Question about Sony PSP (Piano Black)
When playing a game everything's fine but when i push the home button the pad above my analog stick will not allow me to select yes
    Problem Solver:
  • 24 Answers
Why analog stick?
try to use buttons key
Posted on Dec 12, 2009
Ps3 controller manual
You plug in the usb cable to charge the controller and connect it to the ps3 for the first time. You use the left analog stick to move around the dashboard when the ps3 is turned on and the 'X' button to change settings, go to the online browser, playstation store, or start a game. You can back out by pressing 'O' or holding the 'PS' button, which allows you to change a controller number (say controller #1 to #2 with two controllers), turn off the system or turn off the controller. Press (not hold) the controller to look around the dashboard while in a game and select say "Quit Game', or go into settings and change something around to your liking. Every game also comes with the controls and for what the buttons are. (Stick on left is the, "Left Analog Stick," right is "Right Analog Stick," from right to left starting at the green triangle shaped button is the, "Triangle," "Circle," "X," and "Square," buttons. The four buttons on the left going in all directions is the D-pad, and the triggers on the back going from the top left to bottom left and top right to bottom right are, "L1," "L2," "R1," "R2").
Feb 05, 2013 | Sony PS3 DualShock3 Wireless Controller...
Analog stick are doing the opposite of what they should
I had this problem also on my sons xbox.. You must go into profile and then edit the settings.. In the default game setting you select the actions tba and have movement set as the left thumb stick.. His was set to the right thumb stick.. All sorted now.
Jul 03, 2012 | Microsoft Xbox 360 Controller
Problem with logitech dual pad right analog
Try to disassemble the pad. Reseat the analog stick and re-assemble the pad.
May 12, 2012 | Logitech Dual Action for Pc (963292-0403:)...
I play Call Of Duty Black Ops and You usually need to sprint by pushing in the Left Analog stick and your direction. For some reason my controller is pressing multiple buttons when I push the analog stick...
You have a couple of options here. Sounds like your controller may be on the fritz, so if you have the money, I would suggest purchasing a new controller.
Otherwise, in the game options, you can re-map any function to another button on your controller. I would recommend remapping the sprint button to some other button that you don't use for that game.
Dec 10, 2010 | Sony Playstation 3 (PS3) Console
V3 fx steering wheel for PS2
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 Here are all of the instructions enjoy. clip_image001.gif
To adjust the V3 Racing Wheel 2's sensitivity follow the instructions below. ( 3 preset sensitivity selections )
1. Press and hold the SET button for about 1 second to enter the "FUNCTION SETUP MODE", the MODE LED indicator will start blinking and two "beeps" will be heard.
2. Press the direction on the digital/analog directional pad and SELECT button that corresponds to the setting you desire. Directional pad UP and SELECT will give you high sensitivity. Directional pad LEFT/RIGHT and SELECT will give you medium sensitivity. Directional pad DOWN and SELECT will give you low sensitivity.
3. After selecting one of the above sensitivity options you will hear 2 "beeps" letting you know that the wheel has been programmed. For Customizable Sensitivity follow the directions below.
2. Rotate (either left or right with the wheel ) and then hold the wheel to the specific angle desired.
3. Press the SET button again, two "beeps" will sound to indicate the completion of the setting
To reset the the V3 Racing Wheel 2 to it's factory default settings press and hold START, L1 and L2 buttons in until you here two "beeps".
To change between Digital and Analog modes follow the directions below.
2. Press the SQUARE and SELECT buttons to set the wheel to DIGITAL, or the O and SELECT buttons for ANALOG. Two beeps will sound and the MODE LED will stop blinking letting you know that the mode has been selected.
By default GRAN TURISMO 3 A-SPEC uses the X and Square button for gas and brake. To reassign these functions to the pedals on your racing wheel:
1. Go to the options menu in Gran Turismo.
2. Select key configuration. (The picture of the Game Pad.)
3. Scroll down to Acceleration
4. Press Right on the D-pad (11x) until Analog Up is selected for the Right Analog Stick
5. Now go down to Brakes
6. Press Right on the D-pad (10x) until Analog Down is selected for the Right Analog Stick.
7. Press the X Button to confirm your changes and then press the Triangle button to return to the main menu
8. The gas and brake functions for the game will now be set to pedals on your wheel.
Sep 10, 2008 | Cables Unlimited InterAct Racing Wheel V3...
Controller Problem
most probably the controller's carbon button inside the controller is already worn out and is sticking on the controller's printed circuit board (PCB) there are some replacement carbon button that can be bought for a cheap price
or
if you are using an analog controller, check if the analog stick is loose in feeling, this might affect the controls as well because good working analog sticks are a little stiff when pushed
Jun 30, 2008 | Sony PlayStation 2 (PS2) Console
Controller problems
Have you gone back and tried that game again? And were you using one (or both) of the two sticks to move in that game, or were you using the directional pad.
The dual shock controllers on the PS2 have a small, easily overlooked button between the two sticks. It has a red light directly above it. If you push that button, the light will switch on and off. When the light is on, you can use the sticks in pressure sensitive mode. For example, if you push the stick a little, your character may walk, but if you push it further in a direction he will run instead. It's used differently in different games. But certain games won't operate unless that feature is either on or off (again, it varies by game).
My guess is that the button was accidentally pressed while you were playing, and suddenly the controller didn't work. But when you switched games, most games will turn the light on when they start up, if they need it, so the problem corrected itself.
-John
Feb 06, 2008 | Sony PlayStation 2 (PS2) Console
Button stuck or somethong
Round directional button? well if it is a button not an analog stick just take off the psp plate the face if you will and put it back on it wont be stuck if its the analog stick buy a new base not those tops a base were youll have to open up the psp and replace it ------------------------------------------------------------------------
( III -------------------------------------------- )
I == + == I PSP Expert I /\ I
I III I I [ ] OI
I I I X I
I ---------------------------------------------- {home} - Vol + PSP ( ) .?\ select start
Jan 24, 2008 | Video Game Consoles & Games
The "home" button on my PSP does not work
I have the same problem.. I cant put YES on home and my R button isnt working either.. but I've noticed that if I push down the power button to the HOLD lvl and then put it again to the medium lvl it works like the R button -_-'' ..
Jan 06, 2008 | Sony PlayStation Portable (PSP) Console
Sony PSP (Piano Black) Logo
54 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
