Question about Canon PIXMA iP4300 InkJet Photo Printer
Top paper feed does not feed 1 at a time, feeds multiple sheets or envelopes
    Problem Solver:
  • 14 Answers
Check for obstacles - top trays got biggest disadvantage: u may easily drop something into it. I`ve found 1GB memory card in mine
Posted on Dec 12, 2009
How to install paper in oki microline 320 turbo printer
Paper Loading
Rear Feed, Continuous Forms
Use the rear-feed path for printing on single-thickness,
continuous-form paper.
Use the single-sheet path (top feed) for graphics or charts.
! If you have paper in the paper path, be sure to remove it
before installing rear-feed paper.
1 Lock Lever
2 Upper Tractor Cover
3 Pins
4 Lower Tractor Cover
32T-26.eps
1 Move the paper lever to the position marked "REAR."
32T-11.eps
2 Grasp the tabs lift off the paper separator.
3 Pull up on the lock levers and open the tractor covers.
Then, move the right tractor to fit the width of the paper.
32T-27.eps
4 Place the first two holes in the paper over the tractor pins
on either side. Close the tractor covers.
32T-29.eps
5 Move the left tractor to align the edge of the paper with
the appropriate reference mark (1). Then, push back the
lock lever.
32T-29A.eps
6 Adjust the position of the right tractor to center the holes
in the paper on the pins. Then, push back the right lock
lever.
32T-29.eps
7 Install the paper separator. Place the wire guide (1) on the
pull-up roller assembly (2).
32T-31.eps
8 Press FF/LOAD. The paper feeds into the printer.
! The factory default setting for the Top of Form (where
the printing should begin) is one inch down from the top
of the page. To change the setting, see "Using Your
Printer, Top of Form (TOF)."
Top Feed (Single Sheets)
Use the single-sheet path for letterhead stationery, memos,
and individual envelopes.
! If you have continuous-form paper in the path, press
PARK to remove it before loading single sheets.
1 Make sure the printer is on and deselected (SEL light off).
2 Place the paper lever in the position marked "TOP."
32T-12.eps
3 Open the carriage cover. Raise the paper separator to the
single-sheet position.
4 Make sure the wire feed guide (1) is secured in the sheet
guide.
5 Adjust the paper feed guides (1) for the width of the paper.
Place a sheet of paper in the separator. The paper will feed
into the printer.
32T-15.eps
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 04, 2011 | OKI MICROLINE 320 Turbo Matrix Printer
When i give print command the paper was jammed in printer.
The following sections describe how to load media into the different input trays. CAUTION: If you try to print on media that is wrinkled, folded, or damaged in any way, a jam might occur. Priority feed slot The priority feed slot holds one sheet of media up to 163 g/m2 (43 lb) or one envelope, transparency, or cardstock. Load media with the top forward and the side to be printed facing up. To prevent jams and skewing, always adjust the side media guides before feeding the media. Back to top 150-sheet main input tray The input tray holds up to 150 pages of 75 g/m2 (20 lb) paper or fewer pages of heavier media of 25 mm (0.9 inches) or less stack height. Load media with the top forward and the side to be printed facing up. To prevent jams and skewing, always adjust the side and front media guides. NOTE: When you add new media, make sure that you remove all of the media from the input tray and straighten the stack of new media. This helps prevent multiple sheets of media from feeding through the printer at one time, reducing media jams.
Also go to this link to do a Printer Cleaning
Dec 03, 2010 | HP LaserJet 1020 Printer
Can't print envelopes
you need to select tray #1, manual feed.
tray #2 is auto feed- 8x11 sheet paper.
Jan 29, 2009 | Dell 3100cn Laser Printer
Paper is feeding unevenly on black & white prints
If the paper is lodged too far into the printer and can't be removed:
  1. Press the power button to turn the printer off.
  2. Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
  3. Close the front cover.
  4. Press the power button to turn the printer back on.
  5. Resend your document to print.
Ensure that:
  • The paper is a recommended paper for inkjet printers.
  • You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
  • The printer is on a flat, level surface.
  • The left paper guide is against the side of the paper.
  • You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
  • The left paper guide does not cause the paper to bend in the sheet feeder.
  • Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
  • Envelopes or the appropriate specialty papers are selected in the printer driver.
  • You are using a paper or envelope size supported by your printer.
Important: Your application may not be designed to print envelopes. For help, consult the documentation that accompanied your application.
May 21, 2008 | Lexmark X4270 All-In-One InkJet Printer
Brother dcp 7010 How to print envelopes
Use the manual feed slot to print or copy on labels,
envelopes or thicker paper.
Slide the paper guides to fit the paper
size.
Using both hands put the one sheet of
paper in the manual feed slot until you
feel the front edge of the paper touch the
paper feed roller.
Let go of the paper
when you feel the machine feed the
paper in a short distance.
May 16, 2008 | Office Equipment & Supplies
Paper feed on Canon i 350n ink jet printer
Ensure that:
May 13, 2008 | Canon i350 InkJet Printer
I have a Lexmark X3550 printer There is a paper way down inside that cannot be reached Tried the automatic remove and it does nothing. What should I do?This machine is only a few months old.
Bending the bottom exit tray will allow it to be removed. Simply remove tray and wipe rollers right in front of the bar that the ink slides back and forth on. Most printers get a lttle dust on the rollers then they wont feed. Hope this Helps.Sincerely Brian @ Game-On Computers.
Apr 26, 2008 | Office Equipment & Supplies
Won't feed paper while printing
I just obtained a printer with the same problem. When I opened it up I discovered a plastic gear that had cracked and was not turning the main paper roller as it was slipping. It looks like the solution is to replace the roller if you can find one or to repair the gear and epoxy back onto the roller. I am trying the later.
Apr 22, 2008 | Lexmark X83 All-In-One InkJet Printer
Paper jam
Turn the printer off and open the access cover.
Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
Watch the paper as it feeds through and try to determine where the jam is occurring.
Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
Turn the printer off.
Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Ensure that:
Mar 24, 2008 | Office Equipment & Supplies
Automatic Paper feed
Check the feeder roller inside the printer for any foreign substance stuck to the roller, this may cause it not to grip properly. You can also try a few sheets at a time and make sure the paper tray is gripping the paper, but not too hard. If this fails, the roller may be out of place somewhat, try to reposition it. Let me know how you get on.
Sep 06, 2007 | Samsung ML 1210 Laser Printer
Canon PIXMA  iP4300 InkJet Photo Printer Logo
229 people viewed this question
old marine
old marine
