Question about Motorola Mobility Rival A455 Cell Phone
Just about 2 hours ago , my friend was using it,and i was right next to her as she was. And she gave it back to me, and the screen was black and everything else is working but the screen.And i can't fix it.I tried taking the battery out ,but the phone still didn't do anything.I charged it,nothing. I have no idea what to do!I just hope it's not broken.Like everything is workng fine but you can't see the screen!It's just black like the phone is turned off,but it's not!Help!!!!!!!!
Black Screen sort of
The back light is not working. Possible repair at a Sony repair centre.
Feb 25, 2015 | Sony Computers & Internet
My friend gave me a windows embedded ce 6.0 netbook, how do I log in onto my wifi?
Select Connections from the tabs across the bottom. Select WiFi. Find your own wifi from the list of available networks (SSIDs) and select and hold it. Then select Connect. In the next screen, make sure The Internet is selected and click Next. On the Configure Network Authentication screen, make sure Authentication is set to Open and Data Encryption is Disabled and click Next. On the next screen, click Finish. This will bring you back to the Configure Wireless Networks screen. Wait a few moments while your phone connects. Once complete, the status will display as Connected. Click ok from the top right section of the screen then close the Settings window with the x in the top-right section of the screen. Once you've joined a WiFi network manually, your smartphone automatically joins it whenever the network is in range. If more than one previously used network is in range, your pc joins the one last used.
Sep 28, 2014 | Computers & Internet
Gateway 6920
The dying hdd cause some problems. Replace the hdd.
Feb 21, 2014 | Computers & Internet
Right half of screen is Black with a White vertical stripe
Yeah, I have this exact same problem, except my mom slammed my laptop shut in frustration around half an hour ago, so that's why it's like this. The right half of my screen is black with two colorful stripes (mostly white), but the left half is visible. I've researched a bit and found out that this is because the LCD in your monitor has burnt out, and since you don't have a monitor to attach, the only thing you can do is to go to where you bought the laptop and either get it fixed for free or return it for a brand new one (if your warranty still stands). If not, you might as well get a new laptop. I think my warranty has expired, so I'll get a new laptop, hopefully.
Hope this helps!
~Sam.
Jun 08, 2009 | HP Compaq FP 7317 17" Flat Panel LCD...
No display on Philips Freevents X59
It the back light or its converter stop working. Do you have any dark dispaly which can been if yoy see carefully in light?
Apr 12, 2009 | Computers & Internet
Blank screen
if its not too late (under 12 months) call acer right away and get warranty processed. they will fix any hardware issues its having for free..make sure you have a data backup first. you can also try a factory restore aswell and see if that corrects the issue (again make sure you have your data backed up).
Apr 09, 2009 | Acer (ACERMOTHERBOARD)
Lg lcd tv picture goes in and out with "boxes" on the screen
This sounds like the power supply that feeds your back-light is going out. This repair should be done by a qualified technician
Mar 13, 2009 | LG RZ32LZ50 32 in. LCD Television
Screen Works With One Computer But Not This Mine
Soundes likw interference do you have electrical high lines near that area.
Feb 13, 2009 | Gateway FPD1765 17" Flat Panel LCD Monitor
Motorola Mobility Rival A455  Cell Phone Logo
107 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Steve Berry
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
