Question about GE JE1860 Microwave Oven
How to change burned out light bulb - GE JE1860 Microwave Oven
  • GE Master
  • 3,051 Answers
Hello there:
First you will need to unplug the microwave
next on the back along the edge sides you will see several screws remove them now on the bottom of the microwave once again look at the edge and you will see several screws on both sides remove them
now on the side check to see ifthere is any screws if so remove them as well
now the cover will come off it will slide from the front to the back you may have to usea small flattip screw driver to get it started then it will lift off .
You wil see the lightbulb towards the front now just remove it and get a new one and test the microwave if the light now works great just put every thing back together and you are done (Good job) You just saved your self abouta 60 dollar service charge.
I hope this is very helpful for you .
Best regards Michael
Posted on Dec 11, 2009
Testimonial: "Great response! Succinct and accurate. Thank you so much."
Cook top light stays on
Sounds like the bulbs shorted out the smart board, this happens sometimes when folks change the bulbs without up-plugging the oven.
Mar 30, 2014 | GE Microwave Ovens
Changing interior light bulb on GE jes1289sk
I have had this trouble before but with a different model. There may be a plastic screen inside the microwave that will just pop off exposing the bulb. Now all you will need to do is to find out what type of bulb you will need to change the other bulb. I hope this made things easier on you.
Jul 25, 2013 | Microwave Ovens
How do i change the bulb on ag821azh microwave x2
follow this steps and use the VOM for fix it. God bless you
Light Bulb
If the microwave light bulb is not working it is usually located behind the upper grille and behind an access panel, and above the lower panel. On counter top units you will need to remove the outer cover to get to the bulb. If that doesn't solve the problem check the on-off switch, and control board
Main Control Board
If the microwave light bulb is not working check the light bulbs, sockets and wiring. If they are good the main control board might be defective.
Light Bulb Socket
If the microwave light bulb is not working and a new light bulb doesn't solve the problem, the light bulb socket might be burned out and need to be replaced.
Jun 19, 2013 | Microwave Ovens
How to halogen light bulbson my microwave JVM3670Sk03 I have changed one I know there is another one how do i change it please advice thanks anna
That's covered on pages 35 & 36 of your owner's manual.
If for some reason you don't have yours, you can download it here.
Cooktop Light/Night Light
On models JVM1850, JNM1851, DVM1850 and
EMO4000, replace the burned-out bulb with a 120 volt,
40-watt incandescent bulb (WB36X10003), available
from your GE supplier.
On models JVM1870, JVM1871, JVM2050 and
JVM3670, replace the burned-out bulb with a 120 volt,
20-watt halogen bulb (WB36X10213), available from
your GE supplier.
To replace the bulb(s), first disconnect the
power at the main fuse or circuit breaker panel
or pull the plug.
Remove the screw at the left edge of the light
cover and push on the right edge of the cover
to open.
Be sure the bulb(s) to be replaced are cool
before removing. After breaking the adhesive
seal, remove the bulb by either gently turning
(for models JVM1850, JNM1851, DVM1850 and
EMO4000) or pulling straight out (for models
JVM1870, JVM1871, JVM2050 and JVM3670).
Replace with the same size and type bulb.
Raise the light shield and replace the screw.
Connect electrical power to the oven.
Oven Light
Replace the burned-out bulb with a 120 volt, 20-watt
halogen bulb (WB36X10213), available from your GE supplier.
To replace the oven light, first disconnect the
or pull the plug.
Remove the top grille by taking out the screws
on top of the grille that hold it in place and
sliding the grille to the left (opening the door
makes grille removal easier).
Next, remove the light cover.
On some models, the light cover is located
in the center of the top opening. Remove the
screw that secures the light cover and lift the
cover off.
On some models, the light cover is located at the
left of the top opening. Lift the cover off.
Pinch the clips that hold the light socket in
place and lift the socket out.
Remove the bulb from the light socket by
pulling straight out. Replace with the same size
and type bulb, then replace the light socket and
cover.
Replace the grille and screws. Connect electrical
power to the oven.
Jun 08, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave cooktop lights keep burning out. why? i've changed the 10 watt low volt bulbs 4 times in the last 6 mos. each time being careful not to touch the bulbs with my fingers. they will work for...
Are you keeping them on all the time?
Or is the the microwave subject to excessive vibration or door slamming while the lights are on?
Both these conditions are factors in premature bulb failure.
I would also avoid cheap Chinese bulbs from grocery stores and get the GE-specified bulbs either from here online or a local home center such as Lowe's or Home Depot. etc.
Dec 13, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Light bult in a Microwave oven is burned out.
There should be a panel covering the bulb iside the cookspace with a screw holding it on. Remove screw, cover then bulb.
Oct 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Light bulb burned out in microwave oven
Most likely you're going to have to dismount the microwave and remove the outside cover to get to the bulb. This is a fair amount of work but is not rocket science. I'm not famliar with your particular microwave, but it's probably that way. If it's any comfort to you, light bulbs are usually not covered by warranties or service contracts.
It won't hurt to run the microwave without a bulb.
Feb 03, 2009 | Whirlpool GH7145XF Microwave Oven
F6 error... microwave not working
is the microwave itself working? because same thing happened to us apparently the guy who changed the bulb didnt unplugg the thing first and well it burned a part of the circut board cost us about 90 dollars to fix it.....
Oct 05, 2008 | Roper MHE14XKB Microwave Oven
Where is the light bulb on JES738WJ GE microwave oven? I need to change it as it burned out. Thanks.
Took cover off unit to expose bulb. However, was not able to remove bulb by pulling, or unscrewing. Guess the entire bulb "unit" must be replaced.
Jul 25, 2008 | Microwave Ovens
GE JE1860 Microwave Oven Logo
204 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
