    overheating the freezer by breaking the heater circuit when the temp reaches
    close to 32 degrees F. The entire cooling system shuts off during the defrost
    cycle and starts back when the timer advances through the cycle.
    If this ice is not melted it will continue to
    build up until the air can’t flow over the coil to circulate the cold air
    through the freezer and into the fridge. The temperature change in the fridge
    is usually noticed first followed by the freezer.
    If the defrost thermostat is bad it can prevent the heater from
    coming on OR it won’t turn the heater off when it gets too warm. It is clamped
    to the evaporator coil at the top to sense the temp. If it appears to be
    misshapen it is bad.
    With an ohm meter it should show continuity when
    cold and none when warm.
    You can also bypass the thermostat to see if the
    heater comes on then. If it does then you know the thermostat is bad and needs
    replaced.
    The defrost heater is
    located on the evaporator. It is in a tube which is at the bottom and can also
    go up the sides of the evaporator. On some types you can see a burnt spot if
    it’s bad. With an ohm meter it should show continuity from end to end when
    disconnected from the wiring in the freezer. You can also test the wiring for
    voltage when it’s in the defrost mode.
    If
    you have a
    defrost
    timer
    you
    can test it. It is located in the fridge with the controls at the top.
    You can turn the defrost timer till it clicks and everything shuts
    down. The heater should now come on. If it does, replace the timer because that
    means the timer is not running. If it
    doesn't, check the heater and defrost thermostat. Turn the timer again till
    everything starts back up to end the defrost cycle.
We have a Kenmore Elite Trio (bottom freezer- Model#596 73502201-bought 2004) and both the fridge and freezer are blowing cool air but not cold. Food in freezer has defrosted and the fridge temp. is much...
Check to see if the evaporator behind the back metal cover on the freezer side is all frosted up, if it is, then it will probably be the defrost heater which is bad and letting it clog with frost causing low or no airflow. The heater is not expensive and can be ordered online on ebay.
If you need further help, reach me via phone at https://www.6ya.com/expert/gary_9c859f4aa7e5ab10
Mar 02, 2018 | Kenmore 73502 / 73504 / 73509 Bottom...
Our top mount Kenmore fridge (Model # 253.77872509) is frosting up in the freezer section. Have turned off & defrosted the freezer on several occasions - it works for a few weeks but then begins...
Normally when frost build up occurs it's because warmer outside air is getting into the freezer and the moisture from that warm air cools and condensates then freezes into frost or ice. You either have a bad seal like the other listing states try leveling the front a little higher than the back. Or you may have an issue with the defrost heater, thermostat or timer. Do you have a light that comes on from time to time? If so you have an auto defrost unit. If there is no light you may not have a frost free freezer which means you will have to remove the frost manually.
Please check the bellow links for your knowledge:-
http://www.wikihow.com/Stop-Your-Fridge-from-Ice-Build-up
http://www.ehow.com/how_4781069_prevent-frost-build-up-freezer.html
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Sep 30, 2010 | Kenmore Refrigerators
Frost is building up in bottom freezer. Amana ABB2224DEW
I have this problem as well, only nobody is leaving anything open. The defroster is defective of these things and the duct between the fridge and freezer gets frozen over and the cold air can't get in the fridge, so the freezer keeps working until it's blue in the face.
Apr 19, 2010 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Frost forms in freezer, blocking vents so temp in both freezer and fridge is warmer than normal
You have an issue with the defrost system, either the timer, thermostat or heating element. Probably the defrost timer refer to the manual to find it. If you don't have the manual check the makers web site for a parts breakdown. You should be able to put it into defrost manually by turning the knob and see if that helps. You may need to do this sevral times as it only stays in defrost for a little over twnety minutes and run cycle for 6,8 or ten hours. If the ice build up is heavy then twenty minutes may not do the trick thus the need for repated defrost cycles. If it does the trick replace the timer. If not check the thermostat and heater element.
May 18, 2009 | Kenmore 22.4 cu. ft. Bottom Freezer...
Frost build up in a frost free freezer
It could be the door gasket. It could also be that the fridge needs a good defrosting. (especially if it is an older fridge)
When I bought my house I had the same problem with the fridge that came with the house. I assumed the previous owner had been defrosting it regularly, which he had not.
Eventually I decided to try a full defrost, and my fridge now works like new.
Mar 20, 2009 | Kenmore Freezers
Loud shreaking sound coming from Kenmore Frost Freezer.
The fan behind the molding is hitting some ice build up and causing the sound. Sounds like the timer for the defrost isn't working. Try to turn off the unit for few hours or take off the molding in the freezer compartment and remove the ice build up with hair dryer.
Nov 23, 2008 | Kenmore Freezers
Kenmore fridge
First we need to see if the compressor is running.  Pull the fridge out take off the lower panel on the back and see if you can hear it running.  Also, need to know if freezer fan and fan by compressor is running.  Check for thick frost build up on back panel in freezer.  Let me know what you find.
Oct 21, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Grilling Logo
70 people viewed this question
Top Grilling Experts
Paul Carew
Marvin
Marvin
Tom Chichester
Are you a Grilling Expert? Answer questions, earn points and help others
