Question about Mitsubishi Televison & Video
How do I manually unlock channels I have Channel 2 through 13 showing in white and I do get those channels however I can not access the ones in blue so Im assuming they are locked how do I unlock those channels manually
  • 8,197 Answers
If I can get the model # I will help you unlock the chanels.
Posted on Dec 11, 2009
Four wires coming from needle to cable, two are shield and two are left and right channels. Which color goes where
Actually it's not to hard to connect them. All you need is a stereo record where you know a sound of something is on the right or left channels. I use to have a Goodies LP where a one of them would say "bounce to the left" and the other said "bounce to the right" these coming on the respective channels.
To set it up just stick the red (right) on one of the cartridge pins and white - left on the opposite side - not underneath it. Then connect the other two to the pins below them. Play your test record. And if the sound which is supposed to be on the right channel come on the left - swap the two red and white wires around.
If the sound sounds (tinny spaced) out then swap the same side wires around.
So if you have say Red Green, Make it Green Red. If it is tinny only on one channel, don't switch the other channel around.
For example the right is tinny - do the above - but leave the other White Blue.
By the way some cartridges do have L and R marked on them and + and - for the channel types. " -" being for the green or blue wires.
Feb 08, 2014 | JVC Audio Players & Recorders
How do I unlock my scanner?
Channel Lockout You can lock out a channel so it is not scanned. Channel Lockout does not erase the frequency from the channel. You can lock out up to 50 channels, including the Priority channel.
Lockout information is retained in the memory when the scanner is turned off.To Lock out a Channel
Example: Suppose you want to lock out Channel 2 because it stops on transmissions you don't want to hear.Press LOCKOUT when the scanner stops on Channel 2.The scanner locks out Channel 2, Then it immediately advances to the next channel that is not locked out, and resumes scanning.In the Manual mode, press LOCKOUT to lock out the displayed channel. Pressing LOCKOUT does not advance to the next channel in Manual mode.L/O appears in the display to indicate the displayed channel is locked out.Whenever you want to search for channels that are locked out, press MANUAL repeatedly to go through all 50 channels. If a channel is locked out, L/O
appears in the display.Restore a Locked Out Channel To unlock a channel so that it can be monitored during scanning:1. Press MANUAL repeatedly to find the locked out channel.2. Press LOCKOUT again to unlock the displayed channel. L/O no longer appears in the display.Restore All Locked Out Channel To unlock all channels, you must be in the Manual Mode.1. Press MANUAL.
2. Press and hold LOCKOUT to unlock all channels. The L/O indicator goes out on any channel previously locked out.
Sep 18, 2011 | Uniden BC248CLT Base Scanner
TV is not responding, turns on and off and does not show picture nor sound, does not move from channel 22-2
Couple of things.
  • Are you on an antenna or cable/sat box?
  • If you are on an antenna, the sub-channel of a local DTV station (22-2) was the only thing the digital receiver was able to pickup on the initial scan of channels.
  • If you are on an antenna, rescan for available channels.
  • If you are on a cable/sat box, and scanned for channels you probably picked up a like channel that is in the same bandwidth as 22-2. Probably not even a channel.
  • If you have a cable or satellite box, hook it up to one of the VIDEO channels using either a Composite AV cable (Yellow/Red/White) or a Component A/V Cable (RED/GREEN/BLUE with RED/WHITE for audio. If you are lucky enough to have HDMI for your source, use that.
  • Going forward, all of your changing channels will be from the SOURCE.
Mar 13, 2011 | Sanyo DP50747 50 in. Plasma TV
How do I unlock channels (pro-2055)
the unlock command is done from the manual mode.
If you scanner is in the scan mode, push the "MANUAL"button to stop the scanning feature.
Next you need to go to the channel you want to unlock. If you are only a few channels away, while in the manual mode, push the up or down arrows to step (one push per channel to be stepped though) to the channel to be unlocked.
A direct method is to enter the channel number on the keypad and then push the "manual" button. The display should show the channel you desire.
If the channel lockout is on, the second line on the display will show "LO+". Push the keypad button marked "L/OUT" once. The "LO+" should change on the display from uppercase to a lowercase "lo+". The channel is now unlocked.
Oct 16, 2009 | Radio Shack Pro-2055 Base Scanner
When I try to set our TV to locate digital channels, the menu skips the channel selection when I scroll through options of picture, audio, channel, lock, setup. All the options are available.
It sounds like your TV is on a different input. If you watch your cable from an external cable box, and this box is plugged into your TV using wires that are yellow, red, and white, or red, blue, green, red and white, you're currently watching TV on a different input than the one used for the antenna. Channels in a TV are controlled by the tuner. The tuner is the silver, threaded, post on the back of a TV, DVR, converter box, or VCR, that you plug an antenna or cable wire to. The tuner contols channels while the other inputs on your TV carry a direct signal like a computer to a monitor. So when you use something other than coaxial cable to connect cable to your TV, you can't access the channel menu while on that input. To access that menu, change the TV's input or source to TV or stop when you see a channel number on the screen. You have to be on the TV or tuner input in order to access the channel menu. If you're on any other input such as, S-Video, AV1, AV2, component (Yp Br Cr), HDMI, etc. you will not be able to do a channel scan. You have to be on the right input or source.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Jul 27, 2009 | Televison & Video
My componet/av only shows black and white on my vizio vp422
The 37" Vizio I just bought has a very confusing feature where the same input can be used as either the Y channel of the component or the full video channel for composite. If you plug a component source into the TV and then select the composite input ("AV" on the remote), you will see a black and white version of the full component signal (makes sense as the Y channel is just the luminance component). As sad as it is, I was stumped by this for a while until I happened to hit "COMP" and got full color. FWIW, the manual warns about this, but it really doesn't emphasize the point. I wonder how many returns they get because of this.
Mar 16, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Channel stuck and can't record shows the same night
Your two problems are related - the DVD player lost contact with the local PBS channel, which altered its internal clock.
Add a red, white and yellow cable from one of the outs on the back of the cable box to the slot marked AV1 IN on the back of the Philips. Then redo the channel programming - press the System Menu button and change Tuning Band to CATV - it will then ask you if you want to do an Auto Channel Set - say Yes.
Once it is done with the channel programming, turn the DVD player to whatever channel PBS is on in your area's cable service. Then go back to System Menu - select Clock Set and go to Auto. Alternatively, you can select Manual under Clock Set and change the date by hand).
-Tha Mp3 Doctor
Sep 24, 2008 | Philips DVDR3320 DVD Recorder/VCR
TV Trouble: Toshiba Flatscreen CRT (Brazilian model: Linha Face)
i suggest if you buy it few months ago that item is under warranty
you to call the toshiba service and try to have changed with another
one or get free service - delfo
Mar 21, 2008 | Televison & Video
Help
Not a home repair take it to a repair store.
May 24, 2007 | Apex Digital PF3230 32" TV
Televison & Video Logo
125 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
