Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Both remotes work intermittently. Batteries have been replaced in both of them but problem still exists. They will work fine when I am within 5 feet of the main unit but otherwise I have to keep pressing the button until the remote eventually works. I tried reprogramming them too, did not solve the problem.
    President:
  • 3,197 Answers
If two remotes have exactly the same problem then it must be the receiver. It is part of the logic board.
Posted on Dec 11, 2009
Testimonial: "That make sense to me :) Thank you"
Have had a Dei valet 561r remote on my Honda van for several years. Worked flawlessly. Recently, it began working intermittantly. Did not work for several days. Then worked for about a week. Then nothing....
sounds like your car battery was also replace or it die
believe it or not the remote start needs to be reprogram again
find the valet switch, this what you are going to do
make sure ac radio and any other accesorie are off
start the car with the key within 2 seconds or less press and hold the valet swith, and way until the
led turns on and the parking lights on the vehicle flash about 12 seconds
no turn off the car close the door and start the vehicle with the remote good luck
Nov 19, 2010 | Directed Dei Valet 561r Remote...
Samsung DVD-V3650 - Remote operation (on/off, single frame) is intermittent. Batteries are fine...
The issue maybe the board in the players. Wipe the front to make sure the IR sensor isn't being blocked by a smudge, and if it still is intermittent you can try replacing the remote from the manufacturer. If both don't work the unit will need to be replaced if the intermittent working on/off is too much to bear :)
May 07, 2010 | Samsung DVD-V3650 DVD Player/VCR
2002 bmw 530i key does not (remotely) unlock doors or trunk but they work fine manually.
Unlock vehicle. Enter vehicle. Close driver's door. Switch ignition ON and OFF. Remove ignition key. Press and hold unlock button. Press lock button briefly 3 times within 10 seconds keeping unlock button depressed. Release unlock button. Some models: LED flashes slowly for 10 seconds. Some models: Central locking system locks and unlocks rapidly to indicate correct programming. Repeat above procedure if central locking system does not work and LED does not flash or LED flashes continuously.
Mar 09, 2010 | 2002 BMW 5 Series
Intermittent remote trouble
Your wall control is hard wired and doesn't use the receiver portion of the logic board. The remotes do. Your receiver is going bad.
Jan 12, 2010 | Sears Craftsman LiftMaster Chamberlain...
Remote hardly works.
austinater
Have you replaced the batteries in the remote with fresh batteries? If you have, then you may have IR interference that may be causing the intermittent loss of function on your remote. Try turning all components off, including any lights, to see if the remote works. If it does work, turn 1 component on at a time and trying the remote to see if it works. If the remote doesn't work after turning a component on, that is probably what is causing the problem. If it still doesn't work after turning all components on, you may need a new remote. I hope this helps.
Ray Calo
DISH Network
Sep 22, 2009 | DISH Network IR Remote Control
Elecrtonic ign. sw. switches on intermittantly. can it be repaired or must it be replaced? If you wipe the key front with a damp cloth it starts the motor immediatly
Try replacing the batteries in the key. Does the remote central locking work o.k. The switches themselves do fail and you must replace them. The only other item that can be faulty is the immobilizer ring wich reads the key signal and sends it to the switch. I would clean the key lens and replace the batteries. If problem still exists replace the immobilizer ring. These type of problems can be expensive to diagnose.
Jul 23, 2009 | 1999 Mercedes-Benz C-Class
2003 remote key fob batteries keep draining
Is there a circuit board inside with soldered componets ? May have silver migration problem , they used solder without lead ! GM has same problem with instrument cluster draining the vehicle battery . Chevrolet Truck Battery Dies Overnight Part II Watch this video . You may want to ask these guy .
Apr 21, 2017 | 2003 Chevrolet Silverado 2500HD
Keyless remote does not work after replacing batteries
I had the same problem and located the addendum to the owners manual. It's kind of overcomplicated it seems. Here is what it says:
1) Confirm all doors are closed and the key is out of the ignition.
2) Open the driver's door and put the key in the ignition within 10 seconds.
3) Remove the key within 10 seconds.
4) Push and release the driver's door switch 3 times within 20 seconds.
5) Insert the ingition key within 10 seconds.
6) remove the ignition key within 10 seconds
7) press and hold both "lock" and "unlock" on the transmitter for more than 5 seconds within 20 seconds of removing the key All doors will lock/unlock to confirm the process has been properly done.
8) Press "lock" or "unlock" on the transmitter within 5 seconds of completing step 7. All the doors will lock/unlock to confirm that the process was properly done.
At this point the transmitter has been properly programmed.
Of course, this didn't help me. My transmitter still does not work. I did confirm the procedure with a known good transmitter, so it is valid. If the lock/unlock does not happen in step 7, you more than likely have a bad transmitter.
Oct 12, 2008 | 2003 Suzuki Aerio
Vizio 50 inch plasma -- remote not working
You can also try to take out the batteries and push all of the buttons with the batteries out of the remote. Then put the batteries back in and push the power button on the remote. If this doesnt work press the two TV buttons at the same time and the remote should be fine.
Sep 14, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
215 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
