Question about Hoover F7220900 SteamVac V2 Upright Vacuum
Disassembly for repair
After consulting your site, it appears I have a bad turbine. I would like to disassemble to confirm and replace the part. Could you provide disassembly instructions?
Of note, the brush block shaft receiver won't turn. If it were broken, would there be resistance? How is the turbine powered; electrically or via suction?
Thank you for your help.
  • 397 Answers
Sometimes the brush assembly melts because of the way it was designed, could be broke, but u have to take it out and look at the assembly first, turbine is powered through air suction
Posted on Jan 20, 2008
My spin brushes will no work. Have replaced and cleaned screen and brushes are turned on
Is this on a Hoover SpinScrub by chance? If so, those brushes are driven by an air powered turbine. If that turbine isn't turning it may need to be replaced. They can be disassembled and oiled/greased but something like that is better left to a vac shop.
Mar 08, 2016 | Vacuums
Brushes wont spin on the vax duel v 124 model and i dont know how to get to the belt to see if it has broken. There is no reset button on here that I can find !!
V124 /124a. Brushes not spinning. A clicking noise can sometimes be heard with this fault. It is likely that the brush drive unit has developed a fault. For the adventurous it is quite straightforward to repair. Ensure the machine is unplugged from the power supply and remove the tanks. Place the machine down on the floor and remove the brush bar. This clicks into place and is easy to lift out. Remove the screws on the base of the machine that hold the red cover in place. These are posidriv self tappers. Remove the clear plastic V assembly from the machine. This is clicked into place to make removal and replacement easy. Locate the turbine assembly and underneath the machine remove the screws that hold this in place. Disconnect the two small rubber hoses on the turbine assembly and gently pry out the turbine. The turbine can be opened up by removing the self tapping screws holding it together. Do this on a well lit bench or tabletop
Gently open up the turbine housing by lifting the black clips slightly. Keep the turbine level while you are doing this. Inside is the black plastic turbine blade. Remove the two gears and the small bearing and place to one side. Inspect the turbine blade for cracks or damage. If cracked the turbine blade can be repaired using a hot soldering iron to 'weld' the plastic. Ensure the repair is smoothed off by using a flat file. A tiny amount of light oil can be applied inside the turbine casing. Then reassemble the turbine blade, gears and bearing and clip the housing together. Replace screws in turbine housing. Refit turbine into the machine Replace machine screws, red cover. clear V assembly clicks back on. Test the machine to make sure that the brushes rotate. If the turbine is beyond repair a new one can be obtained as a spare part
Sep 21, 2011 | VAX Appliances Vacuums
Beater brushes not turning on the wife's Hoover Steam Vac model F5905-900. Found one prior ''solution'' stating that it sounded like the belt was bad. That was my original thought, but on checking...
This one I can tell you about from personal experience with that generation Hoover Steam Vac. After using it about 7 or 8 times my brushes stopped turning also.
I disassembled it (kind of like disassembling a Chinese puzzle box) and found that the Turbine which develops the torque for the brushes simply has worn out. I replaced the part and it works fine now. Unfortunately unless you are familiar with that sort of repair it's high on the difficulty side. When I took it to a local shop they wanted about $150 to repair it. That was more than half the price I paid for it. It's simply not a very good design. Hoover wont' talk about them yet they are still selling them.
The least expensive place to purchase a replacement part is at: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=250648382497&rvr_id=&crlp=1_263602_263622&UA=%3F*F%3F&GUID=70355e091290a0aad3175ab7ff9f985a&itemid=250648382497&ff4=263602_263622.
The repair shop wanted to charge me $60 for the part.
It seems that the manufacturer is ignoring the problem and it's a great claim for a class action suit against them.
Regards
Zashiban
Jun 25, 2010 | Hoover F5905-900 Vacuum
After cleaning my steam cleaner, the brushes won't spin. They snap in but when turned on won't spin.
