Question about Philips 42PF9630A 42 in. Plasma Television
42 inch philips plasma just turns itself off. when it eventually comes on again it switches itself off again after 20 secs or so.
  • 10,865 Answers
There can be several causes for this, few of which you can do anything about. However, a few things to try:
1) Replace the batteries on your remote control.
2) Try resetting the logic functions on your tv by unplugging it for a minute, then plugging it back in.
3) Try covering up the infra-red receptor on the front of your TV to see if you're getting unwanted signals from the receptor. taping a piece of foil over that area is perfect. If it doesn't stop after doing these two things you'll probably need to take it to a shop.
4) If this does stop it, then look for unexpected signal sources. Have you added a remote control extender? Added a new device to your audio-video system? Changed to a new remote?
I hope this helps. Joe
Posted on Mar 31, 2010
42PF9630A 42 in. Plasma Television: hi there, I have a phillips 42 inch plasma flat...
This is because the power switch operated the socket that your TV is plugged into. Unplug it and plug it in another socket that is not operated by a switch. Appliances should not be plugged into a socket operated by a switch because of the inconsistency of power to the socket. Lights are about the only thing that should be plugged in.
Dec 23, 2017 | Philips 42PF9630A 42 in. Plasma Television
Philips flat screen 42" flashing red light 7 times it stops for 5 seconds and 7 more flashes if i unplug and plug it a few time it will come on
my 42 inch phillips, i turn it on green light comes on for 10 sec then red light comes on and flashes 4 times then stops for 5 sec then repeats.
Apr 20, 2010 | Philips 42PF9631D 42 in. Plasma Television
42"doesn't turn on
your power supply board is going out.
Dec 06, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 42 inch HDTV - "FlatTV" Plasma -- does not turn on.
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Jun 20, 2009 | Philips 42PF9631D 42 in. Plasma Television
Philips Tv won't power on.......
Try plugging in the USB drive and HOPE that the P.O.S.T. during that 2 second period grabs the upgrade, but I must tell you that this is a hail-mary pass.
After that, it's DOAville!!
Mar 29, 2009 | Philips 42PFL5332D 42 in. LCD Television
Gateway Plasma 42" TV
my 5 yr. old 50 inch plasma hd that i paid almost $7000 for started flashing for afew sec. when first turned on.progresivly got worse,flashed for about 30 min. then ok until turned off.after about a month power light comes on fans start then trips off. gateway phone 888 737 6949 wants $250 for power supply $330 for video?board $600 plus for other boards no guarantees.i fixed mine by spending $1000 for a new vizio 50 inch plasma hd.if anyone wants a free dead gateway email me,
archie
Mar 02, 2008 | Gateway GTW-P42M303 42 in. Plasma...
Philips 42 in. Plasma shut down
did u cheak the input cables does it do it on dvd input as well as others ?
Feb 01, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 42PF9630A 42 in. Plasma Television Logo
169 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
