Question about Hardware & Accessories
Need dado throat insert for 113
Need dado throat insert for older craftsman table saw
  • 142 Answers
Why not just make your own out of 1/4" plywood
trace out the insert but don't cut a slot
install it on the saw with the blade all the way down
turn on the saw and raise the blade to cut out the insert
Posted on Dec 11, 2009
Need to purchase delta 36-979 dado head table insert for 10' table saw
Use an appropriate pc of mdf that is same thickness of throat plate already installed. Use a router to flush trim to that throat plate. Now, insert and hold down with clamps and scrap panel. Raise Dado head ,while running, enough to do the job. This completes a zero clearance throat plate. No need to buy!
Dec 31, 2012 | Delta 36 979 10 Inch Left Tilt 1 1/2...
I just received my new saw 22116 however their is no dado insert which I use a lot. on other saw i have bought the insert was part of the saw. i have tried to find it in parts so far no luck. ken parkins
If you are unable to buy an accessory throat plate from Sears for your saw, you might like to look online at www.manageyourlife.com. You may be able to find accessories there that your local store doesn't stock.
I'm not familiar with your particular saw and it's throat plate, but you should know that many woodworkers make their own inserts using 1/2" plywood cut to fit the shape of the throat plate. You can trace your existing plate onto the form, then carefully cut it out and sand to fit. Insert small screws from beneath the plate to level it in position, level to the table top. Then cut a slot in the new throat plate by raising a small blade up through the new plate. Sometimes I use a skilsaw blade or dado blade to make the first cut. Do this only when it is safely held down with a long board clamped over top of it, while you raise the spinning blade up through the new throat plate to cut a slot or groove, as the case may be. If you can't lower the plate over the blade in its lowest position, you can either use a smaller diameter blade to cut through it, or rest the plate lightly against a blade lowered to its lowest position, then hold the plate in place safely with a long board or piece of plywood that rests lightly against it and holds just enough pressure that you cnn start your saw with the throat plate against the edge of the blade, then exert slight pressure downwards to fit the throat plate fully into the throat, cutting through it into the backing board, then you'll be able to raise the blade through the throat plate. This is a dangerous operation and should only be undertaken with safety equipment such as safety glasses or goggles in place, and alway keep your hands away from the moving blade and exerting force away from the moving blade. Exercise good judgement and caution and you should be able to plunge the new throat plate into position over the moving blade, using the backing board as a safety device/push stick.
If you are unsure about any of these instructions please don't hesitate to ask further, or refrain from taking any actions on your own, and in any event, proceed fully at your own risk.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 11, 2011 | Craftsman Professional Premium Hybrid...
I bought a craftsman dado blade set but can't find the instructions and I have no idea how to use it. Is it possible to get instructions
Dado blades are used in a variety of saw applications. Commonly tables saws. The manual for your table saw should identify if the saw is capable of using this blade-set Never used dado blades in a saw that is not intended for them as this can result in severe injury to yourself and or damge to the tool. If your are unsure if your saw can accomodate dado blade please post your make and model of saw and someone will try to help you.
Dec 29, 2010 | Craftsman Garden
I have a craftsman table saw model 113.27870. I need a table insert for a dado blade. I looked on the sears website and it said parts for this saw are no longer available. Will a table insert for a newer...
Maybe you could try using the outline of the regular insert to cut a new insert out of a piece of polycarbonate (lexan) or ABS plastic. The clips that hold my dado insert barely hold it in place on mine, and I've seen other saws that use plastic.
Aug 02, 2010 | Craftsman 10" Table Saw
What kind of dado blade can I use on my craftsman 10 inch table saw model no. 137.248100/ with stand
You have a 5/8" diameter arbor. You can use any dado blade that will fit. That said here's a few things to bear in mind.
8" diameter dado stacks are pretty standard for 10" contractor table saws. A dado stack is typically about 13/16" wide at most. It makes sense that the wider your blade is, the more power it takes to cut through the wood.
If you were to use the full width capacity of your Dado stack (13/16") a 10" diameter stack would bog down. A 8" stack has a faster rotation at the cutting edge because of its smaller radius. So, you don't bog down when you're making a wider cut if you use a smaller diameter.
If your machine was really underpowered, you could go down to a 6" stack which would cut your power requirements even more, but limits the depth of cut.
If this post was helpful, please vote. Thanks.
Mar 28, 2010 | Craftsman 10" Table Saw
I need a switch assembly for my 9 inch table
hereis the web site for Sears and Craftsman.
http://www.searspartsdirect.com/partsdirect/index.action?pop=flush
( I would have looked it up but you part # is incomplete. the # should be 113.###### the 113 is followed by . and 6 more numbers.)
Jun 05, 2009 | Saws
Dado blade installation
Yes. normally an eight inch stack dado set is used on a 10 inch saw. You will also have to purchase or fabricate a special throat plate (non-metallic) to accomodate the extra thickness of the dado set.
The number of blades used, and therefore the thickness, varies depending upon the task at hand.
Make sure to use the factory supplied nut and washer to capture and tighten the dado set securely on the arbor.
Be very cautious in the use of dados. Do not raise the set higher than 1/4" or so until you are familiar with the use of a dado set. Try to avoid so-called "wobble" dado sets. They are IMHO more prone to dangerous kickbacks and harder to adjust than a stack dado set with dado shims.
Mar 21, 2009 | Delta TS200LS Shopmaster 10 Inch Portable...
Hardware & Accessories Logo
603 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