Hi There,
Here's how you may diagnosis your Hoover SteamVac brushes when they don't spin. It's either the brushes are dirty and need to be cleaned, the brush block itself has gone bad and needs to be replaced, or the internal turbine that spins the brush has gone bad and needs to be replaced.
Here's a step by step instruction on how you can diagnosis the brushes not spinning:
http://www.fixya.com/support/t4286338-hooverspin_scrub_brushes_always_stop
If you need to replace the turbine, here's a link to a repair that I did on how to replace the turbine assembly:
http://www.fixya.com/support/r4530769-diagnosis_fix_hoover_steamvacs_when
I hope this helped you. Please leave feedback, or rate my repair helpful if this answered your question. If you need further help on this repair, please just use the comment field on the repair page and I'll be more then happy to walk you through some more advanced diagnosing that you can do.
Thanks so much,
Chris Jones
goVacuum.com
Apr 27, 2010 | Hoover F7425-900 SteamVac V2 Widepath...
Brushes are not spinning. think the belt is off or broken. how do i access the belt?
There is no belt in this machine. The brushes are turning by an air driven turbine. The turbine has a pivot bushing made of steel inside of it that gets rusty because of the water that is running through it. The turbine will have to be replaced and they are expensive. Unfortunately, replacing the turbine and not a lasting solution. It will do it again and again. It is designed poorly.
Dec 03, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Power Drive Supreme - Locked Up!!
Q: Are you talking about the turbine powered hand tool that attaches to the hose? If so, just squeeze the two round pins on the sides, and the housings will separate.
Oct 03, 2009 | Hoover U6311-930 Power Drive Bagged...
The brushes stopped turning
just repaired mine today same problem.
Turbine drive shaft which drives two sets of plastic gears and which in turn make the scrub brushes rotate has sealed ball bearings and I guess from an evidently poor design moisture some how entered plastic gear casing and the sealed bearings froze up which evidently aren't sealed all that well. Anyway (turbine drive after easy removal from unit 8 screws on bottom one on top can be disassembled by removing 4 screws around gear casing allowing access to the plastic drive gears and the bearings) You can make a decision from there of whether or not a new replacement turbine is a better way to go.
The entire turbine unit can be purchased online for a very reasonable price if you look around the Web.
Dec 19, 2008 | Hoover F7431-900 SteamVac Vacuum
Hoover F7431-900
If the screen is not dirty, and the flapper valve to the turbine inlet is open, then the problem is mostly a stuck turbine impeller. The turbine impeller on my F7431-900 has seized TWICE!! The shaft for the turbine is not made of stainless steel, therefore is subject to corrosion. If you have a handy husband or boyfriend, give it to them, because some disassembly is required to access the turbine unit. After the turbine is removed and opened up, get some P'Blaster and squirt is on the shaft. P'Blaster is a rust removing solvent and is great for freeing up rusty nuts and bolts. Allow the P'Blaster 20-30 minutes to penetrate the corroded shaft. Then, grab the impeller and wiggle it back and forth, until free rotation is achieve. The last time my brushes stopped rotating, and I disassembled the turbine, it was really siezed up. I thought I was going to need to buy a new impeller assembly. But, that P'Blaster is really great stuff for breaking up corroded parts (it's like WD-40 on steroids!). I did need to give the turbine's impeller a good twist to free it up. If you can't get the turbine impeller to rotate, then buy a new one (about $27.00). Then, you can just install it and save a bundle on labor. I think I want to become a Hoover vacuum repairman. Their business must be booming because Hoover is putting out a poorly designed turbine unit. Boo, Hiss...... shame on Hoover for selling us **** like this.
PS You can get P'Blaster at any auto store, like Pep Boys, Autozone, etc.
Jun 29, 2006 | Hoover F7431-900 SteamVac Vacuum
Hoover F7220900 SteamVac V2 Upright Vacuum Logo
377 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
