Question about Samsung RF265AA Bottom Freezer French Door Refrigerator
The left side door has dropped and the piece that closes the gap between the two doors will not operate properly. It leaves the gap open and the refrigerator looses coolness. Need to know how to realign door to close properly.
  • 999 Answers
Check the lower hinge of that door for a broken closer cam. The upper hinge is adjustable and adjusting the corners in the front will shift the cabinet to align the door also.
Eric
Posted on Dec 11, 2009
  • 4,070 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
The 2 doors on my Maytag SXS aren't even in the front when they close. The refig side sticks out. The doors are otherwise level and even in all respects. I adjusted top & bottom hin
Hello Joe;
My name is Peter. I am a retired field service refrigeration technician.
This was your first time setting the gap between the doors. So, I will share with you the various ways to adjust the doors gap.
1.) On the bottom of some doors there are adjustment screws for pitching the door left or right to set the gap. This was a good design idea, but there is not locking nut to hold the setting. Opening and closing the door will remove the setting. So, if you have these adjust screws, we will forget them.
2.) Lets try this: Adjust the front leveling bolts. Loosen the top of the door hinges. If the gap is smaller at the top, lower the leveling bolt up on the left hand side. Turn the bolt counter clockwise to raise. Pound on the doors to free them to adjust. If the gap is smaller on the bottom, on the right jacking screw, raise the jack bolt by turning the jack bolt clockwise. Once again, pound on the door to free for the adjustment. Then tighten to top door hinges.
3.) OK, This did not set the gap. The gap between the door is different depending on the model. Determine the gap which you would like to set. Using something solid like pieces of wood (do not use cardboard it will crush), loosen the top hinges, evenly space the wedges and tape them to the door. Now tighten the top hinges and remove the wedges.
4.) Ok, This did not set the gap. Look on the bottom of the door at the hinge. You have a matching set of grommets. These grommets interlock when the doors close to keep the doors closed. These are high wear components. The doors rest on these components. One grommet set may be more warn than the other affecting the door gap
Dec 04, 2014 | Maytag MSD2542VE Side by Side Refrigerator
Want to switch the side the door opens on my lg dryer
The directions for reversing the door can be found on page 13 and 14, with pictures of the operation. Open the door to reverse. Check the 10 screws that need to be removed (6 on the left, 4 on the right). Remove 4 dummy screws with a screwdriver. Remove the two screws from, and disassemble, the latch. Hold on to the hinge while removing 4 screws from the hinge (to prevent the door from dropping). Remove the door from the cabinet cover. Move the door to the left side and insert a hinge into a hinge hole. Hold on to the hinge while screwing down the hinge (to prevent the door from dropping). Insert the latch to the right side and install the screws. Screw down the 4 dummy screws to the right side. Check that the door closes and latches properly.
Feb 02, 2013 | LG SteamDryer 7.3 Cu. Ft....
Bobbin cover door is stuck on Bernina 930 Electronic, and won't open. Can you help me?
Tricky !!! I dont know why the door is stuck, but its possible that the spring-loaded plunger in the top of the bobbin door is stuck into the cover of the free-arm. If there is suficient gap between the top of the bobbin door and the free-arm cover, you could try sliding a thin piece of metal or a very small flat-bladed screwdriver between the two, in the dead-centre of the bobbin door - that's where the plunger is located. By gently manouvreing the screwdriver in, you might be able to release it - be careful, because it's possible that the retaining circlip has dropped-off the bottom, in which case, the plunger and its pressure spring might fly out when the bobbin door opens. If that doesn't work, you could try unscrewing and removing the stitch plate and, again, with a small flat-bladed screwdriver, see if you can release the free-arm cover catch that's next to the top-left-hand-side of the bobbin door, but that's a very risky approach, because the feed-dogs will be in the way and you dont want to mangle any of the hook/shuttle parts etc. You need to find out why the bobbin door is not seated properly - it may be that the bottom hinge that also carries the hook/shuttle retainer has come out of the left-hand hinge mount in the free-arm. Good Luck.
Nov 28, 2011 | Bernina Sewing Machines
Both the freezer and fridge doors hinge on the right, and the left hand side has sagged a little so neither neither door is sealing properly. How do I adjust the doors to raise the left side of the...
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it's wore out and doesn't work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
May 04, 2011 | Refrigerators
I have a LiftMaster garage door opener.When the door closes it is not completely closed on the right side. It has about a 1/4" gap at the bottom. It starts closing evenly but when it is about 2 feet...
SOUNDS LIKE YOU MAY NEED A SERVICE TECH.
IF THE CABLES ARE NOT RUNNING PROPERLY ON THE DRUMS IT WILL CAUSE THE PROBLEM YOU DESCRIBE. OR THE DOOR COULD BE CATCHING ON SOMETHING (DOOR JAB, TRIM ETC.) AS IT CLOSES.
I DON'T RECOMEND TRYING TO ADJUST THIS YOUSELF A PRO CAN DO IT IN ABOUT 10 MIN. IF YOU START MAKING ADJUSTMENT WOITHOUT KNOWING EXACTLY WHAT YOU ARE DOING YOU WILL PROBABLY JUST MAKE IT WORSE.
THE SERVICE CALL SHOULD BE $ 50.00 - $100.00
ALSO DON'T CALL A HANDYMAN ETC. ONLY A QUALIFIED DOOR REPAIR TECH.
HOPE THIS HELPS
Oct 26, 2010 | liftmaster Chamberlain Garage Door Opener...
Hello, my fridge door is off kilter. I can see that is starting not to seal properly with the box. We've removed as much weight as we can off of the door. I've also tried to slide a shim underneath the...
Feb 27, 2010 | Refrigerators
Refrigerator top freezer door slightly rubs to inside freezer bottom while closing the door that opens on right side. Due to this after closing the freezer door, the door opens less than a mm near the left...
I think I can help. Usuly the doors have been swapped around in this case. look closely at the freezer door on hinge side. there should be a small metal piece that covers the hinge to prevent anything from jamming hinge. this shield also serves as a spacer. this is what sets the door at the correct height. if the piece is missing you can have your local appliance dealer order one for you. it only takes a few minutes ts to install. you will need to remove the freezer door to do this. Hope this helps and good luck.
May 07, 2009 | Whirlpool ET1FHMXLQ / ET1FHMXLT Top...
Door mechanism
wind metal strap around plastic bush and hook above hinge
Sep 08, 2007 | Candy 24 in. CD622 Free-standing...
Samsung RF265AA Bottom Freezer French Door Refrigerator Logo
913 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
