Question about Dryers
How to check belts ?noisey
My mytag electric dryer make alot of noise .I assume one of the belt .How can dissasample it to check!
  • 55 Answers
Ok sound like the drum rollers need replaceing
take the screws off back that hold down top lift off top
unscrew front of dryer , it will come off
pull drum out after takeing off drum belt
replace rollers and belt
be sure to notice how belt goes on before taking it off
take model number and make of dryer to appliance parts store
get roller kit and belt
Posted on Jan 21, 2008
Drum is making alot of noise as it goes around . what do I look for?
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch.
Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt.
Remove the drum and belt and this will expose the drum rollers, idler arm
pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the
idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go
to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots
or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably
only need lubrication. Lubricate the shaft of the rollers with a good grade
of machine oil such as 3 in One oil.
Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Jan 13, 2011 | Kenmore Dryers
Whirlpool AWZ 3513 dryer has noisey whining motor
It may not be your motor that is whining, it may be the drum rollers in need of lubrication or maybe the belt has slipped off of one of the pulleys.
pulley and motor.
Please rate me
Dec 28, 2010 | Whirlpool AWZ7303 Electric Dryer
My dryer is making alot of noise as if there is a bearing going out. When I open the door, the drum stops almost immediately. I have the back off so I can see the belt is still on and I can turn the belt...
pulley and motor.
Please rate me
Dec 27, 2010 | GE Dryers
I blew a fuse last night and had to reset the breaker....I went to dry clothes this morning and the dryer is dead, wont come back on after being plugged and unplugged. I reset the circuit breaker too and...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 15, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Very noisey
the belt is wrapped through a belt tensioner with a roller. The bearing in the roller is bad causing the noise you hear. Sears sells the tensioner roller with the belt which is recommended to replace both at the same time
May 14, 2010 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Dryer making noise when turned on
you have to specify what make your dryer is to be able to answer question
Feb 06, 2010 | Dryers
Vibrations and noisey
CHECK DRIVE BELT FOR WEAR AS THIS MAY BE THE CAUSE.
Oct 13, 2009 | Miele Novotronic T1515A Electric Dryer
I have a Mytag Dryer MDE9606AYW The drum won't tumble
Unplug the dryer, open up the top panel. check if the belt is broken . replaced it.
Feb 24, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Question on posting...
If your dryer is kenmore its probably not the blower this dryer has 2 drum rollers at the back that the drum rides on they could be noisey also theres a idler pulley that the belt uses as a tensioner that could be noisey they sell a kit with all those parts thanks THE APPLIANCE DOC
Sep 02, 2008 | Kenmore 63012 Electric Dryer
Dryers Logo
133 people viewed this question
Top Dryers Experts
