Question about Photography
Where can I find the replacement/additional quick
Where can I find the replacement/additional quick release pads to mount the dslr. I live in Richmond, Va. 23230
  • 10406 Answers
SOURCE: hard drive iffy- Want to donate it for parts, whatever....
List it on eBay -- sometimes, people have hard-drives where the _electronics_ fails, while the stored data is OK. So, they want the electronic part of your hard-drive, not the spinning media part,
in order to merge their spinning-parts with your electronic parts, in order to access their data.
Posted on Apr 27, 2009
  • 160 Answers
SOURCE: scanner codes for police in hanover & richmond va
http://www.radioreference.com/apps/db/?ctid=2862
and
http://www.radioreference.com/apps/db/?ctid=2861
Posted on May 11, 2009
kidspeedy
  • 321 Answers
SOURCE: lost only key to 2001 nissan maxima how do i replace ?
the only thing you can do is call a good lock smith to make a new set or call the dealer and see if they can make a set from your vin number.
dont start cutting wires and trying to jump anything.
hope this helps
jm
Posted on Jun 14, 2009
  • 1705 Answers
SOURCE: Where can I find a
You can try ebay or Canon them selves, the trouble is they cost about £50, as much a new printer.
Alternatively you could try cleaning the head, its probably only blocked with dry ink. But not using the printer software, you'll have to get hold of a printer head cleaning kit, I've seen them on ebay you'll probably also get them from ink suppliers.
Posted on Sep 23, 2010
dj_relly999
  • 4070 Answers
SOURCE: I have replaced brake pads
Hi and welcome to FixYa!
Nothing special in this car when it comes on replacing the disc pads. If you do want a hyundai pads then good but aftermarket pads are not bad though. They usually have the same quality.
Hope this helps and thank you for using FixYa! Have a good one!
Posted on Jan 04, 2011
I have a Vanguard VT-200. Is only for video cameras or it can be use for a DSLR camera? I need to add a special part to do so?
It should work for DSLR as long as the release plate will fit your DSLR camera. Most screws for the quick release plates 1/4 x 20 screw. Larger cameras and those with larger lenses need a bigger screws...making some plates non interchangeable.
Aug 16, 2016 | Cameras
Canon iR2318 show paper jam
try this :
Instructions
    • 1 Tap the "Additional Functions" button on your Canon copier.
    • 2 Press the "2" and "8" keys on the number pad simultaneously, and then quickly release them.
    • 3 Tap the "Additional Functions" button again.
    • 4 Tap the "Copier" button when you see the "System Management" screen.
    • 5 Press the "Function" button and then the "Clear" button.
    • 6 Tap the "ERR Button" to highlight all error and status codes that are active.
    • 7 Press the "OK" button, and then restart the copier to finish clearing the error and status codes.
Jul 23, 2014 | Canon Office Equipment & Supplies
How to mount Quantaray 70-300mm F/4.0-5.6 Zoom Lens in Sony Alpha DSLR?
This 3rd party lens (like all of them) makes lenses specifically to fit Nikon, Canon, Pentax, Minolta, etc. camera body mounts. Each has a style mount that is unique. You can not simply mount a lens made for use on a Nikon body on a Sony body.
In order to use this lens, it MUST be the model designed for use on a Sony camera. Functionally, the lens will be nearly identical on any camera it is designed to fit, only the mount (the portion that actually mates to the camera body) differs from one lens to the other.
If you bought this lens without specifying it needs to be used with a Sony camera body (and it is for a different camera) it will NOT mount. Determine if the lens is indeed designed for a Sony camera body. You may find additional letters & numbers on the lens that can help you determine which camera body brand it fits by plugging the number into Google for a search. Additionally, the Quantaray brand is / was a Ritz Camera "house" brand. You could probably bring it to one of their stores and learn all you need to know about the lens there.
Jan 31, 2012 | Quantaray Cameras
The hand held divice stopped working and the mounted pad light flashes quickly. The mounted pad does work.
The most likely problem here is that your wall control is bad. I would disconnect the 2 wires going to it and I think you will find your remote works. Replace the wall control.
Sep 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
I cannot figure out how to use the timer setting on my Sony DSLR a100. HELP
Press the Drive button (marked with a one-handed clock). Use left/right to select the one-handed clock. Use up/down to select the delay, then press the OK in the middle of the cursor pad. Start the self-timer by pressing the shutter release button.
May 22, 2010 | Sony Alpha DSLR-A100 Digital Camera
Lost mount for tripod can I get a new one?
Velbon QB-4W Quick-Release Platform is a nearly identical replacement for the plates that come with the Dynex tripod. You buy it from:
http://www.amazon.com/s/?ie=UTF8&keywords=velbon+quick+release&tag=googhydr-20&index=electronics&hvadid=3155273537&ref=pd_sl_6aoq8ub9ut_b
Apr 28, 2009 | Cameras
Mount for rollei pqs lense to nikon dslr body
The rollei 600x mount lenses communicate to the camera via the gold plated contacts. In addition, the 350mm PQS is a medium format lens. There is currently no such adapter.
Apr 06, 2009 | Rollei 350mm f/5.6 Zeiss PQS Lens
Missing munting post for SLIK U212 Tripod?
http://www.amazon.com/Slik-Professional-Universal-Panhead-Panoramic/dp/B00006I5SI
you can go to this site and order a replacement for 9.95.
please rate this answer as a fixya! thanks.
Feb 18, 2009 | Slik U-212DX Tripod
Nikon d60
The shutter remains closed on a DSLR until you take a picture. There is no way to preview an image that does not exist yet.
Being stuck with the tiny viewfinder as earlier cameras had is a good thing. Holding a camera out from your body will give mixed results due to your movements. You will get better results with the traditional method
Jun 28, 2008 | Nikon D50 Digital Camera
Photography Logo
56 people viewed this question
Top Photography Experts
pontelemon
pontelemon
Tony
Are you a Photography Expert? Answer questions, earn points and help others
