Question about Canon PowerShot A520 Digital Camera
Card error. Memory card locked - Canon PowerShot A520 Digital Camera
    Guru:
  • 1,738 Answers
There is a slide switch on your SD stick. Make sure it is not in locked position.
Posted on Dec 11, 2009
I keep getting memory card error and memory card locked
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Jul 22, 2011 | Canon PowerShot A460 Digital Camera
Tip
Memory Card Locked / write protected error.
Hi due to so many questions asked about this here it is. How to deal with memory card locked/write protected error.
SOLUTION 1 - Unlock the memory card.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.
SOLUTION 2 - Toggle the lock switch.
If the lock switch is not on lock:
1. Slide the switch up and down. Repeat this 3 times.
2. Let it stay on the Lock position for 30 seconds.
3. Slide the switch up to unlock the card.
4. Try to transfer files into the device.
For non-SD cards: Format the card
The data on the memory card may be corrupted.
WARNING: Formatting will delete all the files in the device. Backup all your data before formatting.
Memory card write protected, memory card locked, memory card will not read, can't use memory card.
on Jan 10, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
It says memory card error - card is locked But the memory card is not locked
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Dec 26, 2010 | Canon PowerShot S2 IS Digital Camera
My canon camera keeps displaying 'memory card' error and 'memory locked', what do I do?
check you sd card there is lock and unlock switch. unlock that button
Aug 08, 2010 | Canon Cameras
'memory card error - card locked!'
pull the card out
find the slide button on the side and slide it to the "unlock" position
put card back in
enjoi
Mar 04, 2010 | Canon IXUS 80 IS Digital Camera
Display says memory card error card locked
Format memory card by using card reader, then try it.
Oct 22, 2009 | PNY 4GB Secure Digital High Capacity...
Memory card error
Did you format the card in the camera before trying to use it?
Sep 02, 2009 | Canon PowerShot A700 Digital Camera
Locked Memory Card
I use a Nikon D300 and have Sandisk Compact Flash memory cards. i ahve not come across this problem but would suggest that you insert the memory card into your camera and reformat the memory card. This should clear any errors in the system BUT IT WILL ALSO WIPE ANY PHOTOGRAPHS YOU AHVE TAKEN when formating the memory card.
Oct 20, 2008 | SanDisk ULTRA II 4GB Compact Flash Card...
Canon Camera - Memory Card error & Card locked error
Try reading the card independent of a camera i.e. on a computer or a photo kiosk to determine if the card is readable damaged
Jan 07, 2008 | Canon PowerShot A410 Digital Camera
Memory card error displayed
There is a little slide switch on the side of the memory card. Good luck!
Nov 25, 2007 | Canon PowerShot A410 Digital Camera
Canon PowerShot A520 Digital Camera Logo
42 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
