Question about Maytag MSD2756G Side by Side Refrigerator
GARAGE FRIDGE DIED...IS IT THE COLD?
I have this fridge in my garage and it all of the sudden died..no light, no nothing. Is it equipped with some sort of shut off sensor if it becomes too cold in the garage that it is in? Our temps are in the single digits...
  • SPAPA Jan 20, 2008
    Well...I did as you said ..and walla...the plug was dead!! I checked the circuit breaker and it was ok...do you think.. or have you ever heard of.. a plug going bad? I've never had this happen before?!
Ok....I found the GFCI plug and it was popped...I reset it and the fridge turned on...I went back an hour later and the breaker was popped again...now what?
Posted on Jan 21, 2008
  • 447 Answers
No it has no sensor it sounds like the circuit breaker has tripped or the is no power at the plug..try plugging a radio or lamp in to the plug to test
Posted on Jan 20, 2008
  • joey  shearer
    joey shearer Jan 20, 2008
    A GFCI plug has tripped most likely check all the ones in your bathrooms,garage,kitchen it can control other outlets other than itself
I HAVE SIDE BY SIDE FRIDGE/ FREEZER THE FRIDGE IS WORKING AND THE FREEZER IS ONLY AS COLD AS THE FRIDGE IT DOESN'T FREEZE THE FOOD. I HAVE IT IN THE GARAGE NEAR THE DOOR SO IT IT VERY COLD , I LIVE IN...
I'm in Mass and also buried in several feet of snow, so I have an idea how cold it is in your garage. As a matter of fact, you don't run a compressor in cold outdoor weather, which is basically what you're doing. AC units that were meant to run outdoors have a compressor heater, your fridge doesn't have one.
Feb 18, 2015 | Refrigerators
I recently had to throw away some questionable food that had partially thawed in the freezer cabinet of my kenmoore, model# 253.67882508 fridge with freezer on top. i keep this fridge in my garage and in...
probably,there is a garage kit available that willallow it to work at colder temps,listed in owners manule under accessories the thermostat senses refrig compartment temps.soif garage temp is below 40 or so the thermostat just doen't turn the unit on enough or not at all
Jan 17, 2010 | Refrigerators
Had a fridge freezer in garage. Just found that
more than likely the defroster inside the freezer has gone bad. This defroster is located in the space between the fridge and freezer and activates to defrost the freezer and stop build up of ice in the freezer.. If it is bad the freezer will not keep the fridge nor freezer cold.
Dave
Jan 08, 2010 | Zanussi 3.46 cu. ft. / 98 liter Upright...
Leaving a fridge in a cold garage
a fridge will not work right in an un heated garage
Dec 17, 2009 | Refrigerators
Bizarre Refrigerator Problems
If your voltage is around 117v.you are okay.Any time you lose cold air except the freezer you probably need to check your evaporator thermostat and your heater.
Sep 15, 2008 | Samsung RS2556 Side by Side Refrigerator
Refrigerator and freezer not cold
it could be your cold control stuck turn it on and tap it a few times
Dec 11, 2007 | Frigidaire FRT15G4B Top Freezer...
Frigidaire Freezer Runs Warm in Cold Weather
hi there the problem you have is that the temp in the garage is to low, the fridge part of your fridge freezer has priority and will only activate the compressor when req'd ie. in cold weather the fridge may not need to switch on the compressor for days at a time this is when the freezer will defrost.
All you can try doing is having some very low heating in your garage in the cold weather
hope this is of help.
Dec 11, 2007 | Refrigerators
Maytag MSD2756G Side by Side Refrigerator Logo
228 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
