Question about Freezers
Freezer I have an under the counter marvel freezer. The freezer comes on but it is not as cold as it should be.
  • 63 Answers
Check the condenser (outside coil) and see if its clean. If its dirty then clean it. If that doesn't help then there could be a more serious issue with it. maybe would be best to call a service tech to look at it
Posted on Jan 28, 2008
To cold
Try 2 switch off (plug out) leave it few hour then switch on (plug in) again sometime it just error.
Dec 04, 2012 | Haier Refrigerator Fridge Personal Mini...
Water coming from bottom of my freezer
Is it defrosted? If the water is coming from under the base, check underneath. The insulation may be broken down and condensing on the cold base
May 13, 2012 | Frigidaire Freezers
Turned off freezer, because didn't need to use it. went to turn it on again but it wont get cold, also it's out in the porch during the winter. so it really cold out there.It does come on but won't get...
Good day,
If you can hear it running but does no cooling then either you have lost the refrigerant charge, or the system has developed a restriction somewhere in the lines. It will require the attention of a professional.. If the machine is under 5 years of age, then the factory will cover the repair.
Call your selling dealer for a warranty repair.
Nov 12, 2010 | Frigidaire 5 cu. ft. / 142 liter Chest...
Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine: my hoshizaki under the counter ice machine gradual...
Check condenser coil which is the coil on back with fins, sometimes with metal.mesh filter. If dirty or clogged up clean filter, blow out with air or brush and rinse out, careful not to bend fins. Sounds like issue to me. Unless the dump valve may be leaking by
May 18, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Miele F7131 S The red alarm and the orange -32 degrees orange light on the front of my under counter freezer keep flashing. I have defrosted it. It appears cold but the lights will not stop flashing.
Freezer Temp. shoud be 0 to -5 Deg. if to warm it will set off the alarm. try unpluging or turn off power to freezer for 1 or 2 min. to see if it will reset.
May 17, 2010 | Freezers
My hotpoint under counter freezer isn't freezing properly
A freezer has a very simple operating design and there are only 2 customer serviceable components.
1. Make sure the cold control is set at the proper level.
2. Make sure that the door seal is making good contact with the cabinet. You can apply a thin coat of Vaseline to the door seal to help tight closure of the door.
Keep the door opening to a minimum during extreme heat conditions. Any small air leak can drastically reduce the operating norms during extreme heat conditions.
That's about all that you can do to regain control, the rest will have to be performed by a refrigeration tech. if you are still dissatisfied.
Jul 05, 2009 | Amana Freezers
TRUE under counter FREEZER TU2-27F
Are both evaporator fan and condensor fan running?You stated that you topped off the charge.Assuming the charge is ok, the next thing to check would be the expansion valve.May not be metering the freon properly.A faulty expansion valve can trick you into thinking the unit is undercharged.It may be partially open and starving the evaporator.(Not freezing the water totally)You should have a even coating of frost on the evaporator coil when running.Hope this helps,let me know if i can assist you any further.
Dec 10, 2007 | True 12 cu. ft. / 340 liter Commercial...
Freezers Logo
43 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
